MIDI Controller With Keyboards
27,016
229
33
About: www.youtube.com/EvanKale91 === www.facebook.com/EvanKale91 === www.twitter.com/EvanKale91 === www.evankale.blogspot.ca
Today we're building the 400 key MIDI controller using an Arduino and computer keyboards!
For the budget conscious music producers out there, this project is a great way to build an inexpensive control board for your digital audio workstation.
Or if you're just a musician with an odd taste for instruments, this geeky looking device will surely give you some strange looks.
Supplies:
Step 1: Watch the Video!
Check out this quick video to see how this mega MIDI device translates to an instrument and for a run-through of all the steps below from start to finish.
Click here to watch on YouTube
Step 2: What We'll Need...
We're going to build a box that translates signals from multiple keyboards into standard MIDI out signals.
To do so, we'll need:
  • An Arduino (I'll be using the UNO, but any other variants will work fine)
  • 2 PS/2 ports (as many as you'd like, as long as there's enough digital pins on the Arduino for it)
  • MIDI female port
  • Cardboard
  • A 220Ω resistor
  • Perboard
  • Wires
  • Keyboards!
Where to buy
Soldering gear:
Testing gear:
Step 3: Prepare the PS/2 Ports
Push a piece of perfboard through the bottom pins of the PS/2 ports to make soldering easier.
Clamp the PS/2 ports in place and solder wires to the four pins of each of the PS/2 port that we need to access (they are the Vcc, Ground, Clock, and Data pins - see diagram).
Hot glue the PS/2 ports together.
Step 4: Prepare the MIDI Port
Push a piece of perfboard through the bottom pins of the MIDI port to make soldering easier.
Add a 220Ω resistor in series to the Vcc pin (see diagram).
Solder wires to the three pins we need to access (they are the Vcc, Ground and Serial pins - see diagram).
Step 5: Wire Up the Arduino
Wire the PS/2 and MIDI ports to the Arduino as follows:
For the PS/2 ports:
  • Vcc pins goes to 5V
  • Ground to GND
  • Clock and Data pins goes to digital pins 4 to 11
For the MIDI port:
  • Vcc pin goes to the 220Ω resistor, then to 5V
  • Ground to GND
  • Serial to TX
Step 6: Upload the Arduino Program
I've made the source code to this project open-source, so simply head over my GitHub to download the Arduino sketch:
https://github.com/evankale/ArduinoMidiPS2
Plug in the Arduino to the PC, open up the sketch in Arduino IDE, and upload the program to the Arduino.
Step 7: Make a Box
Cut out a cardboard box template that fits all the components.
I decided to expose the MIDI and PS/2 ports in the front of the box while the Arduino USB port through the back so that it can be USB powered or reprogrammed easily.
Hot glue the components into place.
Step 8: Close Up the Box
Close up the box with some PVA glue, and admire your work of art.
Step 9: Find Keyboards
Just for fun, I decided to attach three old keyboards together with some wood pieces and screws.
Attach two strap buttons, put on a strap, and we have a very unique "keytar" to go with our MIDI box.
Step 10: Plug It in and Give It a Test
Plug in as many keyboards as you'd like and give it a test!
Watch the video to see the MIDI controller in action.
That's all I have for you today!
If you liked this Instructable, then perhaps you'll like some of my other projects!
You can check them out over at my YouTube channel.
New projects every Thursday! See you next week!
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    33 Discussions
    tushar5806
    Question 10 months ago on Step 10
    How to connect that MIDI port to desktop computer ?
    Or How to get output from MIDI port?
    Tituscenation
    Question 1 year ago on Step 10
    What is the software u are using at the last while playing...
    harrycool
    1 year ago
    Is there any way to use USB Type B port instead of MIDI, cuz I already have an Uno and don't wanna waste anything. Plus, anyway to use it with an USB keyboard instead of PS/2?
    SirQuintus
    1 year ago
    So I know I got the circuit right and everything, I set up my MIDI program, and I can see that I'm getting a MIDI signal coming to my computer from the keyboard, but nothing is registering in my actual software. I've tried to do everything I can in the actual MIDI software but nothing is working. Is there something weird in the code that I need to change or anything?
    roclish_rola
    2 years ago
    the ps2 keyboards wont power up, I guess I messed up something with the code, cause I included the magicmusic library by selecting zip file, but when I copied the code from the link the magicmusic instructions are not colored i.e. the system is not detecting the instruction
    those who sucessfully built this please help me out to figure out where i went wrong
    I_O_STREAMroclish_rola
    Reply 2 years ago
    i was having trouble with that too but when i went up to the top menu bar under the sketch tab there is an option called add file that i added all the stuff in the zip file except the readme and it complied for me
    Amit0710
    2 years ago
    Roses are red,
    Violets are blue
    U are so funny,
    And I like You????
    roclish_rola
    2 years ago
    you are using a mega uno arduino, what if I have uno R3
    roclish_rola
    2 years ago
    the ps/2 keyboards wont power up, I am using a clone arduino ;could that
    be a problem?
    Also you have have messed up the connections, first of all your diagram
    shows connections from a ps/2 plug instead of ps/2 socket that you
    demonstrated, also your code mentions the clock pin & data pin to be
    different than that of your connection,
    please clear out the confusion, I really need to build this
    ngmacha
    3 years ago
    Great project and good instructables, thank you Evan! I've built it too, though not without a bit of stumble - your diagram needs to clarify that the PS2 connectors are shown looking from the back of the female connectors, where the wires are soldered... I'm using the TurtleBeach MIDI-to-USB converter and the Universal Keyboard apps on the Windows 10 tablet, and everything works perfectly. Just a question: do you or anyone out there knows of the apps for SurfaceRT tablet that can play form MIDI port?.. That would be a perfect use for this abandoned but otherwise great tablet!..
    DahaiP
    3 years ago
    I like it.
    One quenstion,
    The connectors in circuit diagram are front view or back view?
    WYLMAS
    3 years ago
    Just wondering, is there any possibility to use Arduino's USB port to connect it as a MIDI device? It would be a great feature (obviously some more coding would be needed) as some of those cheap MIDI to USB adapters might have some unwanted latency. The one adapter I have (then connected to a MIDI keyboard) do have more latency compared to the USB MIDI keyboard (the one that is connected through USB and do not have MIDI port at all).
    Why do I have this question? I've never had my hands on any of Arduino boards at all, therefore I don't know all of it's features.
    szymex73
    3 years ago
    Is there an MIDI to USB converter that i can use with this? I don't have midi port unfortunately
    WYLMASszymex73
    Reply 3 years ago
    Probably those cheap MIDI to USB adapters found on ebay would do. I have one shipped from China and I've used it with an old Yamaha MIDI keyboard. Costed no more that £2. It should work with this project too, but you probably have to map it on the DAW yourself (I mean to map certain keys to do certain commands).
    iratozer
    3 years ago
    I am very impressed with your "Multi-Keybord" instrument.
    Do you know of any way to take a graphic equalizer and send each filter section to an amplifier that will drive a speaker for each frequency range?
    bob8898
    3 years ago
    Can you make a version that uses USB keyboards instead?
    AndersJ3bob8898
    Reply 3 years ago
    As Istarian wrote, there are USB to PS/2 adapters you can use if you have USB keyboards.
    Istarianbob8898
    Reply 3 years ago
    That's not as simple as it sounds. For one, you'd need a USB host controller to be able to talk to your USB keyboards. Also, at minimum you'd probably have to write a USBDevice class that provided/exposed the same read/write/etc functions as PS2Device. I have no idea what level of difficulty is involved, but a USB host shield usually only provides one keyboard so you'd need a usb hub too in that case and I have no idea if those shields are compatible with hubs.
    Alternatively, you might be able to use several USB->PS/2 adapters to convert the USB into PS/2.
    JohnB432
    3 years ago
    Controllermate for mac can make any usb keyboard into a midi controller. It's incredibly versatile, very straightforwards, and costs about $20.
