Laser Magnetic Field Mapping
57,682
466
26
About: I'm a guy with diverse interests in San Francisco, CA. I enjoy solving problems, inventing and making things, exploring the unknown, making music, and learning new skills. Learn more about me at gordonki...
Have you ever wanted to visualize magnetic fields better?
Magnetic forces, invisible and acting at significant distance, fascinated me since a young age as an instance of "real magic".
You can get a good sense of the strength and direction of a strong magnetic field by loosely holding a magnet in your closed fist, but I wasn't happy with the resolution or clarity of this method: It's too hard to discern torques from translational forces, and if your hand confines the magnet's rotation, you can fool yourself about the direction of the field (For instance, if you rotate a magnet 180 degrees, you could change attraction to repulsion). Also, if one goal of such a visualization tool is to share the shape of the field with others, you want something visible, so a magnet held in your hand won't do.
I wanted something like a compass, but which could point in any direction in 3D space, not just directions within the compass's plane, or a horizontal plane. It should be well balanced, able to pivot with low friction around two perpendicular axes, and carry a strong enough magnet on it that it would overcome whatever friction the pivots had, to align itself with the field. A magnet that is free to orient itself, but is held centered in a given position, will turn until it's poles align with the local magnetic field lines. You can use something like this to visualize where the magnetic field flows around complex things like magnetic levitation apparatus.
Materials and Tools I used
  • laser cutter. You can make a magnetic gimbal compass with other cutting means, perhaps even just a small coping saw, but the laser cutter sure makes it a lot faster if you've got one)
  • 1/4" thick acrylic. Other materials like wood or MDF would probvably be fine substitutes. Other thicknesses are fine if they are strong enough to support a 1/16th inch diameter hole drilled into the thickness.
  • small red laser diode. Only use low power, <5mW, laser pointers, or you'll put your eye out!
  • two 1.5V button cell batteries. I cut open an A23 small 12 volt battery to get a supply of 8 small button cells for a lot cheaper than buying any other button cells available at my local big box store.
  • a file or sandpaper
  • non-ferrous wire, 1/16th inch or so. I used brass brazing rod from my welding supply store. any non-magnetic alloy should work: brass, bronze, copper, aluminum, most stainless steel, etc.
  • a drill bit very slightly (a few thousandths of an inch) larger diameter than your wire.
  • a small powerful magnet (or if using a laser, four magnets). I used 1/4" diameter, 1/4" tall, neodymium iron boron rare earth magnets, grade N42. Any magnet will do, it's just that the more powerful ones can overcome more friction in the pivots. Ebay has lots of magnets for sale, search "NdFeB Magnet"
  • miscellaneous scraps of small wire finer than AWG22 for connecting the laser and batteries. A soldering iron is useful for attaching wires to laser diode.
Supplies:
Step 1: To Point With a Laser, or Not?
The first, simplest gimbal compass I attempted worked great, with simply a small 1/4" diameter, 1/4" tall rare earth (NdFeB) magnet I got off ebay for less than a dollar. It pivoted easily in both axes of rotation when within about 8 or 10 inches of the permanent magnet assembly I was interested in mapping the field of. But it was small, and so hard to see. It worked fine for my own investigation, but the effect of watching the gimbal rotate (resolving whatever pointing direction into the rotations of the two gimbal rings) was so cool, I decided to embrace the show-and-tell aesthetics, and explore ways to make the pointing direction more salient.
Adding a large pointer arrow would have worked, but I wanted to keep the gimbal-compass small, so I could get it into small spaces. I decided to emphasize the direction of pointing by adding a laser. The laser could remain small, and so too the gimbal, but the laser's beam would be a very salient pointer. Also, it could be made even more spectacular by the use of a fog machine. Lasers LOVE fog machines.
One trade-off of going up in size, to add the laser, batteries for the laser, and additional magnets to achieve symmetry on the inner gimbal disk, is that the gimbal has more inertia. As a result it can sometimes oscillate before coming to rest at a given angle. It should go without saying, too, but lasers of only the smallest power should be used in this.
Note Regarding Lasers and Eye-Safety
Lasers are dangerous to eyes. In this application I used a very low power 1mW red laser diode. I strongly discourage anyone considering attaching anything stronger, because this laser's pointing direction is not directly under the user's control. The whole point of this project is to let the beam's motion serve as an indication of some unknown, the magnetic field direction. With a low power laser like this, you can blink, or move your hand, should the laser approach or cross your eye. With other lasers of higher power, it is possible to cross a threshold where the laser can cause irreversible eye damage faster than the blink reflex. Know that, be rightly scared by that, and enjoy reading instructables for years and years with good eyes.
Step 2: Design Your Gimbal From the Inside Out
The size of the outer rings is determined by what you want to support on the inner rings. In the first, smaller, gimbal I made, I only wanted to hold a small 1/4" diameter magnet, so the inner ring was basically just enough acrylic to hold the magnet, and provide purchase for two 1/16th inch diameter brass wires acting as pivot pins. In the second version shown here with a laser, I wanted to have a small laser, two batteries for the laser, and some number of magnets.
Design the gimbal so it is balanced around the center of both axes' rotation. The rings of the gimbal need to be balanced around the pivot axes, so gravity doesn't tend to make it want to hang in any particular direction. I opted to achieve balance by symmetry - simply taking care to place things equally around the centers of rotation (it's easiest that way). I put the one thing I only needed one of, the laser, in the center, and everything else I needed more than one of (two small 1.5 button cells to reach the laser's 3V operating voltage) evenly spaced around the center. I could have used 2 magnets, but that would have meant the pointer would have much stronger alignment with one axis than the other, so I used an array of four small magnets to approximate a single one. The magnets should all be facing the same way.
Step 3: Design the Middle and Outer Gimbal Rings
You want a nesting series of 3 parts- the outer yoke or ring, the middle ring, and the inner disk. The middle disk has pivot pins on perpendicular axes, with the pins on one axis connecting it to the inner disk, and on the other axis, to the outer yoke.
Leave some room between nesting parts on the extremities of the rotating parts, so that they do not collide during rotation. But have them approach with close tolerances on the sides joined by pivots. I've attached inner, mid, and outer .dxf files for both gimbals shown in this instructable here.
Step 4: Laser Cut Your Parts
You could also use a coping saw to cut out gimbal parts by hand, but a laser cutter makes this vastly faster and more convenient and precise. I went through several iterations of cutting and measuring to get kerf-allowance margins just right, so that the magnets, laser, and batteries would all press-fit and stay snugly in place.
To make everything come out exactly the size you want, you need to calibrate your drawings and the laser's cutting path with consideration of the width of the laser beam, or kerf. This involves cutting shapes and measuring the difference between the drawing's dimensions and the part's dimensions, then adjusting the drawings. It is quite simple, as long as you keep in mind what part you care about: the inside, or the outside. This will determine whether you either increase the size of that part in the drawing, or reduce it, by the kerf allowance. Adjust the specified cut-size to bring the as-cut size in line with your intent. This adjustment can be made very easily if you make the part as a parametric model in inventor, and link to an excel parameter file. Then you can just update the excel file "kerf-allowance" line, update the model, and re-export new .DXF files to the laser cutter.
Step 5: If Using a Laser Pointer, Get Some Batteries for It.
I have pickle jar full of small red laser diodes the size of pencil erasers, in small brass cylindrical housings. I got about 70 of these for $20 off ebay, and they were perfect for this purpose, being so small. But they have bare lead wires, and no integral battery holder. I needed to provide power to the thing somehow, and I did not want to limit the rotation of the gimbal by having wires bridging the rotation axes. Nor did I want to engineer slip-ring electrical pass-throughs to get power across the two rotating joints to the laser, from some external power source or battery holder. I had to put the batteries on the inner ring with the laser. I decided to do this by laser cutting slots into the acrylic, which would hold the batteries on edge. But which batteries?
I got the smallest hearing aid batteries I could find at the local target, but was disappointed to find that many of the package were flat dead. 1.5 volt button cells other than hearing aid batteries are very expensive, too! Individual small button cells were $4 and up. But I found a 12 volt A23 battery, and recalled these have many separable button cells within them. Bingo. Lots of small button cells for only a quarter or so each. They were larger than the hearing aid batteries, but I adapted my design to fit them and moved forward anyway.
Step 6: Prepare Non-ferrous Pivot Wire and Drill Pivot Holes in Gimbal Parts.
The pivots should be non-ferrous so they don't get attracted to the magnets you're using this compass to sense. I had some 1/16th inch brass rods from the welding supply store to do fillet brazing on another project. Bronze or aluminum would have worked equally well.
It's important that the wire spin smoothly, so you have to round the ends after clipping the wire to length. Otherwise it'll not spin smoothly. It can be hard to hold small wire to file the ends round, but I found it very effective to chuck the wire into a drill, rotate the drill slowly and draw a file or sandpaper over the end of the wire. Bingo: rounded, smooth, deburred wires.
My wire measured 0.061" diameter, and so I used an 0.062" drill bit to drill pivots in the gimbals.
It is important to make sure that the pivots on a given axis are truly coaxial, because otherwise the gimbal will not spin without jamming. But the drill bit is often not long enough to drill straight through the part fully, which would otherwise be the easiest way of ensuring coaxiality. I found a compromise by modifying my laser-cut part files to include small 0.010" diameter holes in line with each pivot hole, that I could line the drill press up with, ensuring parallelism and coaxiality to within close enough tolerances for smooth spinning.
Step 7: Round the Edges of the Gimbal's Rotating Parts, Especially Around the Pivot Axis
Sometimes laser cutters don't cut perfectly perpendicular-edged parts. If your parts are parallelogram-shaped, they will bind and not spin smoothly. After drilling pivot holes, I rounded the edges of the acrylic with a file around the pivot hole, to make sure it wouldn't bind.
Step 8: Put a Drop of Oil in the Spinning End of the Holes and Work the Joints
One end of the wire will be captive, one end of the wire will slip. Assemble the pins into the holes after lubricating them, and prevent the pins from falling out by capturing them on their outermost edges with either a piece of tape, or a drop of hot glue.
I worked my gimbal by hand for a few rotations to work loose any sticky spots before I looked up and noticed the compressed air hose dangling above me. "This'll be a great way to work the joints loose" I thought. I then proceeded to accidentally make a 60,000 rpm air turbine / whistle / siren out of the thing, by placing the 90 psi compressed air jet almost adjacent the gimbal and giving it a 3 second blast. The gimbal spun up like a rabid squirrel after a double espresso and glissado-ed to above 2khz pitch, about 60,000 rpm, before raining down it's components in a spectacular disintegration of the middle gimbal ring. The outer yoke and the inner laser-holding disk remarkably survived unscathed.
Thankfully, 1) I was wearing eye protection, and 2) I had laser cut a back up gimbal, and so repaired the damage almost immediately. As an added bonus, everybody nearby had a good laugh about the hilarious sequence of sounds:
ffffft (air hose) wheeeeeeeeeee (glissando of unexpectedly excellent air turbine / gimbal spinning up), kathwack tinkle tinkle (as the acrylic ring shattered, parts went flying, and rained down).
After that, I worked the joints with the air hose held farther away, at sub-rabid-caffeinated-squirrel speeds. You can direct the air hose so as to excite one axis or the other of the gimbal, or diagonally to excite both. I'll upload some video of that interesting spectacle tomorrow.
Step 9: Wire Batteries to Laser
It's not pretty, and I'm a little embarrassed about this step, but I wanted functionality, pronto, so didn't over engineer anything. I connected wires to the batteries in my little laser-cut slot holders by simply filing grooves with a V-shaped file into the acrylic adjacent the faces of the batteries. AWG22 single-conductor hook-up wire was stiff enough that, if the grooves were of tapering depth, the wire would jam in between the acrylic and battery, making useful connection. Take care to note that button cells are positive on the body, negative on the button dimple, in contrast with AA or AAA batteries.
Step 10: Enjoy Mapping Magnetic Fields!
I especially enjoy seeing how, in order for the magnet to align with the field, the parts of the gimbal resolve the required rotation into the component rotations around the two pivot axes.
You can use a fog machine to make the laser beam visible, which is really impressive. I'm thinking I'll do some more long exposure photographs, leaving the laser gimbal fixed in various positions for long enough that the beams register as beams on the image.
    • Arduino Contest 2019
    • Classroom Science Contest
    26 Discussions
    PeterA1
    4 years ago on Step 10
    perfect tool for 1st year electrical students. Thanks, I will make a few and hand them out to my students. You will be mentioned and perhaps become famous in Australia!!!
    GordonKirkwoodPeterA1
    Reply 4 years ago on Introduction
    Why thank you! I like to think that if mass producing these one could turn them out in fairly quick succession after getting set up and familiar. Please keep me apprised of your experiences teaching with this!
    Dylan91
    2 years ago
    Nice work and awsome tutorial:) Thanks for your work
    There is a real eye safety issue here, even with a "1mw" laser module. Even 1mW entering the eye is not safe if it happens repeatedly. If your blink reflex is compromised, 1mW can cause eye damage. But of greater concern is that often times these Chinese "1mW" laser modules can be way overspec. Someone of LPF tested these recently and some were found to put out in excess of 30mW, which is definitely not eye safe. I would advise anyone who builds this contraption to never look in its direction during use and only use it in conjunction with a camera for safety. And don't count on the cheap eBay safety glasses, either. They will do almost nothing at these wavelengths. Even with the proper safety glasses, it's never a good idea to be looking into lasers. So the camera is the only truly safe way. And keep people and animals out of the room during operation. You only get one set of eyes.
    Hi askjerry, I am indeed mapping fields, albeit with a hall effect sensor instead of that GMR sensor you linked to. These give linear output up to about +/-100mT, as opposed to the GMR sensor linked which maxes out at about 8 mT.
    That should look pretty cool when plotted out. There was a high school student doing a project on magnetism... I helped him with his science fair project... getting the plots printed out graphically. We converted them into 3D shapes and ran them through 3D Studio... it turned out quite well.
    Good luck with your project... please do updates!
    Jerry
    I was looking through my archive drive... i don't see it unfortunately... it was 2 or 3 computers ago... if I fire up the old machine (in storage) I might find one... if so, I'll post it. I modeled each layer as "tinted glass" so you could see through it... he won 1st prize... so that was cool.
    PS118
    Cool gizmo. I may have to build one to play with sometime.
    Until then, a few questions:
    What happens if you plug a heater or something into an outlet (so there's a lot of current draw) and hold it next to the wall?
    Will the field allow you visualize the path of the hidden wire?
    Also, if nothing is around does it point North?
    GordonKirkwoodPS118
    The inertia of this magnet means that it is unlikely to move significantly to such a fast alternating field as 60hz, or to such a weak field as normal house wiring currents would produce. However, when I place this near the 1200 turn electromagnets carrying 1 amp peak sine currents at 100hz, I can feel it vibrate definitely.
    Lastly, it would align with the earth's field if it was well enough balanced and, most importantly, if the friction around the pivots could be reduced by an order of magnitude or two. I debated suspending the gimbals from taut string to achieve such low friction. Perhaps fine ball bearings or a jewel point bearing would also be low enough friction.
    Actually, you might get some pretty interesting results if you were to place this device near a fluorescent light. I've found that cheap shoplights (the ones that hum) with cause a run-of-the-mill ceramic magnet to vibrate quite strongly if you hold it near the unit --might have to wave it around until you hit the sweet spot. Of course, there's some question as to whether the magnet is responding to the input or output winding's current, but it's still pretty cool...and somewhat startling if you aren't expecting your magnet to start buzzing in your hand (still haven't found that magnet) while you're trying to stick a reminder to buy more tubes on the fixture.
    Nice work! Would be interesting if a similar device could be made to visualize electrical fields. I have to admit though that I wouldn't know how to do that. Any ideas on that?
    BTW: what is that other project you are working on with the permanent magnets and electromagnets?
    Thanks el-Raza. You certainly could do something similar to detect electrical fields although I imagine one would want to use sensors and amplifiers to indicate the field direction, rather than using the high potentials that would be required to make an electrical dipole align with the field and overcome friction.
    I don't know what I was thinking there, d'oh. Of course you are right. I suppose I was thinking of the most readily sensed electrical potential, which could be sensed with a small probe and is scalar, as opposed to the gradient of the potential. If the field were large enough, you could, I suppose, have a large electrical dipole which would align with the field in a similar fashion as this magnetic gimbal compass; perhaps a small gimbal compass with a pair of sphere electrodes on it and a high voltage source maintaining a large potential between them would create sufficient torques to align that dipole with the field. Or is there a better way?
