Low Cost Water Flow Sensor and Ambient Display
183,496
194
64
Water is a precious resource. Millions of people do not have access to clean drinking water, and as many as 4000 children die from water contaminated illnesses every day. Yet, we continue to be wasteful with our resources. The overarching goal of this project is to motivate more sustainable water use behavior and raise awareness about global water issues.
This is an instructible on how to crudely detect water flow in a pipe and drive an ambient display. I am using a piezo transducer, some LED's and an arduino. The device is a rough prototype of what will eventually become a persuasive technology that motivates sustainable behavior and raises awareness about water use.
This is a project by Stacey Kuznetsov and Eric Paulos at the Living Environments Lab, at Carnegie Mellon University Human Computer Interaction Institute.
Produced by
Stacey Kuznetsov
stace@cs.cmu.edu
http://staceyk.org
Eric Paulos
eric@paulos.net
http://www.paulos.net/
http://www.living-environments.net
The video below illustrates a previous version of this project, where a microphone is used instead of a piezo element to detect water flow. You will achieve better performance when using a piezo transducer, so this instructible details the piezo approach.
Special thanks to Briam Lim, Bryan Pendleton, Chris Harrison and Stuart Anderson for help with ideas and design of this project!
Supplies:
Step 1: Gather Materials
You will need:
- Breadboard
- Microcontroller (I used an Arduino)
- Mastic
- Piezo Transducer (http://www.radioshack.com/product/index.jsp?productId=2062402)
- A few LED's (I used 2 yellow, 2 red, 2 green)
- Candle holder or similar-sized container
- Wire
- 1 Mohm (or other large value) resistor
- 4.7K Resistors (3)
- 1K Resistors (1)
- Low-value Resistors (for the LED's)
- Clipping Wires
- Jumper Wires
- Mastic
- op amp (LM613)
Step 2: Build the Circuit
The circuit consists of an amplifier to increase the signal from the piezo and a voltage divider to lift the base voltage.
There is a high-value resistor between the two inputs form the piezo, which acts as a pull-down resistor for the signal.
Step 3: Test the Circuit
Attach the piezo to the circuit, and hook up the arduino.
The voltage divider sets the base voltage at 2.5V, so the base readings for the signal should be around 512 on the Arduino analog pin (half way between 0 and 1023). Mine fluctuates +/-30 around 520. You may see some fluctuation around this number.
Step 4: Calibrate Your Sensor to Detect Vibrations
When the tap is turned on, the vibrations of the pipe will cause the piezo to generate a fluctuating current. Since the base reading tapers off around 520, you can compute an amplitude around this number to detect vibrations. My threshhold is set at 130, but you may increase or decrease this depending on the types of vibration you want to sense and sensitivity of your particular piezo piece.
To test the signal, use mastic to attach piezo to a flat surface. Try tapping or scratching on the surface at different locations and different intensities see what type of readings you get on the Arduino.
To reduce noise, I recommend computing a moving average of the input. This is a crude way of determining wave amplitude that avoids false positives due to random static current. More advanced methods such as FFT may also be used.
// Sample Code
int sensor = 2; // Analog in
int val =0; // Current reading for analog pin
int avg; // Running average of the wave amplitude
int MIDPOINT = 520; // Base reading
void setup() {
Serial.begin(9600);
avg = MIDPOINT; // set average at midpoint
void loop() {
val = analogRead(sensor);
// Compute wave amplittue
if (val > MIDPOINT) {
val = val - MIDPOINT;
} else {
val = MIDPOINT - val;
// compute running average fr the amplitute
avg = (avg * 0.5) + (val * 0.5);
if (avg > 130) {
// vibration detected!
Serial.println("TAP");
delay(100); // delay to ensure Serial port is not overloaded
Step 5: Create an Ambient Display
If your sensor is working properly, you can add an ambient display to show the information.
My LED's are paired such that each color is illuminated by two LED's. To do this, attach the 'in' (short) lead of each color together, and use a low-value resistor before connecting to the Arduino. Connect the ground (longer) lead of all LED's and attach to ground on the Arduino.
Once the LED's are connected, use the candle-holder to house the display. Since the candle holder is made of aluminum, you may want to put an insulator such as a piece of plastic, on the bottom of the container before inserting the LED's to prevent the circuit from shorting out.
Step 6: Use Sensor Data to Drive the Display
It takes me about 10 seconds to wash my hands. Thus, I have programmed the display to show a green light for the first 10 seconds after the tap is turned on. After 10 seconds, the yellow LED"s turn on. The display turns red if water remains on after 20 seconds, and begins flashing the red light if the tap remains running for 25 seconds or more.
Use can your imagination to create alternative displays!
Step 7: Mount the Sensor and Display Onto a Water Pipe
Use mastic or clay to attach the piezo to the tap, and another layer of mastic to secure the display on top.
You may have to readjust your threshold amplitude or 'MIDPOINT' from step 4. The signal may also be slightly affected by the temperature of the pipe.
Step 8: Future Suggestions
You may choose to drive the Arduino off a battery. An upcoming tutorial will show you how to run this display by drawing power directly from the running water itself, or by harnessing surrounding ambient light energy!
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    64 Discussions
    MonishaV3
    Question 4 months ago on Step 8
    With this method Will I be able to detect water flow in a pipe
    (non-invasive method) say PVC or Copper ??
    ralphshaw
    Question 1 year ago on Step 1
    Hello inventor
    Seen your water flow sensor, it's very good.
    Is it possible to use a similar device to know if there is water flowing in a closed pipe, say copper heating pipe at home or, bigger pipes in plant rooms etc.
    Also, it would be really great if it can be connected to a smart phone.
    Thanks for your time.
    Kind Regards,
    Ralph Shaw
    donfrench
    1 year ago
    What do you reckon is the smallest flow you can reliably detect? The application I have in mind is a leak detector for a vacation home, where a leak might be very small. A gallon a day can do an enormous amount of damage to a home if left unattended for nine months, for example. Any thoughts on this?
    mohits104
    2 years ago
    yeah its work !!
    Is this applicable for detecting small and very small water flow? When water are leaking (drops and more)???
    Thx ,
    miroslav
    Emperor Dane
    10 years ago on Introduction
    wait, is this the same stacyk from News SH? awesome instructable., really well done. as an alternative to an electret mic, you could also use a headphone speaker as a microphone. i'm so going to put one of these in my apartment. and integrate usage over the course of the day, VU meter style Dane dklabs.co.nr
    chnvravitejastaceyk
    Reply 6 years ago on Introduction
    hello
    It's nice to see this innovative project. actually in my project i want to include this one and i want make this flow sensor.....can u help me in making prototype of this and what would be the cost to make this prototype?
    jagdishparmchnvraviteja
    Reply 3 years ago
    Aapne banaya hai kya ye or kya ye high temperature par bhi work karta hai plz give me your mob. No. Or contact 08349990591
    be aware that in an apartment, you will be detecting the vibration from your neighbors water use, as well as sampling some of the vibration of the in-wall heating systems, (some systems are so close together you may get a bleed-over effect, especially of the heating system is hot water and uses zone pumps.)  you might want to wrap your pipes where they come through the wall with a lead collar, or use mastic (RTV) to seal the pipe and the wall so that the house structure dampens these extraneous vibrations and gives you an accurate reading of just your usage.
    HAL 9000
    4 years ago on Introduction
    I love the idea of having realtime feedback on one's water usage! One of the most important things that I've learned while in school has been that the best way to learn something (whether it's how to solve a calculus problem, programming syntax, etc.) is having immediate feedback and corrections for everything you do. it prevents you from continuously making mistakes. I think something like this implemented in every home could really reduce water/energy consumption, as opposed to seeing your water use in a monthly bill (which is hardly immediate at all)
    HAL 9000HAL 9000
    Reply 4 years ago on Introduction
    of, like you said: "persuasive technology that motivates sustainable behavior"
    baezl
    9 years ago on Step 4
     Hey I really liked your project so I wanted to try my own. I think I have all my parts write but its not working. Can you help me out?
    stonebits
    5 years ago on Step 2
    Thanks for posting this -- it's exactly what I was looking for: doesn't require interacting with pluming, "reasonably" low cost, and I can even get the parts at Radio Shack.
    taufique_
    6 years ago on Step 2
    It so happens that you forgot to label R1, R2, R3... with their respective values. Could you please look into it? Thanks.
    99889900
    The 8 pin IC is used in the showed pictures is not a Lm316! what is it?
