Let's Make a Game Controller!
100,969
800
86
I love flying games, but it feels like there are never enough buttons on my joystick.
This instructable will show you how to build your own switch panel in no time.
It will work with any game and computer that supports a joystick. I also encourage people to adapt this guide to make foot pedals, joysticks, or other input devices.
What skill level is needed?
This is a great starter project, all the wiring and code is very simple, just repeated for each button.
Out of any project I've done this has had the best ratio of skills needed to reward, so with relatively little effort you will get a great reward.
Supplies:
Step 1: What Will I Need?
Tools
  • Wire snips + thin wire
  • Soldering iron + solder
  • Drill + drill bits
  • Dremel (optional) + safety glasses
Bits
  • A Teensy(or arduino that supports HID)
  • Buttons! Lots of buttons and switches
  • Potentiometers (optional, used for sliders or axis control)
  • LEDs (optional) + equal number 220ohm resistors
  • Perf board
  • Female pin headers (optional, but recommended)
  • Enclosure
Notes:
I used the dremel because I had some square buttons, using just round-base switches is way easier and faster!
The female pin headers are great so you can take the Teensy out and use it for the next project—highly recommended.
You can also use an Arduino instead of the Teensy, just be sure that it supports HID (Human Interface Device), this is a great standard that ensures it'll work easily with any computer.
I found all my buttons and the enclosure at a local hobby electronics shop.
Step 2: Start Laying Out
The quickest way to plan where the switches will go is just draw them on with pencil.
Bonus
I wanted an extra crisp look, so I redrew all my markings on the computer and printed it out.
Then I glued the paper to my case and pasted over it with clear tape, so the oils in my hands don't ruin the paper.
In the end I chose the standard Russian green colour, makes it a bit more fun, and apparently helps reduce eye fatigue for pilots.
Step 3: Manufacture
Next drill out the holes you marked with pencil, or on your printed decal.
(Optional) If some of your buttons are square, you'll have to use a cutting tool.
Test fit everything together, and become eager with anticipation.
Step 4: Electronics
Snip the pin headers to length for each side, then solder them to your board.
Test fit the board and trim if needed. Leave a few pins on each side of the teensy.
The first step of wiring is to attach the ground wire to one of all the button pins, if there are three pins on a button, attach it to the middle one. For the potentiometers attach ground to one of the outside pins, doesn't matter which.
Now is also a good time to glue in the LEDs, if you're using them, and solder the negative pin onto the same ground wire that we used for the buttons. (All round style LEDs have a flat spot that mark the negative side)
Step 5: Wire Buttons
I've included the diagram that comes with each Teensy, it shows each pin number and what they can do.
Button
One side of the button goes to Gnd, the other to a digital pin on the Teensy.
Each button will take up one pin (marked in grey on the diagram), and a few of my 3-position switches will take up two. Keep track of what pin numbers you are using, but it's not necessary to know exactly which button goes to each pin.
LEDs(optional)
With the flat side of the LED attached to ground, the other side will attach to one side of a 220ohm resistor, and the other side of the resistor will attach to a digital pin.
Notes
Some 2-position switches have three pins. With the middle pin attached to ground, choose what side you want to be "on" and attach that to a digital pin on the Teensy.
Step 6: Potentiometers (optional)
It doesn't matter which side gets wired to 3.3v and which to Gnd, but the middle pin must go to an analog input on the Teensy (marked in orange on the diagram from the last step).
Notes
A potentiometer is a variable voltage divider, basically one side gets the whole voltage, the other side gets no voltage, and the pin in the middle gives a reading somewhere between the two.
I used B10K potentiometers.
The B means linear, as in it increases in a straight line when plotted, these are used for digital things. Type A potentiometers are usually used for audio applications and increase exponentially.
10K means 10,000ohm max resistance. This is pretty standard, but because what we're measuring is a ratio most values work fine.
Step 7: Code
First step is to install Arduino if you don't have it and the Teensy plugin for Arduino. It's a quick install and comes with lots of great libraries to play around with.
Now either download and change my code to the number of buttons you have, or try to make your own using the included Teensy examples. If all you have to do is a few buttons, it's super easy.
When you want to upload the sketch, set the board to your Teensy version, and change "USB Type" to "Keyboard + Mouse + Joystick"
Step 8: Testing
Presto!
We now have a joystick input device, but does it work?
If you used some LEDs you can flick some of the switches to turn on the lights, but you might have to change some of the pin numbers in the code to match your controller.
Now either load up a game, or on Windows press "Win + R" to run a command and type in "joy.cpl"
This is Windows' built-in joystick utility, select the "Keyboard/Mouse/Joystick" and press "Properties" now we will see live input from our custom game controller! Exciting stuff.
Step 9: Package It Up
I used some double sided foam tape to hold my board in place, anything works, just be sure the circuit doesn't touch any metal inside your case.
Drill out a hole for your usb connection. Tilting the drill back and forth a bit will help make it wide enough without using a huge bit.
Step 10: Finishing Touches
Because I forgot to get proper LED carriages I quickly printed some little rings to make them look more proper.
I also had some knobs from an old stereo for the potentiometers, but I decided to print off some little knobs that match a cockpit a bit better. Any place that sells potentiometers will also sell the knobs, or make some, or download some from a 3D share hub to print yourself.
One last finishing touch was a carbon-fibre type decal on the side. Not very traditional, but looks cooler than the plain plastic.
Step 11: Rejoice!
It's done. Didn't take too long, did it?
Now load up your favourite video game, bind some keys and get to work flying, ejecting, or firing missiles! Heck even change radio stations or run macros.
Thanks for reading along, and hopefully giving it a go too!
Thoughts:
If I were to take this project a step further, I would probably make my own enclosure. You can use a laser cutter to cut the pieces, holes, and etch the design in painted acrylic, all in one go! That'd be the dream.
Epilog Contest VII
Runner Up in the
Epilog Contest VII
First Time Author Contest
First Prize in the
3 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Woodworking Contest
    Woodworking Contest
86 Discussions
CadeK
Question 4 months ago
This istructable helped me so much in making my helicopter collective for my computer. Eventually I might even venture into a joystick. I have one question though. I used your coding for Arduino and while I'm in game and since I have On/Off switches that are non self centering, I have to push the switch on once to activate, and turning it off doesn't cause another action. For example my engine on will be "Joystick/Keyboard/Mouse Button 1". Is there a way to make it so that when I turn the switch off, the engine will turn off as well? I'll try and post some pictures here soon. I ended up making it out of K'nex that I had from childhood.
travershenryCadeK
Answer 4 months ago
Hey, glad to hear it helped! I'm big into helicopter stuff too, lots of fun, even more with a proper collective.
I think I've done something similar, it just takes a little editing the code.
Basically you would code the position 1 of the switch to send one key press, which you would bind to "Engine On", and then code the position 2 of the switch to send a different key press for "Engine Off".
It depends on what game you're playing, but it's easiest if the game can support two different bindings for on or off.
Lucas 1028travershenry
Reply 2 months ago
Hey there, what exact type of switch did you use for the trim? I noticed they were centred and could go both ways, I have the same issue as CadeK and thought that by using those switches you can bind one way to on and the other to off just like you would bind trim to go one way and then the other. Do you reckon this would work?
CadeKtravershenry
Reply 4 months ago
It's Arma 3. I believe that it would support it. What would the code lines look like in arduino for that then? I'm still really green to this haha.
Lucas 1028CadeK
Reply 2 months ago
Hey there CadeK, Have you by chance happened to find a solution to your issue? I wanted to attempt this project for a flight sim and use it as a over head panel but this issue meant I would have to have one switch to turn something on and another to turn it off instead of one for both actions like you had with your engines.
If you managed to make it work could you please let me know?
travershenryCadeK
Reply 3 months ago
Sorry, you'll have to experiment. Unfortunately I don't have my arduino stuff on the computer I'm using these days, so I can't quite say without experimenting a bit myself. :\
If you're interested in this sort of thing, try working with the example files that come with the Arduino program, it's a little bit tricky writing the first few bits of code, but it's such a great skill to develop.
Cheers!
Gideont8
Question 6 months ago
I had a spare makey makey board lying around, is there anything wrong with using this board for this project?
1 answer
travershenryGideont8
Answer 5 months ago
Maybe? I'm not really familiar with the makey makey board, but it looks like it emulates a few keyboard buttons.
marko10912na
Question 1 year ago
Hi, nice build. How do you connect the arduino to the computer so the arduino can send information to the sim?
1 answer
travershenrymarko10912na
Answer 1 year ago
Hey, it connects as a USB HID. Basically, a standard joystick or game controller. If you use a teensy or arduino that supports the Human Interface Device protocol (HID), it is recognized by default as a joystick in most games, so you don't have to use any plugin or anything, just bind each button or axis to the control you want in-game.
AgustineM
1 year ago
Hey bud this is awesome!!! Can I use this code and bind differently the buttons for toggles to play Il2 BoS ?
travershenryAgustineM
Reply 1 year ago
Yeah, certainly. Any game that can accept a standard game controller.
JakeH120
1 year ago
Hey, I realise this is pretty old at this point but I just wanted to know what you've set your dials to do? I'm in the process of making one and don't know what to set them to do. Thanks.
travershenryJakeH120
Reply 1 year ago
I think I used them mainly as a trim input for pitch, and for flaps.
Replacing the pots with a multi-position switch is also fun for selecting modes.
theshinyknight
1 year ago
Awesome tutorial!
Question about the program: how do you change the number of buttons used and the analog controls? I did try it with 4 buttons and no pots, and when I switch a button the hat control and the analog inputs just go crazy, instead of staying where they should. Trying to disable anything I don't need, but can't find references to the joystick library you used. It seems different from the one that is made for Arduino, since this runs on the teensy board. Thanks!
travershenrytheshinyknight
Reply 1 year ago
Hey,
Yeah the library that comes with the Teensy is a bit different than arduino. But I think the fix would be to remove all mentions of the inputs you don't want to use from your code. Sometimes buttons are funky if they don't have a pull-up resistor to make the input "stick" to the right digital voltage.
Hope you've figured it out already, though. Cheers!
shachar2like
1 year ago
Nice article, I might make one for myself in the future.
Do you have another article on making a screen one? (for altimeter/speedometer
travershenryshachar2like
Reply 1 year ago
Hey, afraid I do not have one for a display one.
A game controller just sends commands to the game, but a display needs the game to send information to the device. This is harder to do, and must be done with plugins for each and every game.
efe00
2 years ago
Hi!
Can I use Teensy 3.0 for this project? Will it work?
'Cause I think Teensy 3.0 is great and now it's just $9.50!
Please reply me!
Have a good day..
anv3Defe00
Reply 2 years ago
will an arduino uno work?
