Lippan Kaam Clay Art of Gujarat
33,479
20
11
About: I am a hobist with lots of hobies from carpentry to mechanics. There is hardly any thing that i am not interested in.
Lippan art is a clay art form from the state of Gujarat, India. It is mostly done by the village ladies from Kutch to decorate their homes. Traditionally lippan is made by adding mud and cow dung and done on the walls. I am showing a more contemporary way of lippan which used 2 part polymer clay.
Supplies:
Step 1: Materials
We will be using MDF board as the base. The board used here are 6mm boards of dimension 18inch x 18inch.
Also we will be using shilpkar clay which is a different version of m-seal. More white and nonstick.
Glass pieces which can be got from any art and craft store.
Also some acrylic paint to paint our creation.
Also used are some paint brushes and some cutting tools like ice cream sticks, toothpicks etc.
Step 2: Drawing
Take some lippan kaam images and draw onto your mdf board.
Step 3: Developing the Reliefs
Mix the 2 part clay by hand and start developing on the image drawn.
Roll it, press it, pinch it, tear it. Anything you want to do to make your art look great.
Now is the good time to embed the mirrors onto the clay. Yuo can glue them straight onto the mdf if required.
As the clay starts to solidify, use the glue to fix the clay in place, as the clay is non sticky.
When your art form has dried up properly go to the next step.
Step 4: Painting
Use the white acrylic color to give a base coat onto the whole art form.
Actually you are done here. But we are making a contemporary lippan kaam, so we will make it more attractive.
Step 5: Outputs
Many of the unfinished lippan kaam panels when they are still in the drying phase. The base painting will be done as they dry.
Step 6: After Base Whiting
Some of the art forms after they are painted white. Why just white? We are contemporary. Check out the next step for more fun.
Step 7: Finally
This is just one of the lippan kaam output after painting in vibrant colors. These things can not be found much outside Kutch, Gujarat. So go ahead make one too many. Frame and decorate your home.
Clay Contest 2016
Runner Up in the
Clay Contest 2016
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    11 Discussions
    PreetiM9
    2 months ago
    Hi,
    This is an amazing art work!
    I want to do this with my middle school art students. Will it work on canvas and just regular clay? And what type of paints did you use?
    artworkerPreetiM9
    Reply 2 months ago
    Possible with normal clay on canvas. You need a binder such as PVA glue mixed with the clay or a thick color coating (like primer) to hold the final clay art in place. We used normal painter's acrylic paint for the finish.
    artworkerचित्राभ
    Answer 7 months ago
    Lippan kaam is not difficult. If you are a beginner, start with an easy design.
    It may be little tough to stick Lippan kaam on Sunmica with white PVA glue. You can use Gorilla glue while working on Sunmica.
    Best is to work on MDF board.
    RitikaJ2
    Question 1 year ago on Step 3
    Other than shilpkar and m seal can plaster of Paris be used?
    1 answer
    artworkerRitikaJ2
    Answer 1 year ago
    POP (plaster of paris) can be definitely used. Just that you have to check if POP attaches to MDF board or not. If I use POP, I will add some white glue with the POP dough that I make.
    Tura Street
    2 years ago
    That is one of the prettiest things I have ever seen.
    offseid
    2 years ago
    That is beautiful! Thanks for sharing.
    Swansong
    2 years ago
    These are beautiful :)
