Internet of Things: LoRa Weather Station
14,144
83
10
This is an example of a nice LoRa project. The weather station contains a temperature sensor, air pressure sensor and humidity sensor. The data is read out and sent to Cayenne Mydevices and Weather Underground using LoRa and The Things Network.
Check if there is LoRa Gateway of the The Things Network in your area!
Step 1: The Hardware
Step 2: The Wiring
It is wise to first test the sensors on a breadboard. So you can be sure that the sensors works. You can also measure the power consumption with a multimeter. (Use the Low-Power lib to measure the minimum)
First solder wires to the RFM95W module and then solder them to the Arduino Pro Mini. Then add the sensors. View the images and the diagram!
Step 3: The Casing
To place the weather station somewhere, I drew a case and printed it with the 3d printer.
The models can be found on Thingiverse. Of course you can of course make your own variant. https://www.thingiverse.com/thing:2594618
Step 4: The Software
The code I have used can be found on GitHub: https://github.com/henri98/LoRaWanWeatherStation
I used Atom with PlatformIO to realize this project, so this is a PlatformIO project. I used the folowing libarys:
Step 5: Cayenne MyDevices
You can integrate your application in The Things Network with Cayenne myDevices
To add the integration:
  • Go to the application console on The Things Network website;
  • Select integrations from the top-right menu;
  • Select Cayenne;
  • Follow the instructions
Step 6: Weather Underground
To send data to Weather underground, create an HTTP integration. The data will be sent to the URL with a POST or a GET. The following script captures the data and sends it to Weather Underground. Register your own Personal Weather Station on https://www.wunderground.com/personal-weather-station/signup
<?php
echo time();
file_put_contents('json/post'.time().'.json', file_get_contents('php://input')); $json = file_get_contents('php://input'); $data = json_decode($json);
// take the data out of the json $temperature_1 = $data->payload_fields->temperature_1; $barometric_pressure_2 = $data->payload_fields->barometric_pressure_2; $relative_humidity_3 = $data->payload_fields->relative_humidity_3;
// tempc to tempf $tempf = ($temperature_1 * 9/5) + 32;
// pressure $pressure = $barometric_pressure_2/33.863886666667;
if( isset($pressure) && !empty($pressure) && isset($tempf) && !empty($tempf) && isset($relative_humidity_3) && !empty($relative_humidity_3)){ file_get_contents("https://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?ID=XXXXXXX&PASSWORD=XXXXXXXX&dateutc=now&tempf=" . $tempf . "&humidity=" . $relative_humidity_3 . "&baromin=" . $pressure); }
Step 7: Enjoy Your Weather Station
In Cayenne myDevices you can share a project Dashboard. Share yours in the comments!
This is mine: https://cayenne.mydevices.com/shared/59e9c7612d218c587ba531c4
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    10 Discussions
    thass.hw
    6 weeks ago
    Hello ! Why my result when I uploaded to my node on serial monitor is "Enter do_send" and after that there isn't happening on my serial monitor.
    VaskoT
    4 months ago
    I've try the similar setup with the open IoT - www.i4things.com / https://github.com/i4things - with Heltec LoRa32 hardware, but the power consumption of the ESP32 is not small , switched to Feather 32u4 LoRa and now seems to be OK :)
    erasmus_build
    Question 8 months ago
    Hi, Nice project. I have 5v Arduino Pro Mini boards already in my possession and am hesitant about investing into 3.3v/8mhz, would 5v be applicable with this project? Thanks!
    mutton74
    1 year ago
    Just one (hopefully easy) question.
    I have multiple nodes sending data to thingspeak and cayenne, but would like Weather Underground as an option.
    Where do you use the script you have posted in the HTTP integration of TTN?
    cheers
    mutton
    muitgmutton74
    Reply 1 year ago
    Hi mutton,
    I put the PHP script on a private webserver, in TTN I added the http integration, so all the data is posted to the script on my private webserver.
    Regards,
    Henri
    Michal Choma
    1 year ago
    very nice wifi module. I looking for low power wifi sending, I check that maximum current can be 20 mA. Using esp and regulator it takes a little bit more time to connect everything correct. I looking for something like this: arduino pro mini + low power wifi module + sensors, 1. arduino sleep for 15 minutes 2. measure some values and send to thingspeak 3. sleep again. This module help me, thanks
    muitgDIY Hacks and How Tos
    Reply 1 year ago
    Thank you very much! Maybe in the future. I added a script to read the battery voltage today.
