Make Your Own Camera
1,246
About: 55+ years in electronics, computers, and teaching ... now retired.
This instructable explains how to make a monochrome camera using an Omnivision OV7670 image sensor, an Arduino microcontroller, a few jumper wires, and Processing 3 software.
Experimental software for obtaining a color image is also presented.
Press the “c” key to capture a 640*480 pixel image ... press the “s” key to save the image to file. Successive images are sequentially numbered should you wish to create a short time-lapse movie.
The camera is not fast (each scan takes 6.4 seconds) and is only suitable for use in fixed lighting.
The cost, excluding your Arduino and PC, is less than a cup of coffee.
Images
The component parts, without jumper wiring, are shown in the opening photo.
The second photo is a screen-shot showing the Arduino camera software and the Processing 3 frame-grabber. The inset shows how the camera is connected.
The video demonstrates the camera in action. When the “c” capture key is pressed there is a brief flash followed by a burst of activity as the image is scanned. The image automatically appears in the display window once the scan is complete. The images are then seen to appear in the Processing folder following each press of the “s” key. The video concludes by cycling rapidly through each of the three saved images.
Step 1: Circuit Diagram
The circuit diagram, for all versions of this camera, is shown in photo 1.
Photos 2, 3 show how the jumpers-wires and components are connected.
Without the aluminium bracket the images are lying on their side.
Warning
Program your Arduino BEFORE attaching any jumper wires to the OV7670 camera chip. This will prevent 5 volt output pins from a previous program from destroying the 3v3 volt OV7670 camera chip.
Step 2: Parts List
The following parts were obtained from https://www.aliexpress.com/
  • 1 only OV7670 300KP VGA Camera Module for arduino DIY KIT
  • 1 only camera bracket complete with nuts and bolts
  • 1 only UNO R3 for arduino MEGA328P 100% original ATMEGA16U2 with USB Cable
The following parts were obtained locally
  • 18 anly Arduino male-female jumper cables
  • 3 only Arduinin female-female jumper cables
  • 1 only mini bread-board
  • 4 only 4K7 ohm 1/2 watt resistors
  • 1 only scrap aluminium stand.
You will also need the following datasheets:
Step 3: Theory
OV7670 camera chip
The default output from the OV7670 camera chip comprises a YUV (4:2:2) video signal and 3 timing waveforms. Other output formats are possible by programming the internal registers via an I2C compatible bus.
The YUV (4:2:2) video signal (photo 1) is a continuous sequence of monochrome (black & white) pixels separated by U (blue color difference) and V (red color difference) color information.
This output format is known as YUV (4:2:2) since each group of 4 bytes contains 2 monochrome bytes and and 2 color bytes.
Monochrome
To obtain a monochrome image we must sample every second data byte.
An Arduino only has 2K of random access memory but each frame comprises 640*2*480 = 307,200 data bytes. Unless we add a frame-grabber to the OV7670 all data must sent to the PC line-by-line for processing.
There are two possibilities:
For each of 480 successive frames, we can capture one line to the Arduino at high speed before sending it to the PC at 1Mbps. Such an approach would see the OV7670 working at full speed but would take a long time (well over a minute).
The approach that I have taken is to slow the PCLK down to 8uS and send each sample as it comes. This approach is significantly faster (6.4 seconds).
Step 4: Design Notes
Compatibility
The OV7670 camera chip is a 3v3 volt device. The data sheet indicates that voltages above 3.5 volts will damage the chip.
To prevent your 5 volt Arduino from destroying the OV7670 camera chip:
  • The external clock (XCLK) signal from the Arduino must be reduced to a safe level by means of a voltage divider.
  • The internal Arduino I2C pull-up resistors to 5 volts must be disabled and replaced with external pull-up resistors to the 3v3 volt supply.
  • Program your Arduino BEFORE attaching any jumper-wires as some of the pins may still be programmed as an output from an earlier project !!! (I learnt this the hard way ... fortunately I bought two as they were so cheap).
External clock
The OV7670 camera chip requires an external clock in the frequency range 10Mhz to 24MHz.
The highest frequency we can generate from a 16MHz Arduino is 8MHz but this seems to work.
Serial link
It takes at least 10 uS (microseconds) to send 1 data byte across a 1Mbps (million bits per second) serial link . This time is made up as follows:
  • 8 data bits (8us)
  • 1 start-bit (1uS)
  • 1 stop-bit (1uS)
Internal clock
The internal pixel clock (PCLK) frequency within the OV7670 is set by bits[5:0] within register CLKRC (see photo 1). [1]
If we set bits[5:0] = B111111 = 63 and apply it to the above formula then:
  • F(internal clock) = F (input clock)/(Bit[5:0}+1)
  • = 8000000/(63+1)
  • = 125000 Hz or
  • = 8uS
Since we are only sampling every second data byte, a PCLK interval of 8uS results in a 16uS sample which is sufficient time to transmit 1 data byte (10uS) leaving 6uS for processing.
Frame rate
Each VGA video frame comprises 784*510 pixels (picture elements) of which 640*480 pixels are displayed. Since the YUV (4:2:2) output format has an average of 2 data bytes per pixel, each frame will take 784*2*510*8 uS = 6.4 seconds.
This camera is NOT fast !!!
Horizontal positioning
The image may be moved horizontally if we change the HSTART and HSTOP values while maintaining a 640 pixel difference.
When moving your image left, it is possible for your HSTOP value to be less than the HSTART value!
Don’t be alarmed ... it is all to do with counter overflows as explained in photo 2.
Registers
The OV7670 has 201 eight-bit registers for controlling things such as gain, white balance, and exposure.
One data byte only allows for 256 values in the range [0] to [255]. If we require more control then we must cascade several registers. Two bytes gives us 65536 possibilities ... three bytes give us 16,777,216.
The 16 bit AEC (Automatic Exposure Control) register shown in photo 3 is such an example and is created by combining portions of the following three registers.
  • AECHH[5:0] = AEC[15:10]
  • AECH[7:2 ] = AEC[9:2]
  • COM1[1:0] = AEC[1:0]
Be warned ... the register addresses are not grouped together !
Side effects
A slow frame rate introduces a number of unwanted side effects:
For correct exposure, the OV7670 expects to work at a frame rate of 30 fps (frames per second). Since each frame is taking 6.4 seconds the electronic shutter is open 180 times longer than normal which means all images will be over-exposed unless we alter some register values.
To prevent over-exposure I have set all of the AEC (auto exposure control) register bits to zero. Even so a neutral density filter is needed in front of the lens when the lighting is bright.
A long exposure also appears to affect the UV data. As I have yet to find register combinations that produce correct colours ... consider this to be work in progress.
Note
[1]
The formula shown in the data sheet (photo 1) is correct but the range only shows bits[4:0] ?
Step 5: Timing Waveforms
The note in the bottom left corner of the “VGA Frame Timing” diagram (photo 1) reads:
For YUV/RGB, tp = 2 x TPCLK
Figures 1, 2, & 3 verify the data sheet(s) and confirm that Omnivision treats every 2 data bytes as being the equivalent of 1 pixel.
The oscilloscope waveforms also verify that HREF remains LOW during the blanking intervals.
Fig.4 confirms that the XCLK output from the Arduino is 8MHz. The reason we see a sinewave, rather than a squarewave, is that all of the odd harmonics are invisible to my 20MHz sampling oscilloscope.
Step 6: Frame Grabber
The image sensor within an OV7670 camera chip comprises an array of 656*486 pixels of which a grid of 640*480 pixels are used for the photo.
The HSTART, HSTOP, HREF, and VSTRT, VSTOP, VREF register values are used to position the image over the sensor. If the image is not positioned correctly over the sensor you will see a black band over one or more edges as explained in the “Design Notes” section.
The OV7670 scans each line of the picture one pixel at a time starting from the top left corner until it reaches the bottom right pixel. The Arduino simply passes these pixels to the PC via the serial link as shown in photo 1.
The frame-grabbers’ task is to capture each of these 640*480=307200 pixels and display the contents in an “image” window
Processing 3 achieves this using the following four lines of code !!
Code line 1:
  • byte[] byteBuffer = new byte[maxBytes+1]; // where maxBytes=307200
The underlying code in this statement creates:
  • a 307201 byte array called “byteBuffer[307201]”
  • The extra byte is for a termination (linefeed) character.
Code line 2:
  • size(640,480);
  • a variable called “width=640;”
  • a variable called “height=480”;
  • a 307200 pixel array called “pixels[307200]”
  • a 640*480 pixel “image” window in which the contents of pixels[] array are displayed. This “image” window is continuously refreshed at a frame rate of 60 fps.
Code line 3:
  • byteCount = myPort.readBytesUntil(lf, byteBuffer);
The underlying code in this statement:
  • buffers the incoming data locally until it sees a “lf” (linefeed) character.
  • after which it dumps the first 307200 bytes of local data into the byteBuffer[] array.
  • It also saves the number of bytes received (307201) into a variable called “byteCount”.
Code line 4:
  • pixels[i] = color(byteBuffer[i]);
When placed in a for-next-loop, the underlying code in this statement:
  • copies the contents of the “byteBuffer[]” array to the “pixels[]” array
  • the contents of which appear in the image window.
Key Strokes:
The frame-grabber recognises the following keystrokes:
  • ‘c’ = capture the image
  • ‘s’ = save the image to file.
Step 7: Software
Download and install each of the following software packages if not already installed:
  • “Arduino” from https://www.arduino.cc/en/main/software
  • “Java 8” from https://java.com/en/download/ [1]
  • "Processing 3” from https://processing.org/download/
Installing the Arduino sketch:
  • Remove all OV7670 jumper wires [2]
  • Connect a USB cable to your Arduino
  • Copy the contents of “OV7670_camera_mono_V2.ino“ (attached) into an Arduino “sketch” and save.
  • Upload the sketch to your Arduino.
  • Unplug the Arduino
  • You can now safely reconnect the OV7670 jumper wires
  • Reconnect the USB cable.
Installing and running the Processing sketch:
  • Copy the contents of “OV7670_camera_mono_V2.pde” (attached) into a Processing “sketch” and save.
  • Click the top-left “run” button ... a black image window will appear
  • Click the “black” image-window
  • Press the “c” key to capture an image. (approx 6.4 seconds).
  • Press the “s” key to save the image in your processing folder
  • Repeat steps 4 & 5
  • Click the “stop” button to exit the program.
Notes
[1]
Processing 3 requires Java 8
[2]
This is a “once only” safety step to avoid damaging your OV7670 camera chip.
Until the sketch “OV7670_camera_mono.ini” has been uploaded to your Arduino the internal pull-up resistors are connected to 5 volts, plus there is the possiblity that some of the Arduino data lines may be 5 volt outputs ... all of which are fatal to the 3v3 volt OV7670 camera chip.
Once the Arduino has been programmed there is no need to repeat this step and the register values may be safely changed.
Step 8: Obtaining a Color Image
The following software is purely experimental and is posted in the hope that some of the techniques will prove useful. The colors appear to be inverted ... I have yet to find the correct register settings. If you find a solution please post your results.
If we are to obtain a color image, all data bytes must be captured and the following formulas applied.
The OV7670 uses the following formulas to convert RGB (red, green, blue) color information into YUV (4:2:2): [1]
  • Y = 0.31*R + 0.59*G + 0.11*B
  • U = B – Y
  • V = R – Y
  • Cb = 0.563*(B-Y)
  • Cr = 0.713*(R-Y)
The following formulas may be used to convert YUV (4:2:2) back to RGB color: [2]
  • R = Y + 1.402* (Cr – 128)
  • G = Y – 0.344136*(Cb -128) – 0.714136*(Cr -128)
  • B = Y + 1.772*(Cb -128)
The attached software is simply an extension of the monochrome software:
  • A “c” capture request is sent to the Arduino
  • The Arduino sends the even numbered (monochrome) bytes to the PC
  • The PC saves these bytes into an array
  • The Arduino next sends the odd numbered (chroma) bytes to the PC.
  • These bytes are saved into a second array ... we now have the entire image.
  • The above formulas are now applied to each group of four UYVY data bytes.
  • The resulting color pixels are then placed in the “pixels[]” array
  • The PC scans the “pixels[]” array and an image appears in the “image” window.
The Processing 3 software briefly displays each scan and the final results:
  • Photo 1 shows the U & V chroma data from scan 1
  • Photo 2 shows the Y1 & Y2 luminance data from scan 2
  • Photo 3 shows the color image ... only one thing is wrong ... the bag should be green !!
I will post new code once I have solved this program ...
References:
[1]
http://www.haoyuelectronics.com/Attachment/OV7670%... (page 33)
[2]
https://en.wikipedia.org/wiki/YCbCr (JPEG conversion)
  Click here   to view my other instructables.
    • Warm and Fuzzy Contest
    • PCB Contest
      PCB Contest
    • Cardboard Challenge
      Cardboard Challenge
    27 Discussions
    skywalker58
    Question 2 days ago
    hello again. i buy a new ov7670.
    i take this photos. how can i do take a good image with ov7670?
    only working in high light.
    lingibskywalker58
    Answer 23 hours ago
    An image at last ... well done :)
    The fact that you are now getting an image indicates that both your camera module and frame grabber are working.
    I am a little puzzled about your images as I have not encountered this problem.
    Both images have a slanting edge which indicates a timing / synchronising issue. In particular the lower part of your first image appears to "wrap-around" the screen.
    The "bands" in each image also indicate a loss of sync. I suspect that you are occasionally loosing a sync pulse and what you are seeing are bands of "UV" (color) data then "Y" (image) data as you regain sync. If this problem occurs at start up then it may resolve after running for a while (I'm thinking temperature).
    Go back over my previous suggestions ... in particular the answer in which I post six images.
    skywalker58lingib
    Reply 19 hours ago
    i dont made it. Why dont happened, i am not understand. what is the problem this time? i make your says but I couldn't reach the result.
    lingibskywalker58
    Reply 17 hours ago
    I can understand your frustration.
    Keep in mind that I cannot see what you are doing and have no way of knowing what you have tried in an attempt to debug your latest problem ... you are my eyes and ears. Sounding off does not help.
    Currently you have progressed from no image to a (slightly) distorted image.
    Together we isolated your initial lack of an image to a faulty OV7670.
    I am assuming that you have confirmed that the framegrabber is working by performing the tests that I have previously sent you. I am attaching the three screen shots again.
    Your framegrabber screen should change from light-gray, to gray, and then to black when you change the Serial.print(data); line in yellow-high light. This test is probably unnecessary as you are now getting an image. Restore the line in yellow-highlight to read Serial.print(data); when you have finished.
    The number 307201 should be displayed following each test.
    Assuming that the framegrabber tests okay you need to figure out why your data is getting corrupted.
    For this project to work you need relatively short leads as we are dealing with microsecond pulse widths. Long leads can distort pulses which could cause pulses to be missed which will result in a distorted image.
    If you look at my wiring the earth and supply leads are extremely short.
    skywalker58lingib
    Reply 9 hours ago
    i make your says (in picture). but not improve. even I can't take the photos I took formerly . i shortened cables.
    skywalker58skywalker58
    Reply 8 hours ago
    i took a picture of the window now. Actually camera is working but have a problem. Why occur side lines ?
    lingibskywalker58
    Reply 17 minutes ago
    If you study the photo in Step 3 of this instructable you will see how it is broken up into three sets of information.
    The desired "Y" information, which appears every second data position, produces a detailed image. This us why we sample the data every second PCLK.
    The unwanted "U" and "V" information only contains faint images. These signals, if displayed on a monochrome screen, would appear as faint monochrome outlines.
    If you now examine each of your three "window" images you can see faint outlines in each of the unwanted horizontal bands.
    It would appear that your Arduino is not detecting the occasional PCLK signal from your 0V7670 chip. If this were to happen then every second sample would become "U" then "V" information and the image would appear as faint monochrome outlines until another PCLK signal is missed at which point the desired image will reappear.
    This would also explain the slanted edges to each of your images as the frame-grabber is a dumb device and simply captures data until a linefeed symbol is received at which point it will display the data it has received.
    It would appear that:
    (1) your frame-grabber is working correctly
    (2) your 0V7670 camera chip is working.
    (3) your 5 volt Arduino is not reliably detecting the PCLK signals from the 3 volt 0V7670 CMOS camera chip
    Things to try:
    (1) Swap your existing Arduino board for another. Make certain you PROGRAM IT FIRST before attaching the OV7670 wires.
    (2) If you don't have a spare Arduino board then you could try mapping the PCLK signal to another unused Arduino pin ... some pins may be more sensitive. If you do this then you will need to change the binary patterns, and possibly ports numbers, in each of the code lines associated with the PCLK signal. Let me know if you need help with this.
    lingibskywalker58
    Reply 23 hours ago
    The fact that you are getting a dark image indicates that the lighting levels have changed in which case you will need to increase the camera gain.
    Since the picture also exhibits the same problems as your previous post I suggest that you concentrate on getting a stable image using the settings for your window shots before changing the lighting.
    skywalker58
    6 weeks ago
    firstly thank you for answered me.
    i made your says but now, i encountered a new problem. how can i adjust net(clear) image?
    sorry for my bad english. i hope understand me :)
    lingibskywalker58
    Reply 6 weeks ago
    The fact that you have data indicates that your hardware is working :)
    I suspect the problem is the result of too much light. If you pause the video in my Instructable at 0:14 seconds you will see that the room is dimly lit.
    In Step 4 (Design Notes: Side Effects) I mention "To prevent over-exposure I have set all of the AEC (auto exposure control) register bits to zero. Even so a neutral density filter is needed in front of the lens when the lighting is bright."
    The exposure values are set to minimum in the "initialise_OV7670(){}" subroutine should you wish to experiment.
    Try installing "OV7670_camera_mono.ino/pde" as this software is much faster which means that you can quickly see the effect of different light levels. The "color" software can be tried once you have an image using the "mono" software.
    The "color" software requires the same lighting level ... it is essentially the "mono" software run twice then processed.
    Keep in mind the color "software is purely experimental" and that "the colors appear to be inverted".
    skywalker58lingib
    Reply 6 weeks ago
    i don't understand to what will do. what i should change in code?
    I tried low light but take same image.
    lingibskywalker58
    Reply 6 weeks ago
    Check that your data line wiring is correct.
    If you haven't already done so, upload "OV7670_camera_mono.ino" to your Arduino.
    Do not make any changes to the code. If you have access to an oscilloscope you should see signals on each of the data lines.
    Open the Arduino "Serial|Monitor" and set the baud speed to 1000000.
    Remove the lens-cap from your OV7670 in bright light. Removing the lens cap forces the OV7670 data pattern to 255 (white)
    Now send the letter 'c' to your Arduino and note the symbols/characters that appear in the Serial|Monitor.
    Replace the lens-cap on your OV7670. Adding the lens cap forces the data pattern to be 0 (black)
    Send the letter 'c' to your Arduino and note the symbols/characters that appear the Serial|Monitor. These symbols/characters should be different.
    If no visible characters appear on the screen substitute the following (untested) code in "OV7670_camera_mono.ino":
    /* Read second byte */
    while (PINB & B00000001); // Wait until PCLK pin 8 is low
    data = (PIND & B11110000) | (PINC & B00001111); // Read data
    if (data <128)
    Serial.write('A');
    else
    Serial.write('Z');
    while (!(PINB & B00000001)); // Wait until PCLK pin 8 is high
    If the characters change from 'AAAAAA....' to 'ZZZZZZZ.....' when you add/remove the lens cap your OV7670 is okay, in which case upload "OV7670_camera_mono.ino" once more to your Arduino and run the OV7670_camera_mono.pde" sketch on your PC.
    Point your OV7670 to a dimly lit object.
    An image should appear in the PC image window, and the number 307201 should appear in the bottom Processing window (307201 = 640*480 pixels + 1 termination character) whenever you press the 'c' key.
    Now adjust the lighting level to suit.
    The above tests should determine whether your OV7670 is working .
    skywalker58lingib
    Reply 6 weeks ago
    i make your says. i encountered a new problem. i write this code ( if (data <128)
    Serial.write('A');
    else
    Serial.write('Z');
    . i see this message (the buffer passed to readBytes....) in processing screen. Before, i delete this parantheses => ''{''. after, again write this parantheses.
    the problem has fixed.
    Later, i upload code in arduino and i look processing screen. and i see this image(in photo).
    lingibskywalker58
    Reply 6 weeks ago
    Your camera may well be working ... it may just need more gain.
    Overwrite any code changes that you may have made by reinstalling BOTH "OV7670_camera_mono.pde" and "OV7670_camera_mono.ino".
    In the "OV7670_camera_mono.pde" software
    Change code line 78 to read:
    pixels[i] = color(int(byteBuffer[i]));
    Explanation:
    Changing the data type SIGNIFICANTLY improves the image.
    In the "OV7670_camera_mono.ino"
    Your image brightness may be adjusted as as follows:
    Change the code to read:
    write_register(0x07, B00000000);
    write_register(0x10, B00100000);
    write_register(0x04, B00000000);
    Explanation:
    These three lines control the image brightness.
    You are allowed to write a '1' into any of the positions below that are shown with an 'x'
    write_register(0x07, Bxxxxxxxx);
    write_register(0x10, Bxxxxxxxx);
    write_register(0x04, B000000xx);
    The default position is"
    Please let me know if this works and I will update the Instructable.
    A screenshot showing the changes is attached.
    skywalker58lingib
    Reply 6 weeks ago
    i tried different combinations in arduino code. but i dont take good image.
    Could my camera be defective?
    lingibskywalker58
    Reply 6 weeks ago
    There is a strong possibility that your OV7670 is not working :(
    With a '1' written into every bit position your screen should be white as shown in Gain_high.jpg (attached) .... your screen is gray ???
    With a '0' written into every bit position you should get an image as shown in Gain_zero.jpg (attached).
    With a gain setting of 4 (binary 00000000 00000001 00) the image starts to over-expose as shown in Gain_four.jpg (attached).
    While you are getting valid sync pulses it appears that your OV7670 data lines are producing invalid data. A simple way of verifying this is to fill each bit position with a '1' (as you have done) and send known hexadecimal data values to your PC as shown in the remaining screen shots.
    0x00 produces a black screen as shown in Serial_write_0x00.jpg.
    0x80 produces a mid-gray screen as shown in Serial_write_0x80.jpg.
    0xFF will produce a completely white screen.
    Serial_write_0xD0.JPGSerial_write_0x80.JPGSerial_write_0x00.JPGGain_zero.jpgGain_high.JPGGain_four.JPG
    skywalker58lingib
    Reply 6 weeks ago
    i make same thing to your make.(in photo).
    while serial.write(0xD0) , gray color in processing screen. but what i do write.register(0x07,0x10 nad 0x04) ?
    if i dont change serial.write(0xD0 OR 0X80 or 0x00), dont change image in processing screen.
    *** there is a important situation***
    i use 10k ohm resistance previously.
    but now i use 4.7k ohm resistance.
    is this a problem?
    Reply 6 weeks ago
    What i should write here? => write_register(0x07,0x10,0x04) ?
