Large Wire Bender
29,386
356
21
About: Hi! You can call me Matt. I'm a problem solver with interests in many fields. I will try to post some of my more interesting projects when I have the time.
I needed to consistently bend 1/4" steel round bar which proved to be quite difficult without a bender. As a result of this need, a large wire bender was built. The following is the construction process of the wire bender using scrap material found around the shop.
Supplies:
Step 1: Materials and Tools
Materials:
  • (2ft) 1X1" 11GA steel square tube
  • (6in) 1/2" round steel rod
  • (3x4") 6/8" steel plate
  • 3/4"-10X2" bolt
  • 3/4"-10 uncoated nut
  • 3/4" washer stack as wire clamp*** (did not have any to try, used Vise-Grips instead)
Tools:
  • Drill press (1/2"and smaller pilot drill bits)
  • Angle grinder with cutoff and grinding disk
  • Welder
  • Hammer and center punch
  • Bench vise to hold the bender
***The original plan was to use a stack of washers (>4) on the 3/4" bolt with the top washer welded to the bolt head and the bottom washer welded to the nut. The wire could then be clamped between the washers when the bolt is tightened into the nut. I could not find enough washers so the Vise-Grips was used to clamp the wire.***
Step 2: Bending Arm
  • Cut square tube to 2ft
  • Mark center of tube 1/2" and 1 3/8" from one end
  • Use center punch on marks
  • Drill through tube using pilot drill bit
  • Drill through tube using 1/2" drill bit
Step 3: Drill Baseplate
  • Drill pilot hole centered with 1" offset from 3" end
  • Drill 1/2" through-hole
Step 4: Add Pivot Rod to Baseplate
  • Chamfer end of 1/2" rod
  • Insert rod into baseplate and weld end
  • Slide bending arm over rod and cut rod leaving ~1" extending above bending arm
Step 5: Add Nut
  • Position nut centered with 1" offset from other 3" end
  • Weld around base of nut
Step 6: Add Bar to Bending Arm
  • Grind small chamfer on end of 1/2" bar
  • Insert bar flush in second hole from end
  • Weld around bar end
  • Slide bending arm onto base
  • Cut 1/2" bar to same length as baseplate bar
At this point clean up any sharp edges and problems with the angle grinder and insert the 3/4" bolt into the nut.
Step 7: Use
  • Hold the bender in a bench vise
  • Insert the bar using the contact point with the pivot as a measuring datum
  • Secure the bar to the 3/4" bolt using a Vise-Grips or tighten between stack of washers on bolt (This step is not critical but the bar will shift while bending)
  • Pull bending arm until desired angle is reached
(Several tries were needed to find a method for consistent bends)
Enjoy!
  • IoT Challenge
    IoT Challenge
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
21 Discussions
I AM AGREE WITH DANIELON ESTRADA, BUT YOUR PROJECT IS SO GREAT FOR ANY OTHER APPLICATIONS AND YOUR INVENTION MAKES EASIER TO FOLD OTHER FERROUS MATERIALS TO MAKE ANY OTHER SHAPES MOVING SOME CENTIMETERS THE PULLING AND PIVOT.... CONGRATULATIONS!!!! NICE JOB AND EXCELLENT WORK!!!!
Danielon estrada
2 years ago
Creo que si añades otro perno un poco atrás del mismo que está deteniendo el tubo este le servirá como ancla evitará que tengas que poner una mordaza pues al ponerla detiene el desplazamiento del mismo solo una observación pero grandioso proyecto, saludos!!!
271828-Danielon estrada
Reply 2 years ago
I will have to think about the second pin the next time I use it, thank you!
OctavioB
3 years ago
Good job ~ I'm making one and I needed the basic principle, by parts. Excellent slim design, the simpler, the better, Less parts to make and guess (figure) into the works.
Ralphxyz
3 years ago
thanks, close to what I need.
I need to make multiple 360° bends.
A spring bend but not with spring steel just mild steel.
Some thought with what you have done will get me there.
_soapy_Ralphxyz
Reply 3 years ago
You might do better with a roller system if you want hoops.
Ralphxyz_soapy_
Reply 3 years ago
Do you have a picture? I am not sure what you mean.
But thanks for the reply!!
_soapy_
3 years ago
Nice job.
This is probably actually better than the powered one I've got. Certainly likely to be more controllable!
sdzucev
3 years ago
Отличная работа!
Единственно, мне
кажется некоторые рычаги слишком длинные, например на оси вращения). И
не совсем понятна роль болта, почему именно болт?
Great job!
The
only thing it seems to me some leverage too long, for example on the axis
of rotation). And don't quite understand the role of bolt, why bolt?
271828-sdzucev
Reply 3 years ago
Thanks!
The longer bending arm allows for better control of the bend with less force. Chose a length that works for you.
The bolt was designed to have a stack of washers that would clamp the wire during bends. I did not have enough washers at the time.
OctavioB
3 years ago
fantástic project i want a bender so bad but im tight and other tools take my budget away. cool! to tha batwelding cave!
techie66
3 years ago
Did not made it yet, but yes this has a lot of potential also for flat material like tie-fasteners, love it !
николайм
3 years ago
в кузне очень часто таким инструментом пользовался. И сейчас используем подобный инструмент, только не установленный на основу
Aussie58
3 years ago
Brilliant. Love it. A project I can get my high school students onto designing and making.
Any reason why you couldn't just put a nut on either side of the base plate for the 3/4" nut to save welding it? Not a criticism just an inquiry. Or maybe just plug weld a piece of 3/4" rod into place from under the baseplate.
