Lab Centrifuge Fidget Spinner
20,036
89
24
About: Hi there!
Hi guys,
In this article you will find how I made this special fidget spinner that can be used as a centrifuge for lab experiments!
Here are all the steps:
  • Centrifuges. Why do we use them?
  • Requirements. Few things you need to have or need to know.
  • Designing the spinner. The main steps on Fusion 360.
  • The bearing caps. Here you will find a tip to make 2 colors prints.
  • Adapters for smaller tubes. If you want to work with 500µL tubes.
  • Files and More. Because I love you all.
I have also entered the "Fidget Spinner Design Contest", if you want to have a look!
Step 1: Centrifuge
Basics about centrifuges
Nowadays centrifuges are everywhere in wet labs such as biology, chemistry, and I guess they are one of the most common and important devices you can find there.
It is mainly used to separate different components from solutions. When it is spinning, the centrifugal force "pushes" the heavier particles to the bottom of the tubes (it is called the pellet), while lighter particles will stay on the top of the solution (it is called the supernatant).
For example it is possible to separate components from the blood like cells, but also smaller particles like different proteins in the same solution, nucleic acids, etc...
Usually many parameters can be changed on a centrifuge:
  • Temperature. This is important if you are working with biological material that need too be kept at a certain temperature.
  • Magnitude (in RPM (rotations per minute) or in RCF (relative centrifugal force)).
  • And duration.
If you want to know the force (RCF or g-force) acting on the particles with a certain speed in RPM, just use the following formula:
RCF=11.18 x r x (RPM/1000)^2
With r the radius of your centrifuge (or your fidget spinner!), and RPM the speed in rotation per minute.
The weight has to be equivalently distributed around the axis, otherwise the centrifuge does not spin correctly and it might break. That is why we have to add counterweights: when you add a tube in the centrifuge, make sure to add another one with the same weight on the opposite side of the axis.
If you want to read more about centrifugation, check this link.
Why using a fidget spinner as a centrifuge?
Here I do not claim to make component separation with this spinner... Yet, centrifuges are also sometimes used at low speed, for quick duration. Here is an example: sometimes the solution is sticking to the lid of the tube. This is a problem because in these conditions any tiny drop is really important. Indeed we are often working with microliters (or µL) which correspond to 0.000001 L (this is really small!). As a comparison a drop of water is about 50µL. Anyway, if the drop is sticking to the lid of the tube, and you open the tube, you might lose it, or forget to take this drop with your pipette... In this case it is important to centrifuge for few seconds the tube so there are no drops sticking to the lid. And this is why I made this lab spinner. Quickly and manually centrifuge tubes to clear the lid before usage.
Step 2: Requirements
You can use this fidget spinner with 2mL and 1.5mL tubes. If you don't have these tubes, it works anyway, but it is a bit useless...
If you have no bearings, you can download some (here for example), and print them! That is what I did!
And I have also designed the spinner making sure the tubes can pass between my fingers when spinning (see the gif).
Step 3: Designing the Spinner
Here I will briefly describe how I made the design.
The main point here is the technique I call Copy/Paste/Rotate (see the gif). In this design, I have designed only one branch of the spinner, then copy/pasted it and rotated it around the central axis of the spinner with 120°, and I done this twice. Just like this:
  • Create the branch around the centrale axis
  • Once it is done, copy/paste it
  • Select the object, then click move (or M)
  • In "move type", select "rotate"
  • Select the central axis of the spinner
  • Add 120°
  • Done
  • Repeat for the third branch
  • Then select the 3 objects and combine them!
And here are the detailed steps, related to the images:
  1. First I have made the central ring that will receive the bearing. I made it with a diameter of 22.5mm, the walls have a width of 3.75mm and the height is 7mm.
  2. Then I have made the tube that we use in centrifuge. Basically they are 40mm long and they have a diameter of 10.5mm. I have placed it in the center of the first ring with half of the tube above, and half below. This is very important because the tube has to pass correctly in your hand when the spinner is spinning! I have also tilted it for the same reasons, and also because it is much more convenient to centrifuge like this. I have moved it 40mm away from the center. To finish, I have create a ring around the tube, with 2mm width.
  3. Then I have create a plan passing through both ring axis. And in the sketch mode I have projected the rings, and connected them to create nice round shapes using circles. To finish the connexion I have extruded this sketch of 2.5mm on each side of the plan and I made sure there were no parts protruding into the rings.
  4. Here I have used the copy/paste/rotate technique to create 3 branches.
  5. Then on a new horizontal plan I have create a line of 30mm from the axis of the central ring to one of the small rings outside. I have rotated it up to 60°. Then I have created a similar ring as the central one. And again used the copy/paste/rotate technique.
  6. To connect all the rings together I have created a horizontal plan, and designed some circles between all the branches created above. And I have extruded these parts.
  7. To finish, I have used the fillet tool on all the edges I wanted to fillet, and used 2mm.
Step 4: The Bearing Caps
I have used caps that I found on thingiverse here. And I have added 3 different designs of objects you can find in many labs:
I will not go in the details in this step. Basically I have open the caps file as mesh, then design in "sketch mode", and I have combined the design with the cap.
Also you can notice on the pictures that I have printed them with 2 colours. Actually I have printed the first part in green, then paused my 3D printer, changed the filament to black, and finished the object. You can pause your printer manually when it reaches the good layer, but it means you have to stay close to you printer which might be a bit long... So I have used the following automatic technique (it will work on any printer using Marlin firmware):
  1. Go to your slicer and check the different layers and where you want to change the filament.
  2. Export the .gcode as usual
  3. Then open your .gcode with a text editor
  4. Find the layer you want (ctrl+F for windows or cmd+F for mac). For example, type "layer:52".
  5. Then type "M600", which is a command that pauses your printer so you can change your filament. And save it.
  6. Launch your printer with this .gcode.
  7. Change your filament when the printer is paused.
  8. Then continue your print.
Step 5: Adapters for Smaller Tubes
I made this spinner for 2mL and 1.5mL tubes... But if you want to centrifuge 500 microL tubes, you can use this adapters!
Step 6: Files and More
Here you can download the file to print the fidget spinner.
Don't forget to visit my thingiverse account here!
And you can also go check my entry for the fidget spinner contest here.
Feel free to comment, I'd be glad to hear what you think about it, if you want to try it!
Explore Science Contest 2017
Runner Up in the
Unusual Uses Challenge 2017
Runner Up in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    24 Discussions
    FionaM56
    1 year ago
    Really nice idea! One question: what would you estimate the rpm/rcf of this centrifuge to be? Thanks!
    MatlekFionaM56
    Reply 1 year ago
    Thanks a lot! With regular metallic bearing, I would say that it spins as fast as regular fidget spinners. On the internet, you can find a lot of values, but I think the most reliable one is 3750 rpm. Here is the video, and the method he uses sounds quite relevant.
    mchau2
    1 year ago
    great idea!! that ball bearing works very well for your purpose!!
    gocivici
    1 year ago
    Woah! this is the most creative use of a fidget spinner I've seen so far. It actually solves a problem. Bravo!
    It would be awesome if the hands holding the tubes had hinges on it, this way the tubes would rise while spinning like on an actual centrifuge!
    Matlekgocivici
    Reply 1 year ago
    Thank you for your nice comment! On some centrifuges the tubes are kept with a fixed angle of 45° (second photo in step 1), but on some others there are some hinges as you said (third photo in step 1). But this is a good idea, I might try to design it adding hinges if some others are interested!
    Jonathanrjpereira
    1 year ago
    How did you make a GIF for this Instructable? Which website did you use & what were the settings?
    MatlekJonathanrjpereira
    Reply 1 year ago
    I use an app called "GIFBewery" on mac. It is an old version, but I think it is still available for free on the App Store. The most important setting is the size, I set it to 300px in height. If it is bigger it might be too long to open on the webpage. Then I play with the other parameters: I crop the gif, I change the duration, the number of fps, etc... GIFBewery is quite good for that.
    But on my earlier articles I have used a website called makeagif.com, it is easy to use, but there is the logo "MakeAGIF.com" on the bottom right corner, and it is ugly. You can see what the gifs look like here: https://www.instructables.com/id/Solar-System-Lamp/
    I hope it helped!
    eigengrad
    1 year ago
    It looks like the size bearings you printed was 22.5 rather than 22 mm- is the size difference small enough that the commercial 22 mm bearings would work, or should I re-size it to 22 mm interior diameter?
    Matlekeigengrad
    Reply 1 year ago
    You can find the files in step 6!
    Matlekeigengrad
    Reply 1 year ago
    The bearings I have printed have a diameter of 22mm too. Actually I have set the hole for the bearing at 22.5mm so there is a small offset of .25mm all around the bearing and it can fits perfectly (and it fits perfectly for 3D printed bearings). However I never tried with commercial 22mm bearings...
    In order to check this, I have designed 2 small rings of 22mm and 22.5mm of diameter. If you own a 3D printer you can print them (so it is less time and PLA consuming than printing the whole spinner), and try each rings to see which one fits best.
    Let me know which size is the best for you bearings. And feel free to post some pictures of the spinner if you print it!
    Goldberry88
    1 year ago
    I made it =D
    But unfortunately, my hands are smaller than yours,and the eppjes keep hitting my hand, making it useless.. Now thinking of adding a shaft to the spinner so I can keep my fingers apart further. This will make the gap formed by my hand bigger =)
    Or a shaft (pen is working well already) where it can rest on top off
    MatlekGoldberry88
    Reply 1 year ago
    BTW the files are available in step 6, see "BearingCapLong...".
    MatlekGoldberry88
    Reply 1 year ago
    Hi, I am glad you made it :)! Did you use the bearing cap on the central bearing? It might help if your hand is too small, because you will have a small offset. If it still hits your hand, you can try the following files: I have remade the bearing caps with 1cm offset. I hope it will work better! And feel free to upload some images, I'd be glad to see it!
    Matlek
    Reply 1 year ago
    Hi Waren, thanks for the vote and for referring to this in your article!
    agis68
    1 year ago
    imaging this with a cheap PWM controller and perfect bearings.....You smash it!!!! Voted the idea and the design
    inconceivable1
    1 year ago
    wow thats absolutly genous plus it looks awesome! too bad it doesnt spin long
    Matlekinconceivable1
    Reply 1 year ago
    Thank you! Actually it doesn't spin long because I have used plastic bearings. The balls are not completely round because of the printer resolution, and problems during printing. But if you use steel bearings it should spin as a normal spinner!
