Make Cheap, Easy Cardboard Small Parts Storage Organizers
77,947
264
32
About: Retired, doing art work now. Great. Have the time and the money to spend doing what I want to do.
How to make small boxes (at a very low cost) solve a need and organize small parts. I make these boxes as needed, so it doesn't become an overwhelming chore all at once. It's a good way to store small parts in the workshop. And we are reuseing cardboard that otherwise might not be recycled.
Step 1: Tools You Will Need.
Common tools, box cutter or mat cutting knife, straight edge, ruler, clamps and glue.
Step 2: Make As Many Blanks As You Want or Will Need.
Here I've cut 5 or 6 blanks, but could be cutting out 10, 20 or more.
Step 3: Score on Marked Lines
At lines drawn at 1 1/4 inches around blank, score with the bone scorer.
Step 4: Fold Up Edges to Glue
On the scored lines, edges are folded up, and the end flaps are folded inward and glued with clamps.
Step 5: Completed Boxes, Ready to Fill and Use.
Here is seen the results of our labors...several small boxes, some with dividers, ready to use.
    • Organization Contest
    • Sweet Treats Challenge
    • Paper Contest
      Paper Contest
    32 Discussions
    lacod0
    1 year ago
    Thank you for the measurements!
    MarkSindone
    2 years ago
    I have always wanted to find a solution in getting the most out of my wardrobe and other furniture pieces like bookshelves and cabinets and this instructable piece is definitely what I have been looking for. It not only helps to keep things organized but also conceals in the mess which could be an eyesore. Furthermore, things can be retrieved easily if we were to label the individual cardboard boxes.
    OmarN2
    3 years ago on Introduction
    I have to build some boxes for my children toy box cubes. Guess I found the right idea, just by adjusting dimensions. good thing cardboard takes paint well, so I can have them decorate the boxes themselves and voila, quality time with children AND cheap replaceable boxes. Plus, I'm tired of spending a few bucks on plastic divider containers for my own screws and small parts.
    DeanAshby
    5 years ago on Introduction
    Nice and neat indeed. A very smart idea to fully organize the tiny items that easily get lost or difficult to scour through should they get mixed up together. These simple yet very practical storage organizers will definitely save a lot of time and effort as compared to simply dumping them all in just one container altogether. It will enable you to work more efficiently and not have your mind in a mess too.
    bobzjr
    Nicely done - thanks for sharing. Might be good for some of those extra empty boxes I have squirreled away. Have you ever tried this with plastic corrugated sign board? After some events, a ton can suddenly become available. Another upcycle possibility... Could we use some sort of super hot pliers to "spot weld" the plastic. This could let me get away with out glue (maybe).
    graydog111
    6 years ago on Introduction
    I have made containers for bolts, screws, etc out of 1 qt. plastic oil bottles. I wash them thoroughly, cut one side off with a radial arm saw. Write the name/size on the end.
    HogHunter
    9 years ago on Introduction
    Just last night I was organizing my office/tool storage area. I was thinking it would be nice to have a better way to store my screws and nails. This is a good start. I think with these boxes I could create a larger tray/box to hold them and carry them to my work site. One thing I hate is when you go to work on something and realize you need a different screw or a longer nail. Then you have to go all the way back to your shop for them. I think these boxes laid inside a large wooden box with maybe a thin plywood cover between the layers then you could stack them up pretty well. I will see if I can do this this weekend and I will post my results. I have attached a drawing of the box I am referring to. As you can see, with a box like this, you could store 56 of your boxes assuming the boxes are 3" x 5.5" x 1". The drawing says the box is made from plywood, but as I was typing this it occurred to me that you could make the sides and bottom out of plywood and use plexiglass for the front and back. That would allow you to see the boxes.
    corradiniHogHunter
    Reply 6 years ago on Introduction
    I just made a few of these boxes/trays -- at these dimensions they end up being 6 x 3 x 1 1/4. Works pretty well, although they're nowhere near as neat as the ones in the photos where the OP used inside-corner tape... >;-)
    ANYhow: I think HogHunter had kind of the same idea that I just had -- building a cabinet to hold lots of these -- but why the heck use plywood? If I'm going to do that (and I have the equipment & skilz), I'll build the drawers out of plywood too. What I think would be GREAT would be to build the overall cabinet, holding a lot of these trays, out of cardboard too. Obviously that'd depend on how many you want, high x wide -- but it'd be simple enough to design something representative (like: 5 units wide and 5 tall, which would be roughly -- I dunno - ~34" wide and maybe 16" high?)
    The inner dividers could be cut halfway through, like wine-case dividers, and 'tabbed' to glue to the sides of the outer case. The trick would be to avoid having any of those 'tabs' or attachment parts interfering with the 'drawers' sliding in and out -- but I'm sure some clever soul can figure that out! >;-)
    racastro62HogHunter
    Hei HogHunter, your idea is really good. The problem happens to me so frequently that I use to go allaround the house with a 2 gall.-toolbox filled with screws and other typical small accessories. Your design is really elegant. May be too elegant when taken to reallity. I would make a small change: Plywood would sag because of the filled boxes weight. If you make the big box shorter (not more than 12" long) and higher (maybe 15" high), it would be not so comfortable . Regards, Raúl
    AllenInks
    7 years ago on Step 2
    Using a box cutter and a plastic straightedge (as seen in step 2) to guide the cutting blade of the box cutter will typically lead to the straightedge no longer being straight...after being shaved and gouged by the cutter. A metal straight edge will typically last longer, I think - and it doesn't have to be a ruled straight edge. For example, I have a scrap piece of sheet metal (edges blunted by careful filing) that works well.
    That being said, I like this 'ible! I've been trying to find a cheap source of the plastic small parts bins, but even though another instructable said they are cheap (90 cents apiece in batches of 25, or some such thing), that sounds expensive when you want more than just a few!
    pfred2AllenInks
    Cut down plastic bottles. My favorites are half gallon milk bottles. But I mostly use gallon jugs cut in half. Empty oil bottles make nice poly bins too. I'm up in the air whether I prefer Castrol or Penzoil style bottles though. I've a mix of both now. Though I've made plenty of custom cardboard boxes to hold things too.
    Usually when I file metal I end up sharpening it. I file it square to do that though. I suppose if I chamfer file metal it knocks the edge off. Careless filing dulls metal pretty good :)
    Regarding step 2; apparently a bone scorer doesn't hurt plastic rules. I've an extensive tool box and I must admit I do not possess such a device myself.
    espence
    7 years ago on Introduction
    THATS THE ULTIMATE FORM OF RECYCELING - GOOD JOB CMAN
    madwheels37
    7 years ago on Step 5
    Thanks...simple to do, and very handy for me. Course your own sizes can be made for different objects or funky sizes.
    TheHobbit81
    8 years ago on Introduction
    Very nice, I think I'll make some larger ones for all my arts 'n' craft tools and scraps.
    beehard44
    i was thinking if i can make these for the drawers in my electronics workbench
    Beagles
    Good stuff C'man, I love to see projects re-using cardboard. Is that box cutter holder a tool you made? Could really use something like that if if have further details, please. When it comes to making sharp bends in cardboard, right where you want them, a neat tool to make up is a board (say 3/4" thick) and bevel the edge at 45* on your saw. That sharp edge makes a clean crisp bend. I often make up cardboard cases for my magazines, to store a couple of years at a time, and had difficulty putting the bends where they belonged..........until I made up that board creaser. The cat food pouches we buy come in cardboard trays that measure: 3 1/2 W X 5 H X 8" L and are usefull for many things. Be on the outlook for other things like that. We have no shortage of cardboard, the local grocery stores all have boxes set out for re-use...............'cause we have a ban on plastic bags here (Toronto)
    CreativemanBeagles
    Thanks for the comments, Beagles: Yes I made the holder to expedite the cutting of cardboard. Helps alot! Not sure I follow on your "creaser" however. Tell you what: I will update the holder construction by making a new instructable, if in turn, you will make one showing your board creaser? Deal? Have a good day. Cman
    BeaglesCreativeman
    Sounds good........but I may be run out of here if I tried to make that creaser an "Instructable" . It is a board that is cut on a 45* angle and the sharp edge is held over the bend line, then simply lift up on your cardboard. The "45" gives you a clean sharp bend, because you can also go past 90* to counter any spring back of the cardboard. In my case, the board was a 3/4" X 4" X 12" piece of white oak that was otherwise headed for the stove. Simple enough to make and use, was getting tired of the crappy bends that came with a square cut edge board. And thanks, for your holder info. Beagles
    BeaglesCreativeman
    Yes, that is it exactly. Another small point, when you run across difficult (to bend) cardboard, it helps to take that pointed board and use it to crush the cardboard on the bend line. I have found that it makes the cardboard respond better. Thanks for your photos and your update on the box cutter holder. Beagles.
