Launch It: Torsion Spring Catapult
69,166
119
40
True catapult that uses a extremely tightly wound string to power it, it fits in the palm of your hand, it cost under $20. all supplies can be purchased at Michaels. fires small foam objects 40 feet aprox 1053 feet to scale, about 7.5FPS when firing a 14g weight (twice the weight of the catapult its self) (i know cause i did a school project on it. This is my design and i didn't copy it) it can fire other objects farther and faster such as rocks but you can not easily recover them cause they go to far and fast to visually track.
this is for the competition so please comment and rate (this is the 4th catapult i have made they all worked good yours should to)
This is technically an [http://en.wikipedia.org/wiki/Onager_(siege_weapon) onager] but it is still in the catapult family.
this is a rather complicated instructable and is an example on how to build one yours dosent have to be exactly the same i use cm for most measurements but some are in inches ask if you get confused
use safety glasses when drilling cutting wire and when firing
this is safe when fire foam objects when firing rocks never aim at a person animal car personal property it fires hard enough to break a paint ball if used for office war only use foam light weight objects and make sure every one is wearing safety glasses
build this in a room with good ventilation the Ca glue and accelerator smoke when they dry
Ca glue bonds to skin on contact use un-cure do not pull apart. the glue will not separate but the skin on your fingers will.
The accelerator causes chemical heat and you can get a chemical burn from it which hearts so dont touch it
it has a range between 15-50 feet depending on ammunition and angle of trajectory
Other videos on step 4 and 9
I have pics of my 6th grade Sci fair project back when i was 11
Step 1: Get Your Stuff
i went to Michaels and spent a little over 3 on:
wood, midwest 3/18 X 3 X 36100% polyester string 500yds
you will need other balsa wood i have a huge box of scrap so i didnt need to get any thing else
you could use cotton, or any sting thats not hemp or nylon thats around the same diameter as kite string or you could just use kite string.
you will also need:
wood glue 19 gauge steel wiresawexacto  kniferuler square (a right angle thing)sand paper bamboo skewers Ca glue and accelerator  (with out accelerator its pointless)5min epoxy the kind that you mix two elements together
you only need epoxy one time the when your gluing the arm, you could use wood glue or hot glue as a substitute but i dont recommend it.
Step 2: Mesure Then Cut Main Frame
you will need to measure the midwest 3/18 X 3 X 36 piece
See Pictures
measure
first draw a line using your square at 5cm it needs to be 42 cm long
at 17 cm draw a line using the square repeat once draw a line at 9cm repeat once
cut
your saw probably can cut the long 17cm long cut so carefully use a razer and a metal strait edge like in the picture
Step 3: Glue Main Frame
this step will probably take the longest time because you have to wait for the glue to dry
line the pieces up and make sure every thing is strait and at a right angle
use Ca/accelerator, put a little drop on the top corner of the joint and spray with accelerator wait 30 sec and carefully pick it up and flip it over put it another drop on other side doing this makes using wood glue so much easier.
Then use the same proses to glue the other two pieces into place
use wood glue to finish the job
why not just use Ca? Ca can take some stress and shaking but hard shocks and impacts weaken it. so we need wood glue not hot glue, hot glue will flex way to much (as i learned from my first catapult)
let it dry then proceed on
Step 4: Mesure the Frame for the Holes and Other Stuff
decide what will be the front and top docent really matter which just chose
repeat all this for the other side
see pictures
make a line 3.5 from bottom
make another line 6.5 from end
where the cross is where a hole will be drilled for the torsion spring tightener
Step 5: Strengthening
on my first and second attempts the catapult riped its self in half to to extreme forces at work so we need to add reinforcements directly under where the holes will be this is where the most stress will be.
a cross will also help prevent warping.
the pictures should help the directions make sense
Measure.
the inside width of your frame mine was exactly 8cm
Mark
on a thick piece of wood (mine was 1X1 cm) mark at 8cm cut then cut another piece 8cm long
Measure across the frame mine 20cm long do it again for other direction
Cut the two pieces
Measure.
slide one piece under the frame make sure its the bottom of frame and no the top then trace the inside corners Repeat for other piece
Cut
along both lines on both side repeat for other piece
Sand
you will probably need to do a little sanding to make them both fit in
Mark
mark where the two pieces meet on both sides
Cut
use a wide exacto knife like a chisel to carefully cut half way through on both pieces
Pre glue
Put them back in make sure they fit
Glue using Ca glue to temporarily hold together put a dot at each corner and where the two pieces cross over dry with accelerator
Go back to the other 2 pieces we cut out earlier
Select one of them at random and:
Sand
i had to do a little sanding before it would fit in
Slide
slide it down so that its 6.5 Cm from the front
Mark where the 2 cross pieces cross over it
Cut about half way through like you did before with the cross
Pre glue
use Ca/ accelerator to glue the brace in
Now the remaining piece
repeat what you just did with the first one but do it 13.5 cm from front and pre glue with Ca
Add more
get a scrap piece from cutting out frame measure/cut it to fit Ca glue it 2cm from top 2.7 cm from front
Glue
use wood glue to glue every joint let it dry then proceed on
Step 6: Build Upper Frame
the upper frame needs to be extremely strong
this is complicated because their are to many variables in the design
You need a base to mount the two 45 angle supports i used some scrap from the frame
Ca glue that for now
now measure how long the vertical supports will be cut them and Ca glue in place
measure the length of the cross bar cut and glue into place
use pictures as guidlines
i also added a square support on the inside sides to help support once you have every thing Ca glued use wood glue to finish the job
Step 7: Drill/string/sling/ring
i am using the arm from an older design but ill still show you how to make your own.
start by using a dremel tool or drill press to drill the 2 holes use a drill bit close to the same size i did. use safety glasses when drilling
cut about 2yds and 6inch of string.
tie it together into loop and cut of the excess string
double the loop once, then again
After Step 8 come back to here and make sling/ring (do to tecnical dificulties i can not have another step)
for the ring cut about 7cm of wire and twist it into a loop like on a key ring (or you could just use a key ring)
then attach it to the arm like in the last pictures using a drop of Ca/ accelerator
now for the sling (i am using the sling from 3.0 so this one is just a model)
using a sharpie or marker make a diagram similar to the picture below (with out the numbers/words)
cut it out and punch holes on each corner like in pictures
tie an even amount of string on each hole
tie the two ends evenly together and make a loop with the remaining string
Look at the pictures for the rest of instructions its a lot easier to explain and understand
Step 8: Making the Arm
i had a throwing arm laying around so i used it but ill still show you how to make one.
First cut on thin piece of balsa wood 18cm long now cut another 18cm long piece using thicker balsa (i didnt have 18cm of thick so i had two glue two together)
mark 1cm on the thin piece
glue togeather using 15min epoxy (glue so that 1 cm of thin is infront of thick)
allow to dry.
now we need to drill a hole to but the hook into
using safety glasses
cut about 1.5 INCHs of wire bend it so it kinda resembles the picture.
get a drill bit little thicker than wire
carfully drill a hole 2 inches deep into thicker piece of wood
glue use Ca glue to fill the hole you drilled, insert the hook so its facing the same way as picture
do not use accelerator give it 5 min to dry on its own
now that thats done flip back to 7 to complete the sling and ring (sorry bit of technical difficulties)
Step 9: Rigging the Arm
we are to the part of the project where the torsion spring and arm will be installed into frame!
the pictures should explain them selfs
Here is a video to help explain (the microphone on camera is messed up so all it gets is static) yes i intended it to jump out of my hands i was trying to show how powerful it is
After its twisted really tight let it sit over night the spring will relax, and when you tighten it again it will be even strong than before (getting the string a little bit wet will make it relax too)
Step 10: Adding the Catch
the catch this is the firing mechanism you push it down or pull a string an it fires its pretty simple you already made the ring so now all you need is a hook made out of the same 19 gauge wire.
first get some of that scrap left over from the frame cut it at about 4 cm
now cut 2, 2cm pieces i used 1X1cm
position the pieces like in pic 3 and glue them with Ca/accelerator
then i just snapped a bamboo skewer so that it was about 5cm long (i just snapped it no need to use saw or measure)
put dots of glue down, glue the piece of skewer on and spay with accelerator
now Ca/accelerator glue the whole thing about 1 cm from top
this has no safety the hook is a kinda sharp and it could go off at any moment if it hits you in the eye it will cause severe damage i have had the tip jab my finger it sinks in deep and it hearts
Here it is (i did not load the catapult in video)
Step 11: Load and Fire!!!
to load simply pull down arm hook the hook through the ring. loop the string loop around the other hook
place ammo in sling aim in safe direction push down lever and Fire!!!
If you read the bold on first page you would know that this is a temporary video and one that meets the criteria will soon follow
Step 12: Adjusting
This is not extremely accurate it was originally designed to shoot at a castle wall.
you want a trajectory of about 45 degrees
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    40 Discussions
    dean14111
    6 years ago on Introduction
    by the way your video on it is listed as private so we CANT watch it!!!! good inst though
    tobyscool
    7 years ago on Introduction
    Nice catapult :D
    but i can't watch the video it says its on private
    mironman
    9 years ago on Introduction
     nice. very cool attempting on making my own. cant find anyplace but here to find how to build a miniature onager. then ill maybe have an idea on  how to build a bigger one on my own. thanks for the great instructable with all the pics and steps.
    shadowhawk96
    Put hooks on it so you can also add rubber bands so you get more power and range.
    ltamez
    going to start this project over the weekend as usual my son tell me today he has to build a catapult and that it is due Tuesday, well at least we have the weekend, only he can't use any metal but nails so we figured instead of using the ring we will hold it down with two nails and string will post when we get it done.
    ltamezltamez
    well we accomplished it will post a pic later...worked great and it was so solid. When I did the base I put rubber bands around it to hold it tight together. Great Idea thanks...
     heyy we made this catapult and it's pretty good, but our arm doesnt tighten that much, so it cant launch anything, it just slowly goes up, any suggestions of what we could do?
    Impressive! Much better in design (and range) than mine...still got an A in social studies, though I hit the teacher. :P I hope your instructable wins!
    dietpoop
    suggestion: the twisty bit u could drill a hole next 2 it and place a pin in the hole 2 hold the torsion
    otherwise, great
    qkooosjjjdn
    9 years ago on Step 5
    is the piece that you used for the 20 cm cross part 1 cm by 1 cm like the 8 cm part? it looks smaller
    m456arcus
     When you make the skien, how do you connect the string in a loop?Could you just tie it?
    Do you think this type of string (or should i day roping) would work on a real catapult, say 15 feet long. I just built one and I wanted to do torsion but I am not exactly sure how yet.
