MAKE a Table Out of a Tree Stump
2,632
5
Making something out of nothing is always fun. Here in this instructable we’re taking an old tree stump that we removed out of our yard with a backhoe. With as much work as it took to get this tree stump out of the ground, it would be a shame to let this go to waste. With a chainsaw we transform this old stump into a coffee table with character. We will use a very large wooden nickel from an oak tree that fell through my parents house in hurricane Katrina. I think you will enjoy the process of this transformation into a usable piece of artwork.
Step 1: Find Your Stump
We uprooted a wild cherry stump. So lets make a table base out of it!!
Step 2: Chainsaw, Chainsaw, Chainsaw
And chainsaw, There is a lot of work to do with the chainsaw. Level the bottom and the top of the stump so it can sit flat and level! Make sure you have the proper safety equipment before using the chainsaw.
Step 3: ​Final Touch Up
Use a level to make sure you have it flat. Now lets put on the top
Step 4: Put on the Top
We are using a big wooden nickel that we got from a tree that fell thought my grandparents house and split it in two!! So now the top of our table has a story! It would be cool to use a glass top but we don't have one, but you could put one on yours!
Step 5: Finished
Now you have a table that you made from a tree stump!! Enjoy!! :)
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    3 Discussions
    memestra
    Tip 6 months ago on Step 2
    The easiest way that I have found that to make a level cut on a complex shape like this it to do it with water. Start by making sure your object (stump) is dry. Next, find a large enough body of water that you can can dip it partially in. Holding the object upright in what you want to have as your finished position, dip it in as deep as you want to cut off. Voila! The water level will leave a perfectly level line around a complex shape! Use a pencil to trace around the water line and cut that line.
    doing2muchmemestra
    Reply 5 months ago
    Wow, what a fantastic idea! For a moment, I was a little confused as to why you mentioned water right after the need for it to be dry! The water only touches what will be removed...
    Gadisha
    7 months ago
    Nice, I love anything made out of a tree stump :)
