Make a Simple Operating System
163,244
1,036
95
About: I build products which solve real world problems.
Ever wanted to make an Operating System? Ever waned to know how command line operating systems work? Everything's here!
So we'll make a basic Operating System in C#, don't worry, if you even know some basics of c++ or java, you'll understand the code :D
By end of this tutorial, you'll be able to make your cool operating system!
So lets begin with some ind
Supplies:
Step 1: The Concept
So, how actually a OS works? I'll explain from the level of a electric circuit.
Most of you know logic gates in electric circuits. when many logic gates are connected, i.e. billions of transistors are connected together inside a chip, they can store 0s and 1s. Each gate could store either 0 or 1.
Then the connected transistor forms a Micro-Controller or a Micro-Processor. Here we are going to program on the micro-processor which is in your computer.
Did you know that your computer can also run with a operating system!? Wonder how! Every chip in your computer can run individually without a microprocessor but then without OS, it can't do multi tasking or run multiple threads together like in simple words, play a video in which one time music can play and one time graphics can play. But both can't run together.
Because of an operating system, today you can listen to music while browsing the internet.
The OS works based on its kernel. The kernel stores all the library files and whenever we run a program, the program's code calls header files from the kernel. In windows, kernel is 'Win32'
Step 2: Materials and Prerequisite Knowledge
What will you need-
1) Microsoft Visual Studio 2012/2013/2010 (Any Edition)
Link: https://www.visualstudio.com/
2) COSMOS User Development Kit Milestone 4 (C# Open Source Managed Operating System)
Link: https://cosmos.codeplex.com/downloads/get/90082
3) Any Virtulization Software to run the OS. I'm using VMware Player.
Perquisite Knowledge-
Basics of C++, Java, .net would work
I just request to just browse some 5-10 basic online tutorials of c# so you can get a better understanding
Step 3: Introduction to COSMOS
Cosmos (C# Open Source Managed Operating System) is an operating system development kit which uses Visual Studio as its development environment. Despite C# in the name, any .NET based language can be used including VB.NET, Fortran, Delphi Prism, IronPython, F# and more. Cosmos itself and the kernel routines are primarily written in C#, and thus the Cosmos name. Besides that, NOSMOS (.NET Open Source Managed Operating System) sounds stupid.
Cosmos is not an operating system in the traditional sense, but instead it is an "Operating System Kit", or as I like to say "Operating System Legos". Cosmos lets you create operating systems just as Visual Studio and C# normally let you create applications. Most users can write and boot their own operating system in just a few minutes, all using Visual Studio. Milestone 5 includes new features such as an integrated project type in Visual Studio, and an integrated debugger. You can debug your operating system directly from Visual Studio using breakpoints. Cosmos is available in two distributions, the developer kit (dev kit), and the user kit. The dev kit is designed for users who want to work on Cosmos itself. The user kit is designed for those who are interested in building their own operating system and doing some Cosmos work. The dev kit might be thought of as the Cosmos SDK. Most users should start off with the user kit as it is not so overwhelming like the dev kit. This article focuses on the user kit.
Step 4: Writing Your First Operating System
So, first lets write a OS which can simply print some text on screen!
So first of all, install all of the software required that is mentioned in the previous step.
1) Open visual studio and navigate to File>New Project
2) In the new project dialog box, select COSMOS and then COSMOS Project in the templates box. Name the project and click OK!
3) Now you'll see a file "program.cs" in the solution explorer. Click and load it.
4) You'll see a whole lot of code in it, don't be scared, we just need to edit code under "public static void Init()" block only :D
5) Now click on start button you see on visual studio toolbar or from Debug menu, click "start debugging"
6) You'll see a COSMOS Builder window appear, without any modification, just boot click build
7) WOW! So that QEMU window appear? QEMU is actually a operating system emulator so you are seeing the code being executed. Now lets make some modifications and personalize the OS.
Step 5: Personalizing the OS
Now just make some simple changes in code,
under public static void Init(),
Change Console.WriteLine("Welcome! You just booted C# code. Please edit Program.cs to fit your needs"); to Console.WriteLine("Hello World! This is my first operating system");
So, you've changed Welcome! You just booted C# code. Please edit Program.cs to fit your needs to Hello World! This is my first operating system.
We've just edited the text. Now lets compile the code and see the output. Perform the steps in previous step to compile the code.
Saw that! Text has changed! you can even put your name here. Congrats! you've won half the battle by understanding the basics. But how about a operating system that takes input from user and gives user a output? Just like command line operating systems or Linux terminal.
Step 6: Making a Command Line OS
So here we'll make a command line operating system. As we saw the previous code, the code just writes some text on screen via Console.WriteLine() function. Now we will write a OS where the user gives the input and the computer processes it.
So, lets make a code which prints Hello User! Thanks for using this operating system! when we give hello as input to the computer.
In programming, there are different kinds of loops which most of you know like If loop which does the action if the conditions are met. So here will will use if loop and if the input of a user is hello, then it will print the line we mentioned above.
CODE:
string input;
input = Console.ReadLine();
if (input == "hello")
{ Console.WriteLine("Hello User! Thanks for using this operating system!");
Here in this code, we made a string named input in which we read some data. The If loop checks that if the input matches the word hello, then it should print Hello User! Thanks for using this operating system!
Now lets go and execute this code!
You can now type into the operating system now! type hello
Excited? Saw the output? :D
You made your own command line OS. but how about adding many more features in this? Like if you type about, it tells you the info about the OS and if you type help it shows the list of commands? Lets do it in the next step.
Step 7: Adding More Features to Our OS
So, lets add more features like about which displays COSMOS OS 1.0 and help which displays
hello - Simple OS command
about - Know about OS
Similarly like the previous step, make 2 more if loops.
CODE:
string input;
{ Console.WriteLine("Hello User! Thanks for using this operating system!"); }
if (input == "about")
{ Console.WriteLine("COSMOS OS 1.0 ");
if (input == "help")
Console.WriteLine("hello - Simple OS command");
Console.WriteLine("about - Know about OS ");
In this code as you see we've made 2 more if loops. Now execute the code and type about. Saw that, it displays COSMOS OS 1.0 and then close the window and re-execute the code and then type help. Saw that? This means everything is going good.
Now every OS has a option of shut down or power off. So lets add features like shutdown and restart.
Step 8: Adding Shutdown and Restart Features
Adding shutdown and restart feature is also extremely easy. In cosmos the code to shutdown is Cosmos.Sys.Deboot.ShutDown(); and to restart is Cosmos.Sys.Deboot.Reboot();
Now make IF loops which have input as shutdown and restart.
CODE:
string input;
if (input == "hello") { Console.WriteLine("Hello User! Thanks for using this operating system!"); }
if (input == "about") { Console.WriteLine("COSMOS OS 1.0 ");
if (input == "help") { Console.WriteLine("hello - Simple OS command"); Console.WriteLine("about - Know about OS "); }
if (input == "shutdown") { Cosmos.Sys.Deboot.ShutDown(); }
if (input == "restart") { Cosmos.Sys.Deboot.Reboot(); }
Now execute the code and type restart. Saw it xD! It restarted! Now type shutdown. Saw it, the window closed which means the OS shut down.
This may be the most exciting part when you made a OS which can shutdown and restart itself!
Now lets improve this OS by giving it final touches.
Step 9: Final Touches
In the final touches, we will use the switch case because it is much more simpler and better then IF statement. We will also make a command that when the user types a keyword which is not in list of our commands, it should show No such command
Just see the code once.
CODE:
while (true)
string command = Console.ReadLine();
switch (command) {
case "shutdown": { Cosmos.Sys.Deboot.ShutDown();
break;
case "help":
break;
case "about":
break;
case "reboot": {
break;
case "hello": {
break;
default: { Console.WriteLine("No such command");
command = null; break; } }
Ok, just copy the code into visual studio and execute the code. Note that we added the break;. This is used in switch case. Now have the fun with your OS!
Now try to type a wrong command like help me. this command was not defined so it shows No command found. This means now our OS won't accept wrong commands. And try all commands. You may have noted that now you can type another command after previous as we are taking input in a constant loop.
Step 10: Running & Testing the OS
So i'm now going to test the OS we made. I'll be using a Virtualization software to run the OS. I'll be using VMware player which is free to download!
Ok, so create a virtual machine and open C:\Users\ {Your Username} \AppData\Roaming\Cosmos User Kit
Here you will find cosmos.iso file after you select build ISO in visual studio. Just boot this file in VMware and enjoy your operating system! (make it full screen)
Step 11: Thanks & About Me
I'm a 16 year old embedded developer, working with MIT Media Labs India Initiative. I work in various technologies like ARM, AVR, Arduino and Raspberry Pi.
You can find about me here: http://www.sarthaksethi.net/
Facebook: https://www.facebook.com/pages/Sarthak-Sethi/25272...
Youtube: https://www.youtube.com/channel/UCv7OszKtRFkJ_e0Af...
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    95 Discussions
    TKIPAES
    10 months ago on Step 6
    Its a nice article that you wrote but if a statement for & while are loop that are looping until the condition x is met
    JacobA84
    Question 1 year ago on Step 2
    Wich Visual Studios? Professional, Enterprise, or Community? (I'm using 2017)
    Not sure what the problem is, that
    people dislike this system.
    In a traditional sense, yes, this is
    not an OS that you make from scratch.
    However, you would be foolish to
    neglect this wonderful software and its brilliants.
    I took a look at this, and
    I must admit, this a brilliant software design that was made by
    brilliant people. Think of it as this...these people made LEGO with
    instructions. You can build with LEGO, throw them at someone, step
    on them, or feed them to your cat. You can do whatever the hell you
    want. You can even design your own house out of LEGO, if that is
    what you want. However, you never made the “LEGO” In the
    traditional sense. It was already made for you. You are just
    following instructions even if the seems a bit arbitrary.
    Let me
    Give you and Example: Let us say
    I wanted a special OS to run my 3 hydroponics systems. Instead of
    going from point A to point B then to point C then back to point A,
    So I could check how the system is doing. I deiced to use this
    software and attache it to my makeshift old PC through floppy drive
    (Lol). I then wrote a software for this OS to connect to my hydroponics
    system so I can check the progress, and any problems that
    my systems might have.
    Whatever you want to do, is up to you.
    Don't neglect this opportunity to learn a lot just because of
    “traditions”. Yes, traditionally, it takes a lot more brainpower to make an “Official” OS. However, I never would had the
    time, had I had to write the damned OS from scratch, or use it by the
    time I finished making it.
    I needed the thing running like “NOW”
    so I used this. Why should I be ashamed to call this “My OS”.
    The point is, if you really want to use
    it, in any way you want. You will figure out how to make use of this,
    besides just “Playground” purposes.
    You can sit here and do some nit
    picking as well as continue arguing about the semantics....
    Or you can attempt this tutorial,
    “Making your OS” and learn something at the end of the day.
    The choice is yours.
    Tinker Bench
    1 year ago
    Great Sarthak. I was unable to find your website or channel but i appreciate your work. Well done. When I read through the first parts, I didn't even dream that it would be an instructable by an Indian. Great work
    jeffbowman
    2 years ago
    Much of this text is blatantly plagiarized from the original documentation at Cosmos' GitHub source code repository.
    SSARTHAK598, you're 12 years old... this isn't a good way for you to start out. Be honorable. It'll get you further.
    cuban.guy.94
    4 years ago on Step 11
    Nice. Some corrections:
    1. This is not an OS. All the
    functions of the OS kernel plus the .NET runtime and libraries are
    provided by COSMOS. You're just writing a very basic .NET application.
    2. The processor on a PC can do multitasking without an OS. You just have to program it for it.
    3.
    The Windows kernel is not Win32. Win32 is just a subsystem (more like C
    libraries). You can run even run the kernel without win32 with some
    hacking and you can run other subsystems (such as INTERIX) side-by-side.
    Are you stupid or what? That is an operating system that has a kernel. I've made an operating system in Cosmos before. It can boot on computer hardware using a cd or dvd.
    hueypcuban.guy.94
    Reply 4 years ago on Step 11
    With the kernel point, wouldn't that mean that Ubuntu isn't an operating System and instead a Linux application set on top of the Linux kernel?
    WernerM1cuban.guy.94
    Reply 4 years ago on Introduction
    Actually, had you read his initial considerations, you would have caught the following, which I am bringing up here for you:
    "Cosmos is not an operating system in the traditional sense, but instead
    it is an 'Operating System Kit', or as I like to say 'Operating System
    Legos'"
    No one with some basic commercial programming knowledge would expect this framework to ever become a full blown OS after looking at it, as it is clearly not intended to. This is merely a tool for learning and playing around.
    dhall-1
    4 years ago on Step 10
    This seems more like a UI than an OS.
    At the very most a line input interpreter.
    WernerM1dhall-1
    If you judge it merely by the examples provided by the author, then yes. Nothing differs much from writing a console application that parses command line arguments, such as:
    void main(char[] argc, int argv){
    if (argv > 0){
    switch argc{
    case "help": {
    break;
    case "about": {
    break;
    case "hello": {
    break;
    else {
    break;
    But since this article only demonstrated some simple commands that are available under the whole COSMOS framework (which has an extensive library), I think it is always a good idea to do some more exploration before issuing comments way too soon.
    sviquarahmedWernerM1
    Reply 2 years ago
    my emial is :- sviquarahmed@gmail.com ,you contact on that
    dhall-1WernerM1
    So I was correct in my original statement.
    This is NOT an operating system. COSMOS is the operating system and this is just a way to interface with it.
    I spent 6 months in college writing an operating system for a vax/vms mainframe. And even it was just extension of the emulator our professor had written on top of the VAX's OS.
    Did the author write COSMOS or the library files? without COSMOS would the examples execute? Then no, the author did NOT make a OS, he made a way to interface with the OS. It is still a great project just the title is misleading.
    Connor Willettdhall-1
    Reply 3 years ago on Introduction
    Good for you buddy. 6 months in college. I'm 12 years old and I made an operating system with this Cosmos thing.
    WernerM1dhall-1
    Reply 4 years ago
    Your comments clearly demonstrate your lack of attention to the text and excess criticism. And that's enough said.
