Laser Etched Cookies
15,670
76
16
About: After a fun time making projects for the Instructables design team, I'm now helping to start the robot uprising.
Everyone loves cookies and lasers, so why not combine the two? This recipe is for very basic vanilla sugar cookies that I then etched using a laser cutter, mostly to see what would happen (and how they would taste).
Ingredients, in order of use:
1 cup unsalted butter, soft
1 cup sugar
1 egg
1 Tbsp milk
1 tsp vanilla extract (or other flavorings/extracts - citrus zest would work well)
3/4 tsp baking powder
1/4 tsp salt
3 cups flour
powdered sugar for rolling
sugar for dipping
Supplies:
Step 1: Blend Butter and Sugar
Combine the butter and sugar in a bowl and mix until smooth. Ideally, you should use a mixer but a spoon and some elbow grease will work as well.
Step 2: Add Liquids
Mix in the egg, vanilla, and milk.
Step 3: Add Powders
Stir the salt and baking powder into the mixture and distribute evenly.
Step 4: Add Flour
Half a cup at a time, slowly mix in the flour until you get a homogeneous dough.
Step 5: Chill
Turn the dough out onto plastic wrap and chill into the fridge for about one hour, or until firm but not hard.
Step 6: Roll the Dough
Working with half of the dough at a time, roll it out to about a 1/4" thickness. I used scraps of plywood wrapped in plastic wrap to make sure my cookies were perfectly level at 1/4" (I wanted them to be as uniform as possible for laser etching). You can do something similar with cardboard or rubber bands wrapped around the rolling pin if you don't have access to plywood.
Step 7: Cut the Cookies
I cut my cookies into 2 1/4" and 3" rounds for testing. I also dipped some of them into white sugar before baking, in hopes that the sugar would caramelize from the laser (it also just happens to taste good).
Step 8: Bake
Bake the cookies at 375 deg F for about 10 minutes, or until the bottoms are just beginning to brown.
Step 9: Design the Patterns
While the cookies are cooling, create your design for the etching. I made a layout sheet of 2" circles for my smaller cookies, and made sure that the images were centered over the circles. The circles and the images were on different layers, so I could turn the guides off when etching.
Step 10: Etch
First, clean the laser cutter. I found that it smelled a little after cutting, and that wiping down the bed, the rail that the laser slides along, and the laser housing helped reduce the smell. Put down a printout of the layout sheet you created and cover it with a layer of parchment paper (you should be able to see the layout lines through the parchment paper). Place the cookies inside the guidelines and focus the laser on a cookie. Finally, etch the design using the cutter's "raster" feature.
Step 11: Etching Results
I tried a variety of settings and found that I could never get the etching quite as dark as I wanted. In the end, I settled on speed at 100%, power at 75%, and raster settings of 400 DPI. I also experimented a bit with sugar vs no sugar on the top of the cookies. The plain cookies had better resolution, but the sugar-coated cookies tasted significantly better.
Step 12: Admire/Eat
As a safety note, food that has been laser etched in the cutter I used is no longer considered "food safe" and probably shouldn't be eaten (hence "admire"). That being said, the cookies took on a bit of a chemical/burned taste which I found kind of awful. The sugar-dipped cookies had less of an aftertaste than the plain cookies. However, other people who tried them said that they barely noticed the taste. In any case, the non-etched cookies are pretty good too.
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
16 Discussions
thesnowtheriver
4 years ago on Step 12
it's a great idea and visually really interesting. but if it's not food safe, i cannot honestly say i will try this recipe.
The cookie recipe is fine - it's just standard sugar cookies. The laser etching is also technically food safe (you aren't actually touching the cookie with the machine). The problem is that food that has been in a machine shop is generally not considered food-safe, since it can potentially come into contact with various chemicals (cutting fluid, glue, etc).
Raitis
4 years ago on Introduction
Umm, if laser etches taste a little off, would it be possible to CNC the graphic into cookies?
BeaconsfieldRaitis
Reply 4 years ago on Introduction
Probably not - this cookie would crumble rather than chip like wood/metal does. A sturdier/denser cookie might be ok, although you wouldn't have nearly the same resolution.
heckkitty
Yeah, I tried laser etching cookies, and this is not a good project. The burnt taste is so bad that it completely negates the point of it being a cookie if you can't eat it! I ended up just going with custom cookie cut-outs, which sadly don't have the same resolution.
thesnowtheriver
Very nice:) I use 4 long paint stirring sticks (2 glued together) to make my 1/4 inch thingys . I hate to get technical on you:) They are free at the paint or hardware store and are the ones used for the 5 gallon pails of paint. They are longer than the regular paint sticks. Just ask for them and promise them some cookies:) Love the cookie recipe, too
Orngrimm
4 years ago
cool idea! i think if you print a skeleton of a dinosaur on the cookie, it would look like a round slab of stone with a skeleton embedded... ;)
lime3D
4 years ago
I tried making personalized gingerbread men by cutting the shape out of graham crackers with the laser, the etching photos of people's faces.
They looked really cool, but completely inedible. I couldn't even stand to smell them!
I made a few pieces of Jesus toast, and they came out a little better. My guess is the sugar burns too much.
kmargie25
4 years ago
What a cool idea!
doodlecraft
They are cool...almost fossil like! Too much work not to eat them! :)
