Machine Learning With Raspberry Pi
75,592
83
6
Hi,
This is my first Instructable and moreover my English is not good. So please don't mind if it is not well written.
Background:
Deep learning is a new hot topic in the area of Machine Learning, that shows promising results to achieve artificial intelligence. These days we hear a lot about Machine Learning algorithms from big companies like Google and facebook. But recently a startup called Jetpac brought an iphone app that makes even lay person to use Machine learning. Now the same startup has ported their Deep Learning algorithm called Deep Belief to Raspberry Pi. Although, Pete Warden, the CTO of Jetpac, has given instructions on Github, there are some small changes required to adopt to install it on Raspberry Pi. Therefore, I am writing this instructable.
Supplies:
Step 1: Allocating RAM to GPU
This deep belief software requires, at least 128 MB of RAM. In order to allocate that memory, edit the config file of Pi, by using the following command.
sudo nano /boot/config.txt
Add the following line at the end of the file
gpu_mem=128
Now reboot the Pi.
sudo reboot
In case. if you did not install git before, install it
sudo apt-get install git
Step 2: Install Deep Belief Image Recognition SDK on Raspberry Pi
Now we can install the Deep Belief SDK, by following the below instructions
git clone https://github.com/jetpacapp/DeepBeliefSDK.git
cd DeepBeliefSDK/RaspberryPiLibrary
sudo ./install.sh
Step 3:
Inorder to check whether it is installed correctly or not, follow the below instructions:
cd ../examples/SimpleLinux/
make
sudo ./deepbelief
That should give the following out put
0.016994 wool
0.016418 cardigan
0.010924 kimono
0.010713 miniskirt
0.014307 crayfish
0.015663 brassiere
0.014216 harp
0.017052 sandal
0.024082 holster
0.013580 velvet
0.057286 bonnet
0.018848 stole
0.028298 maillot
0.010915 gown
0.073035 wig
0.012413 hand blower
0.031052 stage
0.027875 umbrella
0.012592 sarong
This is basically telling that the algorithm is analyzing the default image in the library and giving the probability of it being sarong and umbrella. This algorithm is very useful in robotics. I am trying to implement this on my Raspberry Pi Robot soon. You can find more details on my blog.
Credits:
Pete Warden
https://github.com/jetpacapp/DeepBeliefSDK/tree/ma...
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    6 Discussions
    hackedu280
    1 year ago
    in on raspberry pi3 / debian jessie / updated......
    Keep getting error. below is what i get when i use the make command.
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ make
    gcc -o deepbelief ./main.c -L/usr/lib -ljpcnn
    ./main.c:11:22: fatal error: libjpcnn.h: No such file or directory
    #include
    compilation terminated.
    Makefile:14: recipe for target 'deepbelief' failed
    make: *** [deepbelief] Error 1
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ ls
    jetpac.ntwk lena.png main.c Makefile
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ makefile
    bash: makefile: command not found
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ sudo make
    #include
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ (keep getting same error)
    hackedu280hackedu280
    Reply 1 year ago
    ok so i got ahead of myself and skipped a section is why this error came out.
    but now im having this error and i know i did everythign right? it will not open
    $ Can't open device file: /var/lib/jpcnn/char_dev <------ the issue as below
    pi@raspiFlex:~/Desktop/DeepBeliefSDK $ cd RaspberryPiLibrary
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ ls
    install.sh libjpcnn.h libjpcnn.so
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ sudo ./install.sh
    libjpcnn installed
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/RaspberryPiLibrary $ cd ../examples/SimpleLinux/
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ sudo ./deepbelief
    deepbelief jetpac.ntwk lena.png main.c Makefile
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ ./deepbelief
    pi@raspiFlex:~/Desktop/DeepBeliefSDK/examples/SimpleLinux $ leafpad /var/lib/jpcnn/char_dev
    anyhelp would be great thanks
    oliver20170701
    1 year ago
    Hi, great instructable !
    I followed all the instructions but when I entered “sudo ./deepbelief” for the last command it gave me the error,
    “Can’t open device file: /var/lib/jpcnn/char_dev”.
    Any assistance on how to fix it would be greatly appreciated!
    kauffman214oliver20170701
    Reply 1 year ago
    cd ~/DeepBeliefSDK/source/src/lib/pi/
    vi mailbox.cpp
    (change #define MAJOR_NUM 100 to #define MAJOR_NUM 249) / save
    sudo rm -rf /var/lib/jpcnn/
    make clean
    make TARGET=pi2
    sudo cp libjpcnn.so /usr/lib/
    sudo cp src/include/libjpcnn.h /usr/include/
    cd ~/DeepBeliefSDK/examples/SimpleLinux/
    make
    sudo ./deepbelief
    scshepard
    1 year ago
    Hi, nice set of directions; I'm falling into a different hole; when making the SimpleLinux directory for the "deepbelief" executable, I get the error:
    /usr/lib/libjpcnn.so: file not recognized: File format not recognized
    Seems to be ELF 64-bit library, not the 32-bit for the other libraries. Any ideas??
    Thanks!
    jcrist70
    1 year ago
    I have the same issue as posted below/above. I'm using a fresh copy of Raspbian and a Pi 3. Please advise.
