Laser Engrave Metal
26,038
121
22
About: Welcome to my profile. My name is Matthias and I am BrittLiv's boyfriend. She also uses this account to post some quick instructabes that she deems too simple for her main account.
Being able to engrave metal was one of the main reasons, why I got a laser cutter.
In this instructable I am going to show you some of my experiences.
Please share your results and experiences in the comments, I would love to learn more about engraving metals.
A word of warning: The process of engraving metal after applying an agent to the surface is patented. So please inform yourself, before doing so commercially.
Step 1: Engraving Stainless Steel
In the picture you can see the different things I tried to engrave stainless steel.
  1. Just the metal
  2. CRC Dry Moly Lube
  3. Weicon MoS2
  4. MoS2 Powder
  5. MoS2 Paste
  6. markSolid 114
In order to use the powder I mixed it with isopropyl alcohol until I had a thick paste an applied it with a disposable brush.
Step 2: Engraving Stainless Steel
As you can see I used different speed and strength setting to see what works best. The first number is the speed and the second the energy percentage. I have a cheap 60 W Chinese CO2 laser and as you can see some of the setting worked really well.
Out of all the metals I tried to engrave, stainless steel definitely worked best. As you can see in the picture out of all the things I tried, CRC Dry Moly Lube and markSolid 114 gave the nicest results.
materialvisibilityscratch resistantalcohol resistant
1. Just the metal(✔)(✔)(✔)
2. CRC Dry Moly Lube ✔✔✔✔✔✔
3. Weicon MoS✔✔✔✔
4. MoS2 Powder✔✔✔✔
5. MoS2 Paste✔✔✔✔
6. markSolid 114✔✔✔✔✔✔
"-": didn't work
"(✔)": kind of worked
"✔": worked well
"✔✔": worked really well
Step 3: Engraving Copper
Most of the engraving agents I tired didn't work. Only markSolid 114 gave some nice results. I was even able to polish the results. Sadly the engraving wasn't really scratch resistant.
1. Just the metal---
2. CRC Dry Moly Lube (✔)--
3. Weicon MoS---
4. MoS2 Powder---
5. MoS2 Paste---
6. markSolid 114✔✔(✔)(✔)
Step 4: Engraving Aluminium
Once again most of the engraving agents didn't work. Only after using markSolid 114 the engraving was still visible. Sadly the result was not at all scratch resistant and was easily removed with alcohol. Overall you can definitely say that the cheap alternatives aren't working for copper and aluminium. Btw. covering the engraving with sealer helped a lot with the result.
2. CRC Dry Moly Lube ---
3. Weicon MoS---
4. MoS2 Powder---
5. MoS2 Paste---
6. markSolid 114--
Step 5: Engraving a Hip Flask
Lately I have been engraving a lot of hip flasks. Due to them being out of stainless steel, it works really well.
Start by cleaning it with isopropyl alcohol and mark your focus point. Afterwards place it into the laser, as well as something that helps you to later find the position. Focusing is a bit tricky, due to the bend surface. I focused between the start point and highest point and it worked really well.
As you can see in the picture I used CRC Dry Moly Lube. Cover the surface with it and let it dry for about 5 minutes. Afterwards you can place it back into the laser and start engraving. To remove the residue you can use isopropyl alcohol.
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    22 Discussions
    soceraso
    Question 6 months ago
    Is the MarkSolid114 conductive? I wonder if this process could be used to make soldermask for PCBs...
    ElectroFrank
    1 year ago
    I would guess that aluminium and copper will be difficult because they have high heat conductivity, the heat being dissipated (as in a heat sink) before it burns away (vapourises ?) the metal. So metals with lower heat conductivity (and lower melting/boiling points) will probably work best.
    socerasoElectroFrank
    Reply 6 months ago
    that seems mostly right except that its probably pulling heat away from the spray-on compound too quickly for the compound to harden/adhere to the metal. The spray-on compounds he's using are bonding to the metal with the laser energy. The metal's not vaporizing in that case
    jalesi1978
    Question 1 year ago
    What CO2 laser do you have? Or what can you recommend for stainless steel.
    WyldStyl3
    1 year ago
    I've been looking for a cheap laser to mark stainless and titanium. Nicely done! Do you know if you are able to mark titanium?
    k8e
    1 year ago
    - Please explain the 'patented' comment - regarding the commercial work - I know MANY people are doing this - so, What is the warning for specifically? Like this - thanks for the tutorial.
    MarioB137
    1 year ago
    Very nice work and quite a scientific aproach! I tried the Weicon MOS spray too, but the result were as underwhelming as in your case. Might pick up the CRC lube. Thank you!
    Another thing I want to try is covering the steel with paint or spray plastic and burning it off with the engraver, then etching with vinegar and an adjustable power supply. After that just removing the plastic/laquer with paint thinner. Should give a nice deep etch where the laser removed the masking. :)
    EwgeniyK
    1 year ago
    Guys, try heat-conductive paste applied to the CPU heatsink computers. In Russia this КТП-8. On any metal well. Apply a thin layer.
    brichtlEwgeniyK
    Reply 1 year ago
    Thanks a lot for the tip! I am definitely going to try that.
    levascEwgeniyK
    Reply 1 year ago
    Спасибо за инфу!
    EwgeniyKlevasc
    Reply 1 year ago
    Пожалуйста. Не моя идея, один добрый человек, года 3-4 назад, поделился на форуме mir-cnc.ru
    fred_dot_u
    1 year ago
    It's amazing to consider that there's one other marking compound that should be used for stainless steel. It's grey poupon mustard!
    https://youtu.be/B60nXwhK9gk
    brichtlfred_dot_u
    Reply 1 year ago
    Very interesting, thanks for posting that out
    jpfalt
    1 year ago
    What power levels and travel speeds did you use for the engraving?
    brichtljpfalt
    Reply 1 year ago
    diverdale
    1 year ago
    I've been wanting to get/build a laser engraver for sometime now. Just never pulled the trigger mainly due to the lack of the ability to engrave metals. Never looked into why...just figured it was a power thing I suppose (or laziness) Thanks for sharing this. What types of lasers will engrave metals with no added agents? Or do they not exist?
    Nice 'ible,
    Dale
    liquidsandsdiverdale
    Reply 1 year ago
    A fiber laser will engrave metals but is considerably more expensive than a CO2 laser. I have a 100W laser and I too use the CRC Moly Lube spray. The IMark spray is much better but is 6-7 times the cost of the CRC MolyLube. You can't hardly screw up the IMark product. Just do a test sheet and you will likely do just fine. One caution though! Shake up the spray can for at least 2 minutes before using if it has sat for more than a day first or you may have erratic results. There is so much sedimentary material that if it is not mixed well, it sprays out unevenly.
    gm280
    1 year ago
    We own a large bed Universal LASER engraver. But it won't do any metals at all. And that is because the type LASER used. Ours is a CO2 LASER system and therefore doesn't have the proper LASER frequency to do metals. They make dual LASER systems that have a CO2 LASER and another type used for metal engraving. I tried things and the CO2 system merely does nothing to even copper.
