Make a Key in minutes By using Expired Debit Or Credit bank card or any similar type cards or an Empty Tic tac mints plastic container we can make emergency spare key for lock, The resulted key can be used up to 10 times because its not metal it will bend so make it in less than 4 mins and keep in your wallet and use i an forgotten or an emergency situation.It is the most Usefull and easiest life hack using plastic bottle or a card.
Requirements:
Tictac container
unused gift or expired cards
Clear tape and a
lighter or a candle
Step 1: Take the Necessary Things
take empty tictac bottle or unused bank card or any other similar cards and take the original key and lighter or a candle and now we get into our work
Step 2: Smoke One Side of the Key
use lighter and flame one side of the key smoke accumulates on the surface of the key now place key aside and let it cool down
Step 3: Make the Trace of Key
By using the clear tape stick it on the smoky side of the key and the print of the key transfer to the gummy surface of the that means smoke particles sticks to tape and it gives clear print of the key
Step 4: Sticking Tape on Card and Cutting
Stick the tape on the card and by using the scissor cut it exactly take time for exact cutting if you are not good at cutting after cutting your key is ready
Step 5: About Key
In the above picture you can see the cut portion of key matched to the original key so cut softly and exactly
Step 6: Using Tictac Mint Container
I made similar spare key with tic tac bottle in the same way
Step 7: Test
After making test them they will work , after making several keys i got to know they will work up 10 to 15 times because they are plastic they will bend but even though it is cheap home made trick to copy key and use them in emergency situation make it and keep it in your pocket it will be useful at any time
Thank you
Bye Bye
65 Discussions
1 year ago
I don't think it would work on newer cars because my car doesn't have a key hole in it and I want to be able to use it for the ignition because they condition would recognize something foreign and it would not work
1 year ago
I don't think it worked on newer cars
2 years ago
Very nice idea to make key by using tic-tac bottle in less time.
www.usessayhelp.blogspot.com/
3 years ago
Cool Idea.
http://helpwritinganessay.com/research-paper/
3 years ago
i reckon keeping a lockpicking tension wrench with any of these copies would be a good idea, put the workload on the wrench instead of the flimsy key
3 years ago
The point in not spending your $2 at Wal-Mart, Home Depot, Lowes, etc., etc. is to be able to make a spare key in a pinch or emergency. Better yet, if you are someone who happens to misplace your keys often, this is a fantastic idea. I like this primarily because the keys are not made by a metal, which therefore cannot be detected. Very cool instructable!
3 years ago
This is a whole lot of work for nothing. You can have a key made at any big box store (Home Depot, Lowes, Menards) or hardware store for under $2. Why waste the time making one?
3 years ago
for those who are stating plastic key issues i made another instructable on making metal key please do watch it and i m thinking they will have less issues
3 years ago
I think that what you "save" on this might get pretty expencive if this breaks in your lock....
Reply 3 years ago
Yeah! good point!
3 years ago
i think PVC is stronger (will not bend or break inside the lock) and easier to cut to shape with the appropriate tool
3 years ago
This is a cute idea and it's cool if it works, but, why not just spend the couple bucks it costs to have a real key made! Also, unless you have some high tech door, most people know that if you ever lock yourself out, you just take a card and slide it between the lock and door frame and it unlocks. Then you can still use the card after.
3 years ago
i think i'd be more likely to use an exacto knife for the cutting.
3 years ago
Cheap keys for cheap locks.
3 years ago
Very nifty idea. A better base material is a discarded CD or DVD. They are harder to cut however, but I use tin snips for larger cuts and a sheet tin nibbler for the detail. Old DVDs are great for all sorts of fabrication projects requiring insulated material.
Reply 3 years ago
You could temporarily glue your key to a CD case... then use a rotozip (or even an engraver) to trace the key... or a file if you are not comfortable with those tools.
Once trace is done, you could remove the plastic from the key gently... and then clean off dried glue.
Reply 3 years ago
I didn't mean to type case... i was referring to CD/DVDs.... i might try this... make a spare of house and car keys to keep in wallet (these would be slimmer than metal copies).
I was thinking of using an old credit card - cut out 2 areas roughly the shape of each key - facing each other but offset. Then I could place the spare keys in those blank areas and use clear tape to lock them in. That way, 2 keys can be kept in the space of 1 credit card... and it won't leave that key imprint on my wallet.
Reply 3 years ago
Good idea, but if your wallet was snatched, they'd now have your keys too. I'd keep it somewhere else than in my wallet/purse.
Reply 3 years ago
The case is not a suitable material, they are really brittle, the CD/DVD itself is polycarbonate and extremely tough.
3 years ago
Burglars everywhere are going to love you for this...
Cool instructable!
