Industrial Looking Lamp From Washing Machine Parts and Palettes
15,987
115
31
About: Random creative stuff. Strong weakness for Upcycling, Open Source Hardware / Software and Industrial Vintage Design.
I had a non-repairable washing machine and wanted to reuse some parts. Since I lacked a clever lamp for evening chilling, the goal of the project was quite clear. " What was used to clean the laundry should illuminate the room in the future ... "
With the help of some wood from disposable pallets and some other parts this became a rather handsome piece. : D
Step 1: Materials and Tools
Material:
Washing machine drum and bearing cross
5 Beams of disposable palettes 34.06 x 3.94 x1.97 (LxWxT)
17 Wood screws ~ 2.76 (L)
3 Stick screws ~ 2.36 (L)
3 Stick screws ~ 4.72 (L)
9 nuts (suittable to stick screws)
3 washers (suitable to stick screws)
1 conduit 53.15 x 0.79 (LxØ)
3 pipe clamps (suitable for conduit and stickscrews)
1 Lamp socket with the matching threaded tube
1 power cable with switch
1 Light bulb
Tools:
Pencil and folding rule
Wood saw
Hammer
Drilling machine
Cutting grinder
Wrenches
Step 2: The Pole
The beams were separated from the pallets and the protruding nails removed or completely hammered. They were then screwed offset with each other and sawned to a complete lenght of about 57.09 inch.
I then drilled three holes (top, middle and bottom) for the stick screws, which i then fastened. To these I could now fasten the pipe clamps together with the empty pipe for the power cable.
Step 3: The Foot
First I removed the axis of the bearing cross and drilled six holes for fastening to the pole. From the remaining wood I cut three blocks of the same size. I fastened them to the holes of the old suspension with stick screws and some nuts.
This gives the whole thing a safe stand, the floor will be spared and taring is also possible with uneven ground.
Step 4: The Shade
The pole needs to be adapted to the drum, this was a very tricky part for me... I filled cavities with nuts and washers. :x
I drilled obliquely upwards above the empty tube and in the middle at the top a hole. Now i could guid the power cable through the canal thus formed and attach the drum to the pole.
Finally I connected the power cable to the lamp socket which i then with the matching threaded tube to the shade attached.
As light bulb I have selected a head-mirrored, which fits very well to the lamp.
Step 5: Finish
Especially surprised me the great light pattern on the walls. :)
I hope I could inspire you with this instructable and we will see more washing machine lamps in the future.
P.S. You could of course still remove the lime from the foot and lamp, but I like this patina. : D
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
31 Discussions
ashburn orange
2 years ago
Two thumbs UP ! The use of the washing drum gives a GREAT lighting effect !
WOW ! Pure genius design/build
smashing
2 years ago
Great idea. Next time use the pallets to build a box beam and run the wire through the center. No conduit needed and a nice clean look.
Schabenstolzsmashing
Reply 2 years ago
Thank you. It was my intention to use a conduit outside for the power cable. But you're right, it would be look much cleaner. This is a good tip for people who want to rebuild this.
kenthehats
2 years ago
Cool buddy never even considered using the drum I'm going to try this but adding a small motor to give a lighthouse effect. .i made a rip saw using the mot and dumped the rest tut tut. .but ty for the idea
Schabenstolzkenthehats
Reply 2 years ago
Thanks! Hehe, a lighthouse effect would be very interessting to see. :D I never seen such a saw before, but found a instructable here about it. You're welcome.
KathyS141
2 years ago
very cool, i'm gonna make mine a hanging lamp to use outside...
PhilS43
2 years ago
Some lamp!
I use my old drum as a planter for potatoes.
I was going to use it as an incinerator, but it looked too good.
Might make a decent water filter for big debris - I always look at stuff and think "what can I use that for?", before chucking. Tin cans for storing nails etc.
SchabenstolzPhilS43
Reply 2 years ago
Thanks!
Using the drum as a planter for potatoes is a good idea, especialy if you only got a small balcony.
Yes, its a very neat piece of metall "scrap", stainless steel and many possibilities of use. A water filter would be great, maybe to free various things(stones, vegetables etc.) from dirt.
I also try to give a new purpose to broken or unneeded things. Keep going :)
BettinaS7
2 years ago
Fabulous! I love those drums and already've made the fire pit. Funnily enough my project for the next drum is a hanging lamp and you've inspired me. Great work and instructable too
SchabenstolzBettinaS7
Reply 2 years ago
Yay, a hanging lamp would be look very good. Maybe with just one thicker power cable and the bearing cross as baldachin *thinking out loud*. I hope to see a instructable about your creation. :D Thank you very much.
lkseegers
2 years ago
I absolutely love the inspiration you applied in re-purposing the washing machine this way. Keep up at your great way of thinking! A great conversation piece as well. True eco-art in my oppinion... BRAVO!!!
Schabenstolzlkseegers
Reply 2 years ago
Wow, thank you for the very nice and motivating words! I am very happy that you like the piece.
Reggiedog
2 years ago
Very clever. I love the light pattern display on the wall. Function and beauty saved from the dump. Huge two thumbs up!!!
Meglymoo87
2 years ago
Could you drill a hole down the wooden post to insert the pole instead of it being on the outside? Just curious.
Great job! :)
Meglymoo87Meglymoo87
Reply 2 years ago
But I understand you did it from pallet wood. Maybe hollowing out half a circle on one length of pallet pieces and the second half of the circle on the other length of pallet pieces instead?
