Light Bulb Vase
75,536
393
45
A very simple, yet elegant vase, made from a light bulb.
Recently someone came around with a free energy saving light bulb for every home. So I made something from an old burnt out bulb that the new one replaced. The bulb was hollowed out, and then suspended on a simple stand.
You need:
-a light bulb
-metal rod - I found mine in the junk box. I think it came from a filing system. Something around 3/16"
-A piece of wood. I used part of a wine case. You could use anything really. Try something interesting like drift wood.
-the basic tools: saw, drill, Dremel, pliers.
Disclaimer- Glass is sharp. Be careful. Don't eat light bulbs. This is probably known to cause cancer in the state of California.
Supplies:
Step 1: Hollowing Out the Bulb
This step is probably most dangerous. The bulb could easily shatter. Wear Gloves!
I used TeamDroid's guide.
Here's a quick run through.
- Break off the metal contact from the bottom
- Use a screw or a knife to crack the brown glass insulator
- Looking inside you will see the fill tube. Break it off and remove it
- Remove the filament and other debris with needle nose pliers
- Use a dremel to grind down the glass edges inside for extra safety
- Clean out the powder with water
- Scrape off the writing with wire wool
Step 2: Holes
Make a hole through the threaded part of the light bulb, close to the top. The hole should be through both sides.
Use a drill bit, or a dremel grinding bit. Make sure the hole is large enough to allow your rod to go through it.
Step 3: Cutting Rods
Cut out two 3 inch rods, and another 3 inch piece with a bend in the end.
My rod had a bend in it already, but you can make one by clamping the rod in a vice and pushing on it, until it bends 90 degrees.
To cut the rods, secure them in a vice, and use a hacksaw to make cuts.
Smooth the ends using a piece of sandpaper.
Step 4: The Stand
Select a piece of wood that has an interesting look.
Smooth all of its edges with sandpaper.
Mark a line slightly above the height of the light bulb. Cut off the excess wood, and sand the cut.
Mark a hole at the top close to the center of gravity. Mark two holes at the bottom at each edge to provide most stability.
Select a drill bit that is slightly smaller than the rod, so the rod will press fit into the stand, without needing glue. Do a test fit on the off cut to make sure the hole is not too loose or too tight. Drill the holes with a drill press if you have one.
Step 5: Assembly
Push the two straight rods into the bottom holes.
Put the bent rod through the holes in the bulb, and then into the hole at the top.
Find a suitably sized flower, and put it into your vase, along with some water.
Give it to someone for Valentines!
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    45 Discussions
    kelseyann88
    7 years ago on Introduction
    thank you! i looked at your post to figure out how to gut a light bulb.
    Crucio
    10 years ago on Introduction
    According to some reading I did on Moh's hardness scale, teeth are about the same hardness as Apatite, which is a 5 on the scale. Glass is 5.5 to 7 depending on the type. Diamonds are a 10. So it seems you wouldn't be able to crunch up glass with your teeth. My guess is that the glass he ate in the vid is really cleverly-disguised rock candy. /me shrugs.
    KFCjesusCrucio
    aaaaaaahhhh dont you love people who read a little about a subject and try to assume everything else? the moh's hardness scale has nothing to do with crunching or breaking. it scales what hardness different substances/materials are usually by scratching them against each other. for example, you can scratch glass with a diamond but not vice versa. you can scratch micah with glass but you cant scratch glass with micah. im sure you could crush a piece of glass with some big chunks of micah or maybe crush a diamond with a big slag of glass. the moh's hardness scale pretty much states that the glass probly scratched this dudes teeth up pretty good. i hope who ever reads this learns something
    darkclaw42
    *Jealous* Ive never been able to open up a bulb like that without it breaking. Im going to try your method.
    bullygil
    9 years ago on Introduction
    Awesome ideea and verry easy to make.It took me less than an hour to make it, and I'm pretty excited about it, since it's my first homemade gift.I hope she will like it ^_^
    Kiteman
    12 years ago
    A very nice Instructable. You could do a few bulbs and make a sort of chandelier or mobile, or put sea monkeys in one as a tiny fish tank...
    As for not eating lightbulbs, YouTube can always be relied on to bring the moron out in humanity:
    darkclaw42Kiteman
     I dont know, its probably just me, but the crunching sound kinda sounds.. pre-recorded. Its kinda loud for a camera to pick up, and some of the first crunches were slightly off.
    I dunno, its possible, but not probable.
    Kitemandarkclaw42
    I'd assume they used a microphone (knowing that they would want to hear the crunches), and most of the videos I have posted on YouTube have ended up with the sound out of synch after uploading.  I have no idea why.
    CrucioKiteman
    That's obviously not really glass, or everything from his mouth to his sphincter would be ripped to shreds. A very bad joke that's going to get impressionable kids hurt or more likely killed.
    CrucioKiteman
    Fake yes. Seriously, this is a video prank of some shmuck college kids, not a one-of-a-kind French stuntman. Inhumane hunters used to grind broken glass and mix it with bait to kill wolves.
    AznPandaCrucio
    Say are you making fun of the french????? Huh? better not be Cause thats not nice D:
    wupmeCrucio
    There are plenty of people who do that. My Grandfather was one of them, and he didn't fake it.
    LaxLovaLVKiteman
    Reply 12 years ago
    Ew Ew Ew!! Thats really nasty. Doesn't that like scrape up your esaphagus? Isn't it glass?? Wow and this is why we have to put safety signs on blow dryers saying why not to use while sleeping....
    smbarne
    Great idea and tutorial. I used this with another LED Instructable, a small switch, some wood stain, and some varnish to make one for my girlfriend. Thanks again for the Instructable :].
