LED Resin Cube
132,678
1,135
87
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with.
Hello Again,
I've been wanting to use clear casting resin ever since I saw it used in this brilliant Instructable by Koogar.  Before I took on something as big as Koogar’s project, I wanted to start small so I came-up with “LED Resin Cubes”.
The idea behind the LED Resin Cube was inspired by a mercury switch that I found at my local electronic store.  I love the simplicity and look of this switch and wanted to incorporate it a project so you could see the switch in motion.  As the switch is made of glass and fragile, it’s pretty important to encase it in something strong – hence the clear resin.
Check out the video below to see the LED Resin Cube in action.
This is a really easy project to do and the end result looks pretty cool.
Step 1: Things to Gather
Material/Parts
1. LED lights.
I used these lights from eBay but it is up to you what type of LED light you want encased.  The LED's I used change colour everytime you push the swich, and for the last change the lights flash!
2. Batteries.
I used these batteries from eBay.   They are small button batteries that can re-charge and throw out 3.7v which is plenty to power an LED/s
3. Charger.
I used this charger from eBay.
4. Mercury Switch
5. Female 3.5mm power jack
6. Male 3.5mm plug
7. Copper wire.
(To make the frame)
8. Clear casting resin.
This can be purchased from your local hardware store or eBay.  I used "Diggers Casting Resin" which I purchased from my local hardware store.
9. Solder
10. Casting mould.
I used a small, square, plastic container which held chicken stock cubes - see below
Tools
1. Soldering iron
2. Pliers
3. Wire cutters
Step 2: Creating the Frame
The first thing you need to do is bend the copper wire to make frame.  One end is added to the battery terminals, and the other to the female jack which is how you will charge the batteries.
Steps:
1. Bend and shape the wire as the below images show
2. Solder each wire onto the battery terminals.  Make sure that once they are soldered onto the terminals, the battery sits flush and the wires are reasonably straight.
Note:
Circuit Board - Make sure you mark-out or memorize where the wires are connected the circuit board and switch - you're going to need to make sure that you solder everything in the right place and on the right polarities!
3. Cut a small piece of copper and bend as shown.  Attach to one of the battery solder points on the back of the circuit board as shown.  This will be where you attach the circuit board to the frame/battery
Step 3: Adding the LED’s and Mercury Switch
Next thing is to add the circuit board which has the LED's attached, and switch.  Be careful – you don’t want to break the mercury switch!
Steps:
1.  First you need to solder the circuit board onto the battery terminal via the small arm attached to the circuit board as shown.  This is a fiddly job and may take a couple of tries to get straight.
2.  Next bend another small piece of copper and solder to one of the solder points where the switch is attached.  This copper arm should be sticking-up as shown below.
3. Solder on the mercury switch.  As you can see in the images below, I have slightly angled the switch which will allow the mercury to move significantly enough to turn off the LED’s if they are turned on their sides.
4. Solder on the other switch wire to the end of the mercury switch.
5.  Solder the last wire to the other battery terminal.
6.  Add the female power jack to the ends of the copper, making sure the polarity is correct.  This is your chance to shorten the copper if necessary.
6.   Test.
Note – I’m sure that everyone is aware that mercury is very poisonous.  Please be careful when handling it and use the usual precautions.
Step 4: Testing the Resin
I decided to do a test first as I didn't want to mess up the LED's and have to start again!.  Instead of the LED's I added a battery to the resin (first thing I found lying around).  When mixing the resin I found that it starts out with a slightly yellowish tinge but once it sets turned clear.
I left the resin to cure for 24 hours and then removed from the mould.  I had to break the mould to get it out and then leave for another 24 hours until everything was completely dry.  The finish on the hardened resin was rough but clear.
I used some 600 and 1200 wet / dry sandpaper to get some of the roughness out of the casting and used some brasso to give it a really smooth finish.
I initially tried to create a hard, resin base and let that set but I couldn't wait so I just poured the whole of the resin into the mould.  If you look at the images, you can see a faint line where the 2 different set resins meet-up.
The steps on the following page show how to achieve a clear finish using wet sandpaper
Step 5: Adding the Resin
Now that you have finished your LED light and switch, you now need to put it in clear resin.
Steps:
1.  First you need to decide on what container (mould) you want to use.  I found the below container at the supermarket which worked perfectly.
2.  I decided to use the lid as the base as it was smooth and would also help to get my cast out easier.  Cut the top off the container so you can pour the mould in.  I then hot glued the up-side-down lid to the opening.
3. Add the LED’s and battery to the container, making sure that the socket it at the top! (obviously) and add some blue-tack to the hole.  This way you won't get any resin in the jack.
4. Mix the resin as indicated.
5. Pour in the resin to the top of the jack.
5. Set to dry for 24 hours and remove from the mould once finished.
Step 6: Smoothing and Finishing
Once you take out the cast out of the mound (I had to break the mould to get it out!) you’ll have to polish the cast to get a clear, smooth finish.
I must admit I didn't what wet sandpaper is and how it worked.  After some research I discovered how to use it correctly.  I have put together some points below for these like me!
Steps:
Wet sanding is a sanding technique that uses water to lubricate both the sandpaper and the surface to be sanded so the grit will last longer, and so you can attain a smooth-as-glass appearance. Using water while sanding will also keep the dust down.
1. Soak sheets of sandpaper in a bucket of water for 20 to 30 minutes before using them. Start sanding with a low-grit paper (300 grit) to remove large imperfections quickly.
2. Take the sandpaper out of the bucket and cut it to fit around a rubber sanding block. Wrap the sandpaper around the sanding block. Avoid wet sanding without a sanding block because your fingers will press onto the sanded material unevenly, wear the sandpaper out faster in those areas, and it may take longer to obtain an even sanding.
3. Spray the surface to be sanded with water, coating it evenly. The water will hide the scratch, so you will think it is gone when it isn't. Clean the water away from the area to see if it is really gone before moving on to other areas.
4. Sand the surface with progressively higher grits. Sandpaper is available in grits up to 4000, but it is OK to stop sanding after using 1200 to 2000- grit sandpaper.   Clean the surface in between grits to remove debris so the finer sandpaper is not contaminated with larger debris. Spray water onto the surface as needed.
5. Add a buffing compound such as Brasso to the sanded area when sanding has been completed and buff the area with a cloth.
Step 7: Finished
Completed!
You now should have a pretty solid looking clear resin cube with an LED embedded inside.  Try it out and make sure that everything works ok.  If it doesn’t I’m afraid there isn’t much you can do but start again!
I found using resin pretty easy - as long as you follow the instructions you can't go wrong really.  It’s a great product and I can't wait to use it again.
Learnings
The next one I make I don't think I'll use the female power jack.  Solar would work better and everyting would be contained inside the resin.  You would need to find a small (and I mean small!) , 4.5v solar panel but it would be pretty cool.
You could also have 2 peices of the copper sticking out of the top and when you need to charge you could connect a 4.5 solar panel to the ends.  This would be a good way to simplyfy the insides.
Happy casting.
Lamps & Lighting Contest
Second Prize in the
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
87 Discussions
aoyarce
Question 9 days ago
Excelent proyect, im doing something the same, so i have a question.
Would the battery need to breath? If is all sealed, can the battery break?
How is your prouct now? still working?
1 answer
lonesoulsurferaoyarce
Answer 2 days ago
Yep - batteries for discovered after making this project need to be able the breath and release gases. The cube died on me about 8 months later if I recall. I made a couple of others and tried to compensate for the enclosed batteries. If you are
Able to enclose the batteries inside a small enclosed area, the you should be able to solve the breathing issue
EduardoA7495
Tip 4 weeks ago
e quase o cubo do filme thor ,este cubo blilhando um azul intenso , e lindo
EduardoA7495
Tip 4 weeks ago on Introduction
e uma ideia muito interessante , eu colocaria uma bobina interna de fio com retificador en uma forma de ferrite ,ela carregaria uma bateria recarregável para alimentar os leds multi coloridos ,e possível montar um eletroímã em alta frequência como base de carregamento ao se aproximar do cubo ,ate um transformador pequeno emite 60hz a uma boa distancia ,com ajuda de um imã alojado em uma base alimentada por rede elétrica .algumas bobinas podem ser retiradas de placas eletronicas ,e testadas como mini geradorsa de corrente junto da base carregadora .
magiceye
3 years ago on Introduction
I have a mercury switch connected to 12v bulb I am going to give circuit a try thanks to your instructable.
benom
4 years ago on Introduction
I have done a resin cube with a small solar cell. It was working fine, but after a week it's not working, I think that the battery has died :(
Flambout
5 years ago on Introduction
This is so cool. I have bought the components to build this with a solar cell; but I do have a question. How did you keep the battery and the copper frame from being exposed to the air? If they were sitting on the floor of the mould, I assume that the resin could not entirely cover them. Did you manage this?
webgiantFlambout
Reply 5 years ago on Introduction
One way of preventing the bottom of the apparatus from touching the base of the resin is to mix up a tiny portion of the resin and fill the bottom of the mold. Then once the initial resin is dry, rest the apparatus on the resin base and fill it the rest of the way with resin mixture. The heat from the second application of resin should bond the resin base to the resin block, as it has done for me in the past.
Flamboutmrlivingston
I have not had the compenents delivered yet. I was planning to copy this one, but wire up the solar cell to the batteries. I don't know wherebouts you are, but I bought a torch powered by a solar cell from the UK store Maplins - the brand name is Rolson and it says the cell is rated at 4.5v. The cost was about three pounds or so.
Are you going to incorporate the solar cell into the resin? That's definitely the right way to go. I haven't found the right size solar panel yet, I'm looking for something small and square.
Also, you'll need a 5v to 5.5v to charge the 3.6v battery, the voltage needs to be higher so it is "forced" into the batteries.
Ah. I was hoping that a 4.5v cell would do it. Do you think that would work or shoudl I source a better cell? If it matters, I would prefer a low rate of charge to the battery since I think the cell will be exposed to light pretty much 24/7, but the LEDs will only be on occasionally. I am a bit worried about overheating.
It might be ok - I assume the batteries are 3.6V? Overheating could definitely be an issue but so far my one hasn't exploded! It has probably helped that the batteries were so close to the bottom of the resin!
Yes, the batteries are 3.6v. I was wondering whether it is possible that the power jack in your cube could be acting as a heat sink? I assume it would not be very effective but it is connected to wiring, so any heat would presumably go along the metal of the circuit to the air.
I was thinking about resting the battery on a coin with the coin acting a a heat sink - what do you think?
Howdy
I haven't made it yet! I plan to do one in a couple of weeks though. It will be similar to the one I made bit will have the copper sticking out the top so you can charge when needed.
Good spotting!
There was a thin layer on the bottom and the battery was just inside the resin. Once I started sanding a tiny bit of battery was exposed. The way to fix this is to put a small layer of resin on the bottom of the mould and let this dry. You'll then be able to put the batteries on top without them being exposed at all.
Happy building!
ccronkhite
Another option for charging would be to extend copper wire out of the resin, trim it off and make it flush with the outside and have a charging base with contacts that it sits on.
webgiantccronkhite
Or a snap-on base containing the battery. The battery contacts sit on the very outside edge of the resin block, and insert into the snap-on base. This would remove the problem of the battery getting killed by the resin, and remove the need for the ugly DC port on the top by moving it to the bottom.
ccronkhiteccronkhite
I like the bare wire. I'm picturing a steam punk inspired creation with copper wiring and a charging base made out of wood, and/or brass.
