Laser Cut Plinko Game
7,547
149
7
About: For more about my costumes, crafts and general craziness, check out my blog: http://modmischief.blogspot.com/
My partner and I built this Plinko game for a charity golf tournament. Players in the tournament had a chance to play for an advantage, like a free mulligan or moving their ball closer to the hole. Beyond the golf course, our son really enjoys watching the puck plink down the board, and we have plans to turn it into a great drinking game for our next party.
If you have access to a laser cutter this is a fun and simple project to put together.
Supplies:
Step 1: Materials and Design
For this project you'll need:
  • 4 sheets of ¼" plywood, cut to 20" x 30"
  • Acrylic sheet, 20" x 30"
  • ⅜" diameter wood dowel
  • Wood glue and clamps
  • Saw for cutting dowels
  • Sandpaper
  • Access to a laser cutter
  • Design files (board + stand)
The Plinko board and stand were designed in CorelDRAW. The laser cutter at our local makerspace has a 20" by 32" bed, so the pieces were all designed to fit within those dimensions.
Step 2: Laser Cutting
We used the Epilog laser cutter at YuKonstruct to cut out all the flat pieces for this project.
Lasers are awesome.
Step 3: Making the Puck
We went with a hollow puck since it makes a better sound plinking down the board.
The circles and rings are cut out of the birch plywood and then glued together. Once the glue is dry, sand all the edges smooth.
Step 4: Adding the Dowels
Cut the dowel into 1½" lengths and sand the edges.
Put the backboard with the holes over a solid piece of plywood the same size and glue them together. Use clamps to keep everything in place.
Add a dab of glue and then insert a dowel into each hole. A rubber mallet is helpful for getting the dowels in place.
Put the edge piece on top and secure the dowels with more glue.
The four dowels that hold up the acrylic cover are slightly longer than the rest. The length you cut them should be determined by the thickness of your acrylic sheet. If the acrylic is ¼" thick, make those dowel sections at least ¼" longer than the rest.
The acrylic sheet sits on the front to keep the puck from bouncing out but is not glued in place so it is easy to remove in the unlikely event that the puck gets stuck.
Step 5: Assembling the Stand
The stand pieces slot together to make it easy to assemble and take part.
When not in use, the pieces can be packed flat so they don't take up much space.
Step 6: Add Prize Labels
Since we were planning on reusing the Plinko board at future non-golf-related events, we added temporary prize labels made on a label maker.
You could etch numbers or prize categories on the board when laser cutting it, if you would like a more permanent option.
You can also paint or otherwise decorate your board however you like.
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    7 Discussions
    StanK10
    1 year ago
    First...Love this.
    2 question(s)
    1) In the CDR file, I don't see holes cut for the dowels to be inserted (but see the holes in the pictures) - how do you get the dowels equidistant to each other?
    2) my laser bed is only 24" x 12". If I use the same materials, do I need to make additional changes to the plinko board (adjusting for material size) and does the stand need to be modified if the board is smaller?
    Sorry for the nub questions but I'm not much of a tweaker and a bit new to lasering still.
    ModMischiefStanK10
    Reply 1 year ago
    1. There are multiple layers in the CDR file. To see the holes for the dowels you'll need to turn on the "Backboard" layer (the dowels don't go through the acrylic except for the 4 pegs that hold the acrylic cover on).
    2. You will need to shrink the plinko board to fit your smaller laser cutter. Be careful when you do so not to shrink the holes for the dowels (unless you are using smaller dowels). The stand will need to the modified to fit the new dimensions of the board, but the stand is optional and you could skip making it and just lean your board against a wall.
    JodieD8
    2 years ago
    Are PDF versions available of the pattern to cut with laser. When I click on Plinko Cut.cdr or Plinko.cdr I only get a copy of instructions. Same for PDF download - instructions only.
    ModMischiefJodieD8
    Reply 2 years ago
    The cut files are currently CorelDRAW .cdr files.
    reginaann
    2 years ago
    I love this, so great - Plinko was always my fav game in TPIR. Well done, thanks for sharing!!
    KrazyK4
    2 years ago
    It's like Tipping Point! Ace?
    wold630
    2 years ago
    OMG! This is just fabulous!!
