LED Ring From Recycled Bike Rim
11,643
51
19
About: I run the Maker Project Lab blog, and a weekly video series called Maker Update. Email me at donald@makerprojectlab.com
Inspired by Loek Vellkoop’s Instructable, I recently chopped up a scrap kid’s bike to see all the materials I could reuse from it. One of the elements that really struck me was the wheel rim after I had taken all the spokes out.
Solid, made from steel, and perforated with precisely spaced holes, I thought it would be cool to light it up with LEDs as an accent lamp, or just something cool to trip out on. So, that’s what I did, and I’m proud to say that I whipped it together in an afternoon while my family was out shopping.
Step 1: What You Need
WS2811 Strand Lights
These are Neopixel-compatible addressable LEDs. I was introduced to them by the amazing Scott McIndoe who used them on a similar LED ring project, a flexible infinity mirror. For this project, with the size of the rim, I only used 14 of them. I could have doubled up and used all the holes in the rim, but I only used half. I figure I can use the rest on the second rim.
Small Arduino Board
I ended up using an Adafruit Pro Trinket 5v, which works great and fits inside the rim. But in full disclosure, I was using an Adafruit M0 board first, which also worked fine and is even smaller, but I somehow fried it after soldering and desoldering connections so many times. This code really should work with any common Arduino board though you may need to change the Neopixel output pin in the code to accommodate your board.
LiPo Battery and Charging Backpack
The hardest part of this whole project was figuring out a way to power it that I’d be happy with. I wanted it to be portable, so I needed an elegant way to cram a battery in rim. By using a small LiPo battery and this board, I’m able to fit a battery into the profile of the rim that I can recharge over the Trinket’s micro USB port. So if battery power gets low, I can just connect the whole rim up to a USB power adapter or power bank and load it back up.
Small Switch
The battery back pack also has an easy way to wire in a power switch. Any switch would do, but I had this black, pre-wired one from Adafruit that worked out nicely.
Tools used
High Leverage Cutters or Angle Grinder
For removing the spokes from the wheel. Be sure to wear safety glasses too.
Step Drill Bit
For making the existing spoke holes wide enough to fit the lights.
Glue Gun
Holds the lights in place and mounts the electronics in the rim. I used black glue sticks (https://amzn.to/2JvKuYv) to match the color I painted my rim.
Spray paint (optional)
If your rim isn’t a color you like. I recommend roughing up the existing paint on the rim before you paint over it. This will help the new paint stick better.
Deburring Tool (optional)
Helps to smooth off the jagged bits from the holes you made bigger.
Soldering Iron, solder, wire, etc.
Just, you know, soldering stuff.
Helping hands (optional)
With these tiny boards and connections, a nice helping hands tool is useful. I enjoy these ones made by RaptorLoc.
Step 2: Make a Naked Rim
Pop a tire off an old bike. The front tire is the easiest to remove. In this particular case I used a kid’s bike which had a smaller rim that worked out nicely. I’m not sure if this would look as cool with a larger rim, but maybe.
Using high leverage cutters (don’t forget the safety glasses) I snipped my way through all the spokes and removed the tire, tube and lining.
Step 3: Make Holes Bigger
Using a step bit in a drill or impact driver, make the holes you want to use in the rim big enough to fit each LED.
For this experiment I only used half the rim holes, alternating every other one. With my rim size, I found this spaced the LEDs out just enough to take out the slack in the LED cable. That said, using all the spoke holes would have worked too. It just means more lights, and more power, which cuts down on battery life.
As far as hole size goes, I had the lights handy to make sure I got each hole wide enough. On my first pass I made the holes just big enough for the tip of each light to poke through. But, then I thought it might look cooler to have more of each light reach through, so I made the holes a little bigger.
Either way, just know that you don’t need to get the sizing perfect. Really it’s the hot glue that holds each light in place, not pressure.
After getting the holes the right size, I used a deburring tool to smooth off the jagged pieces left behind.
Step 4: Paint the Rim
This is an optional step, but my rim was Pepto-pink and I thought rainbow lights with a pink rim just wasn’t my style (though, I do rock a Hello Kitty car). So, I roughed up the gloss of the rim with a little sandpaper and hit it with some matte black primer. You can do what you like.
Step 5: Wire the Electronics
In case you missed my earlier confession, I had some trial and error getting a combo of board and code that I liked. My first attempt used a Trinket M0 board wired up to a removable 18650 in a battery holder. This code will work for that combo too, but I found the 18650 battery solution too bulky. When I ditched it for a small LiPo pack and a recharging board, I somehow fried the Trinket in the process (a shame, because I love those boards).
Fortunately I had some Trinket Pro (5v) boards handy. Overkill for this project, but they fit right inside the rim with no problem.
In the diagram, you can see how I wired it to the LED lights and the battery charger breakout. Even though the little battery board is designed to stack on the Trinket, I wired it up to keep the profile low and keep it and the battery in a separate section of the rim. This way, it’s more like a chain of electronics, than a stack. Be sure to use enough wire so that each part of the chain can fit in a different section of the rim.
Also, note that I wired up a little tactile switch to the battery board. This lets you turn the battery on and off and the board has a nice, built-in spot for it. The only trick is that you have to scratch away a little copper trace on the battery charging board if you want to make use of the switch feature. So, don’t forget to do that.
My choice to use pin 4 on the Pro Trinket came from my first attempt with the M0, which uses that pin specifically for LEDs. But really, there’s nothing special about that pin on the Pro Trinket, so use whichever one you want, just remember to make the code match.
Step 6: Code
I’m using the FastLED DemoReel100 example sketch (https://github.com/FastLED/FastLED/blob/master/examples/DemoReel100/DemoReel100.ino) to make this happen. The code is stock except that I changed the data pin from 3 to 4. My version with this slight modification is included as a file here.
You’ll need to add the FastLED library to your Arduino software by going to Sketch>Include Library>Manage Libraries and then search for “FastLED”. Then, click Install to install the library.
You can find this same code in the FastLED Examples folder that’s installed with the Library, but as I said, you’ll need to make sure the code defines the data pin to 4 (or whatever pin you connected your LED data wire to).
And play around with it. You can comment out parts of the demo to have it skip sections. You can make the delay between demo modes longer or shorter. You can increase or decrease the number of LEDs on the strand. Lot’s to tweak.
Also, in order to add the Pro Trinket (or any Adafruit Arduino board) to your Arduino IDE software, you’ll need to tweak a setting to have the Adafruit board library included. It takes five seconds and the instructions to do that are here.
I think that covers it, but if I missed something leave me a comment.
Step 7: Glue the Lights In
With the code uploaded, your battery connected, and the power switched on, you should see your lights all blinky and awesome. If not, time to troubleshoot.
If it checks out, time to glue the LEDs into their holes, starting with the LED closest to your board.
Before gluing, you could carefully count out exactly how many LEDs you need from the strip and cut away the remaining LEDs. Knowing me, I’d miscount, so I glued them in first before cutting away the extra.
I used hot glue to place each LED in each hole, keeping an eye on consistent depth and angle. It takes a minute for the hot glue to set each time, so be patient.
Also, for light projects like this I typically like to use black hot glue. It helps create a light-tight seal and generally looks less like a hot glue craft project. That said, it’s messy stuff, and in the end I found that the casing around these LEDs let a lot of light out of the back anyway, so it doesn’t really matter. Do what works for you.
Step 8: Glue the Boards In
When you’re ready, use hot glue to carefully mount the boards, button and battery inside the well of the rim in the space between the LEDs.
Be sure to place a nice, fat pillow of hot glue between any bare electronics and the rim, since the metal is conductive and can short out the project if it comes in direct contact.
Also, make sure to leave the micro USB port of the Pro Trinket exposed and accessible to that you can charge the battery up later. To ensure a good fit, I recommend having a cord already in the USB port when you glue it in, just to make sure you have enough clearance.
If you screw up and glue things in wrong, you can always use a little Isopropyl alcohol solution to undo the hot glue bond. Just be careful not to get alcohol on your Trinket’s chip, or it may fry.
Step 9: Take It Further
The coolest thing about using bike rims for a project like this is that unless you scrapped a unicycle, you probably have a second one to play with. I’m already planning my second build using the other rim. I think I’ll use more lights and tweak the code for a different effect.
If you build your own version of this, I’d love to hear about it. Post about it in the comments or send me a message.
Be sure to vote for me, and for more project ideas like this, check out my weekly YouTube show, Maker Update!
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    19 Discussions
    WindowsA
    1 year ago
    Really cool Idea . Show to my friend who rent bikes . Lets see if he will sucsed to make good ones ;). Thanks for the share
    You did a great project. I've lately been thinking about making some different kind of a wind chime. If you haven't started on your second wheel project yet think about this. This is basically off the top of my head so.... How about using your first project, but keeping the spokes and bearing hub. Then add some small solar cells, weather proof the whole thing. Attach the wheel hub (bearing) to a pole sunk in the ground, add some wind catching devices(told you it was off the top of my head) and pieces of pipe for the more conventional wind chime. I don't know if I'll ever have the chance to make this, but boy I think you would win the coveted thingamagig Instructable. Please if you would run with my idea, all I ask is to let me in on your ptogress. I'd love to see it. Take care and God Bless.
    Marty
    Dolevett
    Question 1 year ago
    this looks awesome!
    I have a question for you (I'm not a technical person!). I'm a wheelchair user and currently have battery powered Xmas lights on my wheels (my attitude is that if I have to have a chair, make it a funky one!). Would it be possible to make a version of this project that works with the wheels and spokes still on? Mine attach to each spoke with sellotape (told you I wasn't technical!) but I'm sure you could suggest something more appropriate!
    Thanks
    Donna x
    GordoYYCDolevett
    Answer 1 year ago
    These style of LEDs come in strips from a variety of sources in a variety of configs. I'd suggest searching for: colour LED strip self-adhesive waterproof
    If you have enough of a rim lip (need about 10 mm) for them to adhere to, you can end up with the same thing, just with 40-90 of the LEDs depending on how many LEDs/meter They can generally be cut to length, so if you get a 2 meter strip, trimming a bit off would fit the ID of your wheel.
    Brightness, hence current draw, can be set up via software to meet your needs / battery pack sizing. They only require 1 or 2 pins to control, so any little micro (ATtiny) can control them. https://www.adafruit.com/product/1138
    Good luck!
    schaapkameelDolevett
    Answer 1 year ago
    I think funkifying any part of your daily life is a great idea! Would it be possible to tiewrap a smaller kids bike rim to the existing wheel? This way you would not need to alter and possibly weaken the actual wheel. But I think the product Donald suggested (the weatherproof adafruit one) could be used in a simple way outside the rim too.
    let us know if you made something! Go funky!
    Donald BellDolevett
    Answer 1 year ago
    Great question! I came at this project just excited to find new uses for the scrap pieces from this bike. But the more people I show it to, I'm frequently asked if there's a way to make this so it can be usable as a functional bike wheel.
    I think the answer is that it's possible, but dangerous, because each new hole (not reinforced by a spoke) will only weaken the rim. On a bike traveling at high speed, that could be a dangerous point of failure.
    That said, if anyone was to attempt it, I'd suggest using this flatter style of weatherproof LED (https://www.adafruit.com/product/738) or (https://www.adafruit.com/product/3631). The slimmer profile would likely fit in the channel better and leave room for the tube.
    A more practical solution would be to apply it to the outside of the rim. I'm curious to try out some solutions. You can find my email in my bio and contact me directly. I think it would be neat to work on a project like that.
    Oldbear
    1 year ago
    Might I suggest that you mount the tire back on to hind the wires (not that I don't like the wires) or, for even more "tripping out" mount an infinity mirror with this setup...
    Donald BellPenolopy Bulnick
    Reply 1 year ago
    Well, I do have a second rim! I just thought that black would provide a better contrast to the rainbow lights. But hey, I'll embrace full rainbow-pink-princess-power mode on the next one.
    ILykMakin
    Question 1 year ago
    Wondering why you didn't drill the spoke holes to size vs making brand new holes as you did?
    1 answer
    Donald BellILykMakin
    Answer 1 year ago
    I expanded the existing holes with a step bit. I did not drill new holes.
    audreyobscura
    1 year ago
    This came out great! I subscribe to your YouTube channel and was excited to see that you had shared your documentation on Instructables! Well done!
    Donald Bellaudreyobscura
    Reply 1 year ago
    Thanks Audrey! I'm trying to make time for getting more projects up on Instructables. The content here provides so much for me, it's nice to give something back.
    Thorondor95
    Tip 1 year ago
    Micro drone race gate, made from trash.
