Laser Engraver With Arduino
114,532
1,274
63
This machine is designed to make the laser engrave in wood and opaque plastic, having an Arduino and the GRBL as machine automation basis. The machine axis are just the X and Y axis, which move a laser with power 1w 445nm, and this article aims to provide everything you need to make, without waiving of mechanical and electronic knowledge.
With around 170 euros can make one.
My portuguese blog: www.logicamecatronica.com (like my blog on facebook please)
Step 1: Materials
You will need some material for your machine, in which I produced a list of required material. You will need tools.
Bill of materials:
1x Arduino Uno
1x Motor Jaw Shaft Coupler 5x5mm
1x Laser 1w 445nm (you can choose another, but i recommend max 3w on this cnc)
1x CNC Shield v3.1
1x Laser driver 12v
2x stepper motors Nema 17
1x power supply 12v 5A
1x laser diode 1w 445 nm 5.6mm
1x heatsink 5.6mm laser diode
3x GT2 Timing Pulleys 20 tooth 3m GT2 Timing belt
1x 12v fan cooler
1x 605ZZ ball bearing
12x Pulley Wheels Roller 695ZZ1x 5.6mm TO18 Laser Diode Case
2x stepper motor driver DRV8825
2x limit switches
1x switch power 3D printed pieces
1x plugin 230v cable
1x USB cable (in future we will use Bluetooth)
M5 Nuts
various length of M5 screwdrivers
flexible cable wire for electronics
1x pair of safety glasses Note: Never look directly into the laser, always wear protective glasses, link these glasses are cheap and effective, look directly at the laser runs the risk of blindness and cataracts. http://www.dragonlasers.com/Laser-Safety-Glasses....
On Rat rig:
5x 500mm V-SLOT 2040 – Black
8x OpenBuilds Universal L Brackets (Single)
1x OpenBuilds Tee Nuts (25 Pack)
5x OpenBuilds Tee Nut (1 Unit)
Step 2: Electronics
The wiring diagram of this machine is very simple, just follow the following schedule (the used resistance is 1k ohms)
Step 3: 3D Printed Pieces
Printed pieces in 3D, you'll need a 3D printer or else order from any website online already printed pieces.
http://www.thingiverse.com/thing:819755
This printed pieces are from another user of insctructables (tobias.sobkowiak)
Step 4: Mounting
With this photos you can mount easily your machine.
Step 5: Software
Necessary software (works only on Windows 7 or higher and requires framework 4), I used the CamBam (is paid) and 3DPsender, made by a developer who also made a laser engraver, call 3DPBurner.
GRBL hex file: https://drive.google.com/file/d/0B5Y1gEmSHMjMS1R4RUhsamV3QXc/view?usp=sharing
Xloader to flash Arduino: http://russemotto.com/xloader/XLoader.zip
how flash and setting of GRBL: https://github.com/grbl/grbl/wiki
3DP Burner Send: https://github.com/villamany/3dpBurner-sender/releases
3DP Burner image2code: https://github.com/villamany/3dpBurner-Image2Gcode/releases
CamBam settings: https://dl.dropboxusercontent.com/u/40132197/CamBam%20settings.docx
Step 6: Results
The expected results of the machine will be these.
Download all files here: https://dl.dropboxusercontent.com/u/40132197/M.%20laser.zip
Thank you and i hope that you enjoy :)
Arduino All The Things! Contest
Runner Up in the
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
63 Discussions
Billgabo
7 months ago
Your Laser CNC can cut canvas (the fabric of backpacks) or leather?
Adrian-ClaudiuB
Question 11 months ago on Step 2
hello, what is the role of that 1k rezistor between the wires that comes from cnc shield to laser ttl ? i run some tests and the laser works the same with or without it, obly the resistance mesured with rezistor is like 4.8 v and without 4.99 v. cand you explain to me ? thanks
amccoy9
3 years ago
Why is there a resistor between the positive and negative TTL lines? Won't that short it?
JoãoC7amccoy9
Reply 11 months ago
If you knew what a resistor is you wouldn't ask that question...I hope i know it already... ;)
AlexisC80
2 years ago
Do i need a bigger resistance for a bigger laser? lets say a 10w laser?
JoãoC7AlexisC80
Reply 11 months ago
No, the resistance has nothing to do with the laser size. The resistance is there to limit the current from the Arduino pin. Just to turn on and off the laser.
thanhvietnguyen
1 year ago
Please can you fix the link:
https://dl.dropboxusercontent.com/u/40132197/M.%20laser.zip ?
JoãoC7ToddD56
Reply 11 months ago
You can use GRBL 1.1 and LaserWeb for controlling the laser. And for designing use Inkscape, all free software. ;)
radioman02
1 year ago
I have the Arduino Uno R3. My laser is a 12 volt 500mw(below) on the R3, where do I connect it so the R3 controlls the on and off, the laser has it's own power supply. Thank You for the help
IanK66radioman02
Reply 1 year ago
Hi Radioman02
Did you manage to get the laser module working, please share information.
Regards
Ian UK
radioman02IanK66
Reply 1 year ago
no I still don't. Here is my Arduino CNC Shield. Where do I plug the laser in at??
JoãoC7radioman02
Reply 11 months ago
You should look for the pin that usually controls de spindle. The laser is controlled by the Arduino as if it was a spindle. Your laser module should have a pin where you can connect it to the cnc shield.
GeraldoJ3
1 year ago
relly works?
ClecioJ
1 year ago
Ola consigo usar o march3 como controladora este projeto ou tem um outro soft para usar
K K K
2 years ago
Sir, can I use this part from this site:
http://openbuildspartstore.com/v-slot-linear-rail/
it's very expensive from rat rig
Seanfrance
2 years ago
Great work!! I can't figure out how to get my laser to turn on and off .. same set up as you .. grrr
javajrc
2 years ago
hi mister, can you send me a photo of your datasheet. I don't understand your links between the cnc board and the laser driver....how I can set the motors and the endstops? can you write me pls? cecchini.dan@gmail.com
thanks!!
RobotEyes
2 years ago
Some time ago I built a Laser Engraver with this GearBest Kit.
Unfortunately I have not found a software acceptable and easy to use, so I wrote my own.
My software allows to load a picture and send it to the laser engraver quickly and easily.
My software is written in a generic way for almost all machines with standard GCode firmawre.
At the moment the software is WORK IN PROGRESS currently, in ALPHA testing.
As I needed to modulate the laser power (I have a 5500 mW one) I used GRBL firmware version 0.9 (other versions are ON / OFF, 0.9 is PWM)
Here the Robot Laser Project page : http://www.robot-eyes.com/en/RobotLaser/
I will update soon the page (for now very rough).
Please send an email at robotlaser@robot-eyes.com with your opinion, thanks.
okuzster
2 years ago
hey, let's say i have a 3d printer and want to replace it's print-head with a laser diode. what i need beside the diode?
