Kristins Teardrop
19,022
220
39
My name is Brian I am a retired union electrician. I was given a old snowmobile trailer that i had no real use for. So decided to build my daughter a camper.
Step 1: Fixing Trailer
Trailer came with bent tongue, first was to replace that and put new tires on. Had to break down tires twice. I forgot to put in new valve stems.
Step 2: Shape
After getting trailer sanded and painted I used cardboard to figure a shape out.
Step 3: Floor
I decided on a size. Trailer is 8x6 I went 4x8 for compartment. I used 1/2 inch plywood for top and bottom and 2x4s for bracing. I live in upstate N.Y. so insulation will help in cool weather. I sealed edges with metal tape and painted with elastomeric roof paint. I secured the floor to trailer with 8 3/8th in. bolts.
Step 4: Side Walls
For side walls I used 1/2 in. plywood on the outside and 1/4 in. luan plywood for inside walls. I put alot of bracing to try and keep plywood from warping and to use as support. I used a little heavier bracing on the door side. I used foam insulation in side walls.
Step 5: Setting Walls
After getting walls upright I tied them together with 1x2 boards and L brackets. Foam insulation for the roof. I wanted a vent fan so put opening.
Step 6:
Next I slid the Luan into place on the inside and used construction adhesive to adhere it to the cross members.
Step 7: Window
I had a old window out of a pickup truck so I used it. Trimmed with scrap walnut. I had some leftover oak flooring for the floor.
Step 8:
Next I worked on the tailgate area more plywood and bracing. Foam and fiberglass insulation. I had to use 2 pieces of Luan for the roof. Inside area is 4 foot wide so outside walls are 4ft.3in. wide. I tried to get the seam smooth with light body filler.
Step 9: Galley
On the rear I put a spot for stove and a small cupboard. Still thinking if I want more back here. I want to keep it simple. I used scrap butternut,mahogany and walnut for cupboard and most trim.
Step 10: Lift Gate
This gave me some trouble. First attempt didn't work out. I had used bent strips glued together, but they opened up some over the winter so I cut the arch from plywood and sandwiched 3 pieces together. Covered with Luan.
Step 11: Porch
This trailer is wider than most so I decided to put a porch or spot to strap bicycles or what ever on the side. I also put the battery box here.
Step 12: Lighting
Lights and fan from Amazon. I bought what I thought would work. Lot's to choose from. Lights are 12volt LED. Porch side light is switched at light. Door side and double fixture are switched from inside trailer. Single inside light is switched at light. There is a power outlet near the shelf for powering phone or tablet.
Step 13: Jacks
Thought I would try and make some stabilizer jacks. They work ok but need bigger base on the ground. Will weld a pad to the bottom of them. I had to purchase a wheel jack for the tongue.
Step 14: Outside Finish
I used faux wood boards. I got a roll of brown wrapping paper and cut into strips and painted with Sealskin color paint and used a faux wood tool to get the grain. Soaked them in glue and water and pasted them on. I sealed the outside with 4 coats of spar varnish for uv protection and waterproofing.
Step 15: Fun
First trip out camping.
Step 16:
Added a little night light for the kid's.
Step 17:
I added a 50 watt solar panel to keep the batteries charged up and switched to 3 AGM 7 ah. batteries. Also added a larger shelve inside.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    39 Discussions
    Zaspencer576
    9 months ago on Step 10
    This was the daunting part for me that I did not want to attack with mine.
    You did an awesome job on this build!
    Especially like the area of the trailer you didn’t frame in.
    Your square window made it much easier to “trim”. The camper window I got used wasn’t built for the thickness of walls I have in mine. And the window is curved.
    scooters2
    Tip 10 months ago on Step 13
    I changed the jacks a little bit. Made the end square to slide into a square piece welded to the trailer, and put a bigger pad on the bottom of them. They are much more stable.
    BrianT1
    1 year ago
    I admit that the teardrop shape is cute, but on a practical note I can never grasp the sacrifice of the space imposed by the curved roof compared to what a box trailer would provide on the same frame base (to say nothing of the added difficulties of construction with the curves). I've illustrated this with yellow lines in this picture. (Please, someone, don't say it's more aerodynamic. On trailers this size that really isn't a consideration.) Especially with small trailers, every cubic inch of space is precious with none to waste (in my opinion), especially if you contemplate ever using it to bug out and see you through an emergency..
    AlistairW7BrianT1
    Reply 1 year ago
    The "original" tear drops were designed as a build the yourself camper trailer and there is really only one curve which is not that hard to do. The curve is due to the fact that it is easy to bend ply and made for a more waterproof roof before current materials were available. The lack of space is due to the fact that it is not a full caravan, but a dry bed space to sleep in. Living and cooking is aimed to be outside. The low profile and light weight do make a difference for older and smaller cars - plus IT'S GOT THE LOOK.
    scooters2BrianT1
    Reply 1 year ago
    you are correct there is a big loss of space. Were this a work trailer it would matter. When my kids were little I had a chuck wagon I would pull behind the wagoneer for camping. I found all those little compartments were just a place for spiders to collect. Also this trailer has small tires I would worry about cross winds on the highway were it big and square.
    Steinzel
    1 year ago
    Wonderful build! I have been thinking about building one for quite a while. Maybe some day...
    wordsnwood
    1 year ago
    I've never seen a trailer offset to one side like that... how does it pull on the road with the off-center weight?
    scooters2wordsnwood
    Reply 1 year ago
    I know it looks one sided but the deck boards on the porch side weigh close to what the compartment weighs. The trailer was for one or two snowmobiles.
    scooters2scooters2
    Reply 1 year ago
    PS. Kristin and I put the hitch and light kit on her Honda Element yesterday. Maiden voyage will be to Sampson State Park. Will let you know how she does.
    wordsnwoodscooters2
    Reply 1 year ago
    ps: I was at that park in 2008... it is surprisingly remote and isolated. Hopefully warm enough to jump off the dock! :-)
    darklotus
    1 year ago
    PS As in roadworthy, did you need an engineer's certificate, an official inspection or the like?
    scooters2darklotus
    Reply 1 year ago
    Hi. It just gets a regular utility trailer inspection, they check lights and tires.
    darklotus
    1 year ago
    A great design and build scooter! I don't know what the laws are where you are but if you have to register trailers and caravans and such, is it considered roadworthy?
    elaborde
    1 year ago
    How did you furnish the inside? Where does the bed go and how big a bed did you get into it? How tall is it on the inside? How did you do the door? It sure is cool. I want one. :-)
    scooters2elaborde
    Reply 1 year ago
    hi. I really didn't do alot on the inside. Pretty much just a cave to sleep in, bring your own bedding. It is 4 foot high inside and 7 foot 3 inches long in the sleeping compartment. It is for camping so don't want it to cushy. have a good day.
    IngenuityAtWork
    1 year ago
    Nice build! That would be perfect for kayakers, could get a couple on the side with the addition of a couple pair of brackets.
    scooters2IngenuityAtWork
    Reply 1 year ago
    funny you should mention it that is what my son thinks. He will have to work it out with his sister ha
    wesleyfurr
    1 year ago
    I don't see anything in the photos or notes about venting for the area where the battery is located. When a standard wet cell battery charges, it gives off hydrogen gas when charging, which could be explosive if it builds up and finds a spark...please consider adding some venting to prevent something bad from happening...
    I also see comments about weight...the tires should have a weight rating printed on them at maximum inflation. Should be pretty easy to weigh the trailer and find out for sure.
    scooters2wesleyfurr
    Reply 1 year ago
    howdy if you look the bottom of battery box is just deck boards not sealed, venting should not be a problem. I have a deep cell marine battery for it and a 5 watt solar charger. Tires are 4.80x8 rated 750lbs. at 90 pounds of pressure. Trailer was a tilt bed snowmobile trailer.Scale is only couple miles down the road will weigh it at some point. I weighed the trailer empty when i got it 250 pounds.
