MEDIEVAL SHACKLES/CHANDELIER
9,930
71
11
About: Art made from scraps. Instagram: Ollysartsnscraps
How to make Medieval style shackles
for tools you will need:
  1. welder(or other means of fushion)
  2. grinder
  3. cut disc's
  4. flapper disc's
  5. pliers
  6. wire brush
  7. clamp
  8. a vice is always handy too
For materiel you will need
  1. section of 4" tubing
  2. two 1" hinges
  3. two latches
  4. chain
Step 1: Cutting and Grinding
Take the pipe and cut a 1" ring out
using the grinder and flapper disc shine it up
Step 2: Cut
Cut a single line into the ring,  keep it in the vice as is.
move on to next step
Step 3: Bend It
using the other piece of the pipe, a hammer and a clamp bend the hinge to the shape of the pipe
Step 4: Welding Time
Tac Weld in the holes.
Step 5: Shine It Up
Using the flapper disc grind your tac welds away smooth.
Step 6: Add a Latch
Time to tac weld the latch onto the shackle the same way we did the hinge.
add ball
a ball and chain
give it to your ball and chain
whatever you'd like
and little pad locks and your set
Step 7: .....
The big pair I made years and years ago. They are not with us anymore.
Step 8: Make Something
I used three shackles to replace the little poles that keep my light shade on. To do this I had to weld little hooks on the opposite side of the shackle then the chain. Then connecting through shade. Turn on the lights and you have medieval shackle chandelier .
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    11 Discussions
    Cgas21979
    Question 7 months ago on Step 2
    Cut the pipe with what?
    Tazmjm69
    5 years ago
    Nice job!
    iOskr
    7 years ago on Introduction
    Good work man!!! I want ones for my husband XD
    Kaiven
    How should the latches be locked? With a simple padlock? That's really neat, I like the look!
    Dr.DuckhuntKaiven
    yup just little padlocks, there are some pretty intents padlocks such as penny padlocks, some really unique ones
