Leather Cell Phone Case
2,429
38
About: Former NFL Offensive lineman turned Furniture maker. I am self taught and sharing my experiences with the world!
HOW TO MAKE A LEATHER CELL PHONE CASE
This is my FIRST EVER leather good. So from scratch i am quite proud of it. In this video I make a leather case/pouch for my cell phone! I get some help from local leather maker Ryan from Rustbelt Mercantile (Instagram.com/Rustbeltmerc).
Ryan made a list of the best tools for beginners to get started. Check it out!
Beginners Tool List
  • Stitching Hole Spring Leather Punch
  • Craftool Spacer Set
  • Lacing-Stitching Pony
  • Wing Divider
  • Craftool Scratch Awl
  • Poundo Boards
  • Craftool Edge Bevelers
  • Harness Needles 10/pk #4
  • Economy Rotary Leather Punch
  • Drill Burnisher
  • Multi-Size Wood Slicker
  • Waxed polycord
  • Eco-Flo Gum Tragacanth
  • Beeswax Block 1 oz
  • Tandy Pure Neatsfoot Oil
  • Obenauf's LP Boot Preservative 8 oz
  • Tanners Bond Contact Cement
  • Supplies:
    Step 1: Choose Your Hide and Cut Out Shape
    Pick your section of hide. Layout your selected area with a straight edge and cut your section using a brand new razor blade.
    Step 2: Cut Holes and Curves
    Center and punch the hole for the bottom of the case. Layout template for the curve on the top of the case, and cut with a sharp knife. Bevel the edge with your edge beveler.
    Step 3: Seal and Burnish Flap Edge
    Apply Eco-Flo Gum Tragacanth to edge of bevelled curve. Burnish on the drill press.
    Step 4: Taper Corners and Cut Holes for Stitching
    Use corner tool to taper base of the case. Then mark lines for the thread holes. Pre mark, and stamp the holes for the belt loop on both the front and loop flap. Then saddle stitch together
    Step 5: Repeat on the Sides
    Repeat process for edge stitching. Mark holes, punch, and saddle stitch sides together.
    Step 6: Sand Flush , Burnish , and FINISH!
    Use the sander to flush edges. Add bee's wax and burnish. You're done!
    if you like this plan please share and check out my YOUTUBE channel For more build videos!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    ventifact
    11 months ago on Step 1
    You seem to just jump into this without any layout or pattern.
