LED Matrix With Arduino Made Easy
15,780
102
28
About: I love Arduino and Raspberry pi and High Voltage... i build robots and also other cool stuff so stay tuned !!
I am gonna teach you how to use a MAX7219 Led Matrix with arduino UNO and the best part is that it is super easy.
Supplies:
Step 1: What You Need ?
The parts list:
1. MAX7219 LED Matrix
2. M/F Jumper Wires
3. Arduino UNO
4. USB cable for arduino
5. Computer
Step 2: Wiring
There are 5 pins on the module that are connected in a way :
Vcc to 5v
Gnd to Gnd
DIN (DataIN) to Digital Pin 11
CS (LOAD) to Digital Pin 10
CLK to Digital Pin 13
Step 3: Programming !!
MAX7219.ino is a sketch of scrolling text. You can change the text that is scrolling on the matrix by changing the line in the sketch shown in the picture and writing what you want. This the link for the MaxMatrix library https://github.com/riyas-org/max7219. From it put the folder named MaxMatrix in you arduino libraries folder which is located in the documents folder
Step 4: Testing Results
It is totally wicked !! It doesn't look half as good in the pictures as it really is. In the pictures it looks like that the leds are bright but they are diffused leds and you can see it only when you build it. So what are you waiting for !!
Step 5: Thinking Ahead
You can wire 8 matrices together and use them with arduino still only using 3 pins. The CS, CLK, 5v and Gnd of all matrices are wired together and the DataOut of the first matrix is wired to the DataIn of the next matrix and so on. The center header pin opposite to header pins near the ic is the DataOut.
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    28 Discussions
    Magicflea
    Question 11 months ago
    Maybe a little off topic but....
    Would I be able to drill a hole(s) in the middle of the LED matrix, missing LED's and solder points, and it still be functional?
    1 answer
    Crux Australis
    Question 1 year ago
    Hi there. I get an error message that says
    Invalid library found in C:\Users\Administrator\Dropbox\Arduino\libraries\max7219-master:
    I've installed the MaxMatrix and max7219-master libraries.
    Any ideas on how I can fix this?
    Rsympson
    Question 1 year ago on Step 3
    I'm getting an error in line 11 when compiling the code. Can you help?
    FSJCEIJI4J6TSTH:11: error: 'prog_uchar' does not name a type
    PROGMEM prog_uchar CH[] = {
    C:\Users\Robert\SkyDrive\Documents\Arduino\LED Matrix Test\FSJCEIJI4J6TSTH\FSJCEIJI4J6TSTH.ino: In function 'void printCharWithShift(char, int)':
    FSJCEIJI4J6TSTH:164: error: 'CH' was not declared in this scope
    memcpy_P(buffer, CH + 7*c, 7);
    C:\Users\Robert\SkyDrive\Documents\Arduino\LED Matrix Test\FSJCEIJI4J6TSTH\FSJCEIJI4J6TSTH.ino: In function 'void printString(char*)':
    FSJCEIJI4J6TSTH:189: error: 'CH' was not declared in this scope
    1 answer
    lrh18Rsympson
    Answer 1 year ago
    change prog_uchar to const unsigned char
    Fairly OldGit
    1 year ago
    Question :
    Is it possible to change the pin assignments for the CLK, & DIN pins if so, where/how do you do it ?
    ArsS1
    1 year ago
    how pin nummbers in mega 2560 - clk , data in???
    JimmyK7
    3 years ago
    Hi I have some problem see as below and need to help
    MAX7219.ino:8:23: fatal error: MaxMatrix.h: No such file or directory
    compilation terminated.
    Error compiling.
    Thank...
    Arduino TechJoe Moger
    Reply 1 year ago
    Just search for MAX7219 arduino library and select the Github page and download it from there and put the downloaded folder in the library folder of arduino which is located in the documents folder. This the link for the library https://github.com/riyas-org/max7219 . From use the maxmatrix folder
    LesB
    2 years ago
    I would like to see this done with an RGB matrix
    Arduino TechLesB
    Reply 1 year ago
    It can be done but I don't have an rgb led matrix.
    ShioriToshiko
    3 years ago
    How do I work the led matrix when it has 8 pins and I don't know which pin is which?
    I included pictures of what mine looks like, and it doesn't include the thing you have on yours with the five pins on it.
    Arduino TechShioriToshiko
    Reply 3 years ago
    mine also has 16 pins but is multiplexed by max7219 IC in the module so it can controlled with 5 pins. Buy this module on amazon or some other site
    ShioriToshikoArduino Tech
    Reply 3 years ago
    Is there any way to do this without the module? (I'm kinda broke right now... lol) It's okay if you don't know, I'm just asking.
    Reply 3 years ago
    pandya998
    2 years ago
    i downlode laibrary but not compail program
