Laser Galvo - Arduino Controlled
27,221
136
20
Arduino controlled laser galvo. The servo driven mirrors steer the UV laser leaving a phosphorescent trail on the glow-in-the-dark vinyl sheet.
Originally posted on notes.robives.com
Step 1:
Starting with a sheet of luminous vinyl from eBay and a UV laser pointer. Waving the laser pointer round on the vinyl leaves a persistent glowing trace, just like an old style cathode ray tube. Fun, but even better if we can computer control the laser beam!
I’ve come up with a hardware platform that I hope will let me start simple but then experiment with more complex ideas.
Step 2:
I’m using off the shelf servos driven by an Arduino to steer the beam from the laser.
There are two servos, one for the x axis, one for the y. I’ve attached a small circular mirror tile to the servo.
Step 3:
This stand is made from 3mm laser cut ply – there is a pdf of the parts attached - glue the pieces together using PVA glue.
Step 4:
The servos are clamped in place rather than gluing then to make it easy to make small adjustments. These are cheap off the shelf clamps from Wilkos in the UK
Step 5:
All the parts fit together like this:
Step 6:
…and the servos are connected to the Arduino board. I’ve used pins 9 &10 for the servo control lines.
The code for the arduino is attached
Step 7:
Here’s the code in action.
Next step, I think I’ll have a go at a simple raster display.
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    20 Discussions
    Johenix
    3 years ago
    You don't need servos. Just put a boron super magnet in the center of the mirror and hang the mirror and magnet by a two axis gimbal using nylon monofilament sewing thread inside a three axis Helmholtz Coil volume.
    A Helmholtz Coil is two identical coils, in series, spaced a distance apart equal to their radii. The coils produce a uniform magnetic field in the space between them and can cancel out the Earth's magnetic field. Vary the Helmholtz coil current and make the mirror dance.
    DrStein99Johenix
    Reply 3 years ago
    P.S. - With a quick Amazon search, I can buy a 1-axis Helmholtz coil for a thrifty $400. Not something an average hobby experimenter plays with for a toy. If anyone owns these coils, I'm sure they're probably also using something bigger then a dollar-store laser diode pointer.
    NoPinkyJohenix
    Reply 3 years ago
    You have link to a more detailed description or visualization to the mentioned setup? Thanks.
    JohenixNoPinky
    Reply 3 years ago
    Some years ago "Scientific American"'s Amateur Scientist series had an earth field magnitometer (I know the spelling is wrong) that used a Neodymium Iron Boron magnet to measure changes in the Earth's magnetic field. The magnet was glued to a mirror made from a microscope slide cover glass and mounted on a horizontal nylon monofilament thread mounted on a 'U' shaped support that hung from an other nylon thread. The Helmholtz Coils nulled out the Earth magnetic field so that only changes in the field would move the magnet and mirror. A laser pointer was reflected off the mirror and on to a scale so that changes could be read.
    DrStein99Johenix
    Reply 3 years ago
    The Helmhotz coils are interesting. thanks for mentioning that. I was looking for a way to steer a laser beam for raster and vectoring images. It would take a bit of effort to calibrate the size of the magnet, center the mirror & string with the array of current drivers on that field. The software to drive the field is complicated enough just to angle x,y precisely - and has to factor corrective signal for the inertia of the magnet/mirror on rapid movements.
    artmezJohenix
    Reply 3 years ago
    I found that article here:
    https://metodosgeofisicos.files.wordpress.com/2007/04/0199106b.pdf
    robivesartmez
    Reply 3 years ago
    There's also this showing another galvo project http://elm-chan.org/works/vlp/report_e.html
    aasukisuki
    3 years ago
    Pretty cool, but why don't you just have the servos move the laser pen instead of 2 mirrors?
    DrStein99aasukisuki
    Reply 3 years ago
    The laser has more mass & weight then the mirrors. The greater the mass, the more difficult it is to control and stabilize, change direction, etc...
    robivesaasukisuki
    Reply 3 years ago
    I moved the mirrors rather than the laser as they are very light weight and therefore faster to move.
    GeekMomProjects
    3 years ago
    Very cool project! If you're looking for more precision, you might consider switching to stepper motors over servos. Nicely done.
    robivesGeekMomProjects
    Reply 3 years ago
    I went with servos as they are cheap and easily to use - but I like the idea of stepper motors, I'll give it a go.
    DrStein99robives
    Reply 3 years ago
    Stepper motors can do the trick, except the image is choppy at best. They are made to rotate from one degree to the next. When an optical beam is applied to that shaft, across a distance you can see the amount of deflection and jittter & bounce that is caused on the magnetic field and bearings that deflect off of the mass of the housings, mounts, and desk it's sitting on. In order to make a steady image, you need the least mechanical mass as possible. There are no moving parts in a CRT television tube, which uses only a magnetic field to control the beam of light. Laser projection TV relies on spinning gyroscopic mirrors and complex electronics to make that image. Try and research how common laser-printers bounce that laser off the mirror to render the toner print-out. You can buy used laser printers for cheap, take them apart and see inside. Of course you can use the mirror, motor, focus lens with the perfectly manufactured jig it's already mounted on. You may also need a good understanding of electronics to fabricate the electronic control driver for that setup.
    DrStein99robives
    Reply 3 years ago
    Smelter_uk
    3 years ago
    This could be a real time sign writing gizmo. How long does the image persist?
    robivesSmelter_uk
    Reply 3 years ago
    No more than a few seconds - you can see the fade on the YouTube video. As long as you keep rescanning though I'm sure you could make a sign. I'm planning to try making a clock display which would use roughly the same idea.
    Smelter_ukrobives
    Reply 3 years ago
    Hmm, anything like this?
    http://www.yugop.com/ver3/stuff/03/fla.html
    Yonatan24
    3 years ago
    So are you saying in step #1 that if I shine a laser pointer at an old CRT TV, It will glow a bit?
    robivesYonatan24
    Reply 3 years ago
    I have an old 'scope with a crt. If I shine the UV laser pen on it there is a very bright glow which fades very quickly. The scope is designed not to have long persistence whereas the vinyl sheet is designed for the longest possible...
