Lego Earring
11,844
48
8
We were heading to Brickfest this year and I wanted to make something for the event. Lego earrings seemed perfect.
These were designed to be able to have easily changable "gems" to match whatever outfit she may want to wear, but it would be easy enough to take this and make any sort of Lego earring style from it.
Supplies:
Step 1: Stuff You'll Need
So, this is pretty flexible here in what you'd need for this, but it boils down to:
Earring back
Earring loops (or some other small ring)
Super glue
Lego blocks depending on what you want the earring to look like
I bought a small variety back of loops for a few other projects. The size of loop you'll want will depend on the looks you want and the size of the block you're connecting to. I used the 1/8" loops for the earrings here.
Step 2: Glue the Backs
Super glue the rings to the small metal loops. You'll want enough of the loop to be above the top of the Lego block to be able to get the earring back in the hole.
Also, if it's important to you, double check to make sure that "Lego" is right side up on the top of the studs.
Step 3: Add Earring Back
Let the glue dry well, then take a pair of needlenose pliers or similar and use them to open up the loop in the earring back.
Once open, slip it through the hole in the loop attached to the Lego block.
Then, carefully reclose the loop in the earring back.
Step 4: Add Flair
Once the main piece is finished, add any accessory parts you want to the Lego block (if any).
Then, surprise your girlfriend and go to your favorite Lego convention. Or just a night on the town.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    8 Discussions
    nsmith1
    7 years ago on Step 4
    This is a smart way to make these. I have been drilling the hole for the earring hook, and the drill slips about 1/3 of the time, so then that's a wasted Lego AKA cat toy at our house. I am going to try your way right now. Thanks for posting this.
    seabananers
    9 years ago on Introduction
    my sister will like this ps darth nihilus is my favorite sith its just i forgot when i signed up
    hayley_153
    10 years ago on Introduction
    I tried this and I LOVE it! (And so did all of my friends. :P) Thanks!
