Laser Cut Perpetual Flip Calendar
1,451
16
5
About: Having fun creating more or less stupid stuff
This is my take on a perpetual flip calendar made on a laser cutter.
I've been inpired by this video :
https://youtu.be/VJ1Hv339CgQ
Step 1: Material
Here is the list of materials used:
3mm thick MDF (should be a very smooth one so it slips properly)
6mm thick MDF
12 magnets 6mm radius 2mm thick
1cmx3mm magnets
4 nails
varnish
The magnets are hidden and used so the two flipping parts stay properly up.
I cut everything using my Glowforge. I used the default pressets for "Medium Cardboard" and "Thick Cardboard" materials. Engraving params are detailed later.
If you want your own use my rerferal link :)
Step 2: Laser Cutting
Download the SVG files for laser cutting.
I used 3mm wood for the flipping parts and 6mm for the other parts.
The 3mm wood must be very smooth so the pieces slip properly against each other !
On the "mounting parts" file (the 3rd) there are big black areas. These should be engraved deeply, these are actually places for the magnets. So, it really depends on the magnets you use, but in my case i had to get at least 2mm deep for the rotating parts and 3mm deep for the pedestal parts.
I personally used 3 passes with 100% power and speed ok my Glowforge.
The squares for the dates (4th image) should be engraved both sides.
I used maximum speed at 60% power.m for engraving.
The "18" should be behind the "3", the "20" behind the "5", "Aug" behind "Jan" etc.. The SVG is actually made so you just have to engrave the red values at the exact same place you engraved the black values but on the other side. Just cut the squares and engrave the black values on the first pass, then flip the pieces vertically, and engrave the red values.
Step 3: Assembly
Sadly, i made no pictures whatsoever of the assembly but it should be easy to figure it out by yourself.
The only thing to be careful about is to put the squares in the right order inside the flipping parts.
Make a column of the following pieces with the 1 on top:
1, 3, 5, 7, 9, 11, 13
A second column with 2 on top :
2, 4, 6, 8, 10, 12
Then just put the first column with the 1 visible on one hole, careful to put it the right way. Do the same with the 2 visible from the other hole. Close the box and things should be good !
The months should be ordered this way, "Jan" on top :
Jan, Mar, May, Jul, Sep
And this way for the second column, "Aug" on top :
Feb, Apr, Jun, Aug
And same as before, "Jan" should be in front of one hole and "Feb" in front of the other.
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    5 Discussions
    hogenkamp
    9 months ago
    Mega thanks for posting the cut files; D. I cannot wait to get this one started.
    Dursshogenkamp
    Reply 9 months ago
    You're welcome ! Can't wait to see how it goes for you ;)
    Remember the wood must be as smooth as possible so it slips properly inside :)
    hogenkamp
    10 months ago on Step 1
    I really love this Great work. I did not see the SVG files. Were they posted?
    Dursshogenkamp
    Reply 9 months ago
    Good catch :D
    Added !
    Thank you :)
    Penolopy Bulnick
    10 months ago
    Such a fun calendar design :) It's crazy how simple the inside is!
