Lotus Meditation Cube
26,792
264
28
About: Hi everyone! I'm from Canada and just joined the Instructables community. I like to design little ideas that pop into my head.
The idea: I have been dealing with a little bit of run away anxiety and stress lately so I started to practice meditation. One thing that I noticed help me stay present while meditating, was if I placed a candle in front of me and mindfully paid attention to the flickering flame. I built the Lotus Meditation Cube to mimic this positive experience and I am very happy with the results. The Smart LED bulb inside the cube gives you tons of control over how the light is emitted, and this can all be done with an app on your phone. Watching the light transition and pulse as it plays off of the lotus design and surrounding environment is very relaxing. All of the wooden components for the cube were made using a desktop CNC mill. This was my first time using a CNC machine so I was a little nervous but in the end I had lots of fun working on this project. The materials involved are relatively inexpensive and you can knock this out over a weekend. Most of the time involved is just waiting on the CNC machine to mill out your components. The Lotus Meditation cube makes a great night light, home decor piece, and mood lighting as well!
Step 1: Tools and Materials
For this project I used the Nomad 883 CNC mill by Carbide 3D to machine all of the wooden components of the Meditation Cube. As a first time CNC user I was very impressed with the ease of this machine's work flow and accuracy. Any CNC mill you choose to use should be able to make the required components. If you want to design your Meditation Cube from scratch you will also need some sort of CAD software. I tried using Fusion360 since I was already familiar with AutoCAD. Fusion360 is free for 1 year for enthusiasts or startups making less than $80,000 a year. I will provide all of the .stl files for the cube's design in this instructable if you just want to get building and not worry about designing all of the parts.
The materials you are going to need are:
1. Some 3/4 inch pine wood. I don't own my own table saw so I just went to Home Depot and had a 16"x48" board of white knotty pine cut into 8"x8" pieces for me. Link for Wood
2. LED Smart bulb. There are many options out there. Some even have their own built in bluetooth speaker which can be used to play meditation music at the same time. I bought mine off of eBay for $10 CAD.
3. E27 Bulb Socket.
4. Electrical Lamp Cord and plug.
5. 2 1/8" screws 3/4" long and 1 nail 3/4" long.
6. Wood Glue
7. Super Glue
8. Green Painters Tape
9. Double sided carpet tape
10. Tung Oil
11. Sand Paper
12. Round Vinyl Bumpers
Step 2: Design
When designing the meditation cube I made sure to account for the type of wood I would be using, the size of the light bulb, and the milling capabilities of the CNC machine. I decided that I wanted the walls of the cube to have a decent thickness so that the light would look more intricate reflecting off of the inside edges of the lotus design. This is why I went with 3/4 inch pine instead of something thinner which would have milled faster. For the overall dimensions of the cube I went with 6" x 6" faces. This is a good size enclosure to house the LED light bulb and easily fits into my CNC work area which had a maximum size of 8" x 8".
I used Fusion360 to design all of the wooden components. This software is great for quickly bringing your 3D designs to life. There are tons of instructional videos on youtube for Fusion360 which make learning the software a breeze.
In order to create the lotus design cut out of the sides of the cube there are a couple of steps involved. First I quickly sketched out the lotus design with a permanent marker. Next I took a photo of the sketch and opened the photo up in Inkscape. Inkscape is a great free vector graphics editor. You can quickly turn any image into a vector .svg file which is what Fusion360 requires. Just import your image and select path>trace bitmap. Save your new image as a .svg and import into Fusion 360. This is how I laid the Lotus design onto each side of the enclosure and cut it out of the design.
The design has a total of 8 individual components to be milled.
Lotus Cube Side x4
Lotus Cube Top x1
Lotus Cube Base x1
Socket Cover x1
Wired Wedge x1
In Fusion360 export each component as a .stl file in order to produce G-Code for your CNC Mill. I have uploaded all of the .stl files for you to download below. You don't have to use a CAD software to have a 3D view of the .stl files. Your computer should be able to open them up in a native 3D viewer so you can have a better idea of what each of the components entail. For example my MacBook just opens the files up in "preview" which comes free with apple computers.
I have also uploaded the entire Fusion360 design onto the cloud. If you click this link Lotus MC 3D you can have access to a nice 3D view of the meditation cube, as well as download the entire file if you want to make some of your own creative adjustments to the design.
Since the work area of the CNC mill I used is only 8"x8"x3" I milled each component using its own individual setup. If you have access to a larger CNC machine you could potentially mill all of the components in one setup, saving a lot of time.
Step 3: Producing G-Code for CNC Mill
In order to tell your CNC Mill how to machine your components you need to create G-Code files which work out the necessary tool paths and tool path parameters. The "CAM" software I used to do this is called MeshCam. This software comes free with the CNC mill I was using. They also offer a 15 day free trial on their website.
To produce G-Code:
1. Load .stl file of component into the "CAM" software.
2. Define your stock dimensions and the position of your to-be-milled component on the stock. The Lotus Cube faces are all 6"x6" so I centred each component on the 8"x8" pieces of stock pine.
3. Establish appropriate tool path parameters for your CNC machine to mill 3/4" pine. There is a screenshot on this page of all of the tool path parameters I used for the Nomad 883.
4. View the simulation of your tool paths to make sure you are happy with them.
5. Save the tool paths as a G-Code file.
You can use the same G-Code file for the 4 sides of the Meditation Cube since they are identical components. You will need to create an individual G-Code file for each of the remaining components. You should have 5 unique G-Code files in order to mill the 8 Components of the cube.
This Meshcam Tutorial is a great way to learn the fundamentals of the CAM software.
Step 4: CNC Milling the Components
Alright it's time to start using the CNC mill to create all of your components. Since I was using a desktop CNC machine with a somewhat smaller work area I milled the components one at a time. If you have access to a larger CNC mill this process will go by much faster if you machine all of the components at the same time. I will lay out the steps for milling one component. Just repeat these steps for each piece.
1. Apply double sided carpet tape to one side of your 8"x8" stock piece of pine. I was debating whether to use carpet tape or clamps to secure the stock, but in the end was pretty happy with using the carpet tape. Clean up was easier than I expected and the process was very simple.
2. Place the stock onto the waste board of your CNC Mill making sure it is aligned as square as possible. I used one of the extra pieces of 8"x8" pine as my waste board. This allowed the end mill to cut through the stock piece and slightly into the waste board without me worrying about it. Allowing the end mill to cut slightly into the waste board resulted in nice clean edges on the cut out of the lotus pattern. Apply pressure across the face of the stock to make sure it sticks firmly to the waste board. We don't want it slipping during the middle of a cut.
3. Turn on your CNC mill and allow it to go through its homing or start up procedures. On the Nomad 883 this is all done through a controller software called Carbide Motion.
4. Load the G-Code file for the component you are about to mill in the controller software.
5. Use the Controller Software to locate your stock piece of pine. Since we are leaving an inch of excess material around the component I just touched the tip of the end mill against the lower left hand corner of the stock in order to zero the machine.
6. Make sure you have the correct end mill/cutting bit in your CNC machine. I used a 1/8th inch 2 flute ball end mill to mill all of the components.
7. Begin the machining process using the controller software and sit back to watch your CNC machine work its magic. Every now and then I used a vacuum to clear away saw dust as it built up on the part.
8. When'd your CNC mill has completed machining the component turn the machine off.
9. Use a flat edge to gently pry away the excess stock, and then your component, from the waste board.
10. Remove any carpet tape still stuck to your piece.
11. Lightly sand all faces of the component to remove any pine burs and clean up the edges. I used medium grit sand paper and went over each piece for a couple of minutes.
Repeat this CNC milling process for all 8 components of the Lotus Meditation Cube.
Step 5: Assembling the Light Enclosure
Alright, Now it is time to use some wood glue and painters tape to quickly assemble the Lotus Light Enclosure. The photos in this step should help you visualize how this will work.
1. Lay out the 4 sides and top of the light enclosure so that the inside face of each component is facing you.
2. Apply painters tape along all of the edges which will be adjacent to a glued joining.
3. Flip the 4 side components over and position them tightly against each other and against some sort of square surface. I just pushed the 4 pieces up against the back wall of the counter I was working on.
4. Apply a strip of painters tape at each joining. Again make sure when you apply the tape the two edges are snug against each other.
5. Flip the 4 sides over again so that the inside faces of the cube are now facing you.
6. Apply a line of wood glue on all of the 45 degree faces which will be connecting to one another.
7. Carefully fold at each joining until all of the faces are connected into a cube shape and apply a final strip of painters tape on the last joining. The tension of the painters tape on each edge will work to hold each joining tightly in place. This method is quick and easy. It also saves having to use an excessive amount of clamps to get the same result.
8. Apply wood glue to Lotus Cube Top component on all four 45 degree faces.
9. Firmly press the top into the rest of the enclosure and seal all of the edges with painters tape.
10. Rest some sort of weight on the top of the cube as it dries. Or use a couple of clamps to fix the top to the rest of the enclosure. I left the cube in this position over night as the wood glue dried but I am sure you could just wait a few hours and get started with the next step.
This video might help you visualize the glue up procedure a little better
Step 6: Sanding and Finishing
After the wood glue has dried remove all of the painters tape from the enclosure. If all went well you should have a virtually invisible joining at all of the edges. If for some reason there is a slight gap or imperfection in one of the edges this can be easily fixed. First try running a hard smooth surface, such as a screw driver shaft, over the edge to try to close the gap. If this doesn't do the trick just apply a little wood glue into the gap and push some saw dust into it. Then sand over and the gap should disappear. I had a small gap on one corner of the box which i quickly fixed in this fashion.
Once you are happy with all of the edges it is time to sand all of the components. I went over all of the edges and faces with medium grit sand paper. Next i repeated this process with a light grit sand paper to properly prepare the pine for absorbing the finishing oil.
For finishing the cube I decided to use tung oil. I wanted the aesthetic of the Lotus Cube to be simple and natural. I thought tung oil would work well to bring out the grain in the wood and preserve the natural colour and beauty of the White Knotty Pine. This also seals the wood.
To apply the tung oil:
1. Dip a rag or old t-shirt into the oil and apply a generous coat by rubbing the oil into the wood.
2. Take a clean rag and wipe away the excess oil on the surface of the wood.
3. Wait at least 20 minutes before repeating the process. I only applied 2 coats of tung oil. You can apply more if you want your finish to be a bit harder and have more of a sheen.
You don't have to finish your cube in this fashion. You could experiment with some wood stains to darken the finish or change the colour of the cube. I am tempted to try using a stain or darker wood when I make my next one for a friend.
Step 7: Base Assembly and Electrical
Alright, lets start wiring the electrical components of the project. Make sure all this work is done with the plug not connected to power. Also if you have an old lamp or similar appliance that is broken you could just salvage that cord and plug to be used.
1. Cut your lamp cord to a desired length. I made mine about 6 feet long so it had lots of reach when the meditation cube is plugged in.
2. Use an exacto knife to separate the two wires.
3. Use an exact knife or wire strippers to expose the two copper wires. Exposing about 1/2 an inch should suffice.
4. Make a hook shape in both exposed wires and screw them to the inside of your plug. Make sure to take note which side of the wire is hooked up to the gold screw. You will want to wire the same side to the gold screw on the socket. This makes it so one does not receive a shock from touching the exposed wires.
5. Close the plug housing tightly over the lamp cord by screwing it together.
Now to wire the other end of the lamp cord to the bulb socket and fix it to the wooden base:
1. Use an exact knife again to separate the two wires, but this time pull the wires apart much further down the cord (about 2.5 inches)
2. Expose the two copper wires same as before.
3. Tie a knot out of the two sides of the lamp cord.
4. Make a hook shape in both exposed wires and screw to the bulb socket housing. *Remember which side you wanted to fasten to the gold screw*
5. Apply some super glue to the bottom of the bulb socket housing and firmly hold into position on the wooden base. Hold for 10 seconds to allow proper adhesion.
Next hammer a 1/2 inch nail into the small wooden rectangle you milled. I am calling this the wire wedge. Hammer the nail and wire wedge into the wooden base so that it is tight against the knot in the lamp cord. When you tug on the cord you want the knot to pull against the wedge. There should be zero tension on the split wires actually fastened to the light socket when the cord is pulled. This will make the base much more resistant to damage should the cord accidentally receive a rough pull.
Apply some round vinyl bumpers to the bottom of the wooden base to stop the lotus cube from slipping around when on a smooth surface. This also reduces the chance of scratching any surfaces you might be putting it on.
Finally, fasten the wooden socket cover onto the base using 2 3/4" screws. The lamp base is now complete.
Step 8: LED Smart Bulb Remote Enclosure
This step is completely optional since I have a feeling most people will operate the LED Smart bulb with the app on their phone or computer which comes with the light. The LED Smart bulb I ordered also came with its own little remote to use if you don't have your phone handy. The remote has less features than the app provides, but you are still able to cycle through colours, change transition types, turn the light on and off, etc.. Since I had a lot of fun designing and building the Meditation Cube I decided to quickly design and build a wooden casing for the remote so it matched the aesthetic of the cube.
Step 9: Plug It in and Start Playing With the Light!
Your Lotus Meditation Cube is now complete! Just place the wooden enclosure on the base and plug it in. The LED bulb is completely cool to the touch and safe to leave on inside the box. You will be able to turn it on using either the app on your phone or the little remote. Have fun playing with all of the different colours and transition settings. The phone app is amazing because it gives you tons of control over the way the light performs. You can cycle through hundreds of different colours and adjust the timing of the different transitions. When meditating I actually like to have the cube set on one colour and slowly pulse on and off at a speed that feels natural with my breath. This is great for staying focused on the present and mindfully paying attention to the light. When I have the cube set up as a night light or for mood lighting I just let it cycle through the array of colours using the smooth setting.
I had tons of fun building this project and actually found the process quite relaxing. It was my first time using a CNC mill and first time writing an instructable so I ended up learning a lot. Seeing a design idea come to fruition as something tangible was really satisfying. In the end the most challenging part of the project was trying to get quality photos of the Lotus cube which showed how great it looks in person lol. I still feel like I struggled to achieve this.
If anyone wants to attempt building one and has any questions do not hesitate to contact me. I would love to see someone else have a go at this project! I am going to try building another one as a Christmas present for a friend. This time I want to try dark walnut wood and put a battery enclosure in the base so it is more portable. I will load some photos of this when I complete it.
Thanks for reading!
Jeeves
CNC Contest 2016
Runner Up in the
CNC Contest 2016
First Time Authors Contest 2016
Second Prize in the
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    28 Discussions
    NicolasD107
    1 year ago
    Hey did u have the file inskape of the lotuse ?
    hankus
    2 years ago
    I wanted to make this my first project on my Nomad 883 Pro, but I'm having lots of problems. I'm using the 1/8" ball nose bit that came with my Nomad but the full depth of cut used is equal to the board thickness so it doesn't cut cleanly through the 3/4" pine. Also there are numerous "islands" left in the middle of the larger cut outs which pose a problem when then eventually break and wedge the cutter. I've attempted to cut one side 3 times now and this last time I thought I had it after watching it cut for over an hour, removing sawdust along the way, and at 99% the final cleanup passes near the center of the piece started breaking through to adjacent cut outs and ruined the effort. I followed your mesh cam settings exactly, and every other process you described but not doing to good. Are there any changes you might suggest to make to the settings you used?
    Jeeves Thommyhankus
    Reply 2 years ago
    Hey Hankus I just sent you a message on the Carbide Forums
    Peshy
    2 years ago
    This is really awesome! I've been looking into getting myself a CNC mill. Its really inspiring to see what you've been able to do with it, especially after only a few weeks! You may have been the breaking point of me picking one up, if I do I'll make this my first project.
    Thanks for the awesome instructable!
    Jeeves ThommyPeshy
    Reply 2 years ago
    That means a lot Peshy! Yeah I was pretty nervous about getting started with a CNC mill but the learning curve isn't bad at all. Let me know if you decide to make one.
    biggy boy
    2 years ago
    Thanks for the great instructable!
    Do you have the original Fusion 360 files?
    I'd like to cam the project in Fusion. I've tried to do it with the STL files
    But I can't figure out how to cam the tool path from an STL file format.
    Thanks
    Glen
    Jeeves Thommybiggy boy
    Reply 2 years ago
    Cheers Glen! Yes I have the Fusion 360 Files. I will try to send it to your inbox now. If you make it please send me a photo. I would love to see it.
    biggy boyJeeves Thommy
    Reply 2 years ago
    Thanks for the 360 file. I placed my vote for you! I'm looking forward to future Instructables from you!
    Jeeves Thommy
    2 years ago
    Hey everyone, thanks for all of the positive comments :)
    I have received a few requests for the original Fusion360 file of all of the components to help with building the meditation cube. I just uploaded the Fusion360 file under 'Step 2 Design' in the instructable if you want to download. Hope this helps out.
    AMDHamm
    2 years ago
    Great idea and looks awesome! I would love one of these. I am going to see if I can find anyone (local service) that could cut it for me (I have no CNC). Otherwise I would have to cut it on a scroll saw. Wonder how much trouble that will give me. LOL! My other half does 3D printing but I am a wood-lover, so I would prefer wood over plastic. One day I hope to get a CNC (move over 3D printer!). Our local Woodcraft had CNC and laser services but sold the units when it from franchise to corporate store. I think the panels I can hand cut on a scroll saw but that round base would be a bit of work to cut and hand carve. Thanks for sharing! Please share the walnut one when you make it!
    Jeeves ThommyAMDHamm
    Reply 2 years ago
    Cheers! If you knock one of these out on a scroll saw I would love to see it. As for the round base being tricky. It is only round for aesthetics. You could definitely just make it square and have it cover the light socket the same way. I think this would look great too. Yeah I am excited to make one out of walnut in the new year. I think the dark wood would look really nice. Thanks again for the positive comment. Let me know if you make one.
    Aemartin15
    2 years ago
    This looks incredible! Do you know if there are any companies that you can send the files to in order to get the pieces milled? I would love to make one of these, but I don't know how to get ahold of a CNC machine.
    Jeeves ThommyAemartin15
    Reply 2 years ago
    Thanks Aemartin! To be honest I am not sure. I just got access to a CNC mill for the first time a few weeks ago, and I am very new to the CNC world. I feel like this is a service that should definitely be available though. I just have no idea who does it or what they charge lol. Maybe if you don't have any luck finding someone to do it for you, I could try to help you out in the new year when I am on the CNC mill again. If you found someone with a larger CNC mill they could probably mill out all the pieces at the same time pretty quickly. The mill I was using was a desktop mill which required me to do a new set up to mill out each piece. Excellent CNC mill for using indoors, but smaller work area means the milling process takes longer. Let me know if you have any success finding someone to mill the parts for you. I would love to see someone else have a go at this project and let me know how it works out for them :)
    Jeeves Thommyemcintyre2
    Reply 2 years ago
    That would look really cool. Pease send me a picture if you do
    Oncer
    2 years ago
    This is just lovely. Thank you so much for sharing. I actually posses one of these colour changing LED bulbs with the remote you showed and use it as ambient light behind the telly but never thought of using it for meditation. Thank you.
    Jeeves Thommy Oncer
    Reply 2 years ago
    Thanks Oncer! Yeah It works really well for meditating, for me anyways. I am glad you like :). Thanks again for the positive comment!
