Make Your Own ESC
59,116
287
25
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will firstly demonstrate how a common ESC works and afterwards create a circuit consisting of an Arduino Nano, an L6234 motor driver IC and a couple of complementary components in order to build a DIY ESC. Let's get started!
Step 1: Watch the Videos!
The two videos give you a good idea of what is necessary to do to create your own ESC. In the following steps I will present you some additional information.
Step 2: Order Your Components!
Here you can find a parts list with example seller:
Amazon.com:
1x Arduino Nano: http://amzn.to/2fCdkMl
2x LM393 Comparator: http://amzn.to/2wUuM25
1x L6234 IC: http://amzn.to/2wG6WHY
4x 470nF, 1x 100nF, 1x 10nF, 1x 220nF Capacitor: http://amzn.to/2uA0eWA
2x 1µF Capacitor: http://amzn.to/2vRNvi1
4x 1kΩ, 3x 10kΩ Resistor: http://amzn.to/2wG9Cpk
5x 1Ω Resistor: http://amzn.to/2fCjiNi
2x 10kΩ Potentiometer: http://amzn.to/2vRZZGf
2x 1N4148 Diode: http://amzn.to/2vyFPhT
Ebay:
1x Arduino Nano: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x LM393 Comparator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x L6234 IC: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
4x 470nF, 1x 100nF, 1x 10nF, 1x 220nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 1µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
4x 1kΩ, 3x 10kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
5x 1Ω Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 10kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 1N4148 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Arduino Nano: http://amzn.to/2w0QQLZ
2x LM393 Comparator: http://amzn.to/2uRTgaM
1x L6234 IC: http://amzn.to/2w2M2VK
4x 470nF, 1x 100nF, 1x 10nF, 1x 220nF Capacitor: http://amzn.to/2wUe03i
2x 1µF Capacitor: http://amzn.to/2wUyby6
4x 1kΩ, 3x 10kΩ Resistor: http://amzn.to/2vujMKZ
5x 1Ω Resistor: http://amzn.to/2vzjBwc
2x 10kΩ Potentiometer: http://amzn.to/2uRZveE
2x 1N4148 Diode: http://amzn.to/2fCTO2E
Step 3: Create the Circuit!
Here you can find the schematic along with reference pictures of my board layout.
Step 4: Upload the Code!
Here you can download the code that I created for the project. Since I created quite a few of them you can download them all.
Sketch 1: Uses the analogRead function to measure the current
Sketch 2: Uses the external interrupt on pin 3 to measure the current
Sketch 3: Uses timer 2 to control the current chopping
Sketch 4: Uses the interrupts on pin 10,11,12 to switch to the next step
Step 5: Success!
You did it! You just created your own ESC!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    25 Discussions
    karthikanchan
    Question 3 months ago on Introduction
    hi,
    I am doing a project using ESC circuit that is run using arduino uno. I am using this circuit to run a small 12v compressor, the expected flow rate to be obtained is 11 litres/min,but i am able to obtain only 7.5 l/m at the maximum speed of the compressor. So should i increase the voltage to the compressor or the speed of the compressor can be increased by the code itself?
    the link form where i have referred this circuit and code is given below,please have look at it and help me if should make changes in code?.if yes then please help me with the changes in code too.
    https://simple-circuit.com/arduino-sensorless-bldc-motor-controller-esc/
    adrianl126
    4 months ago
    Hi Great Scott my question is, do you think the basic code will run on a senseless squirrel cage induction motor that has no magnets and whose load is a simple green house fan?
    ZellitoH
    6 months ago on Introduction
    Hi Scott, the actual boards pictures you show do not look like the electronic diagram. What changes do I need to make to make this work ?
    Thanks
    AiltonO
    Question 1 year ago
    what changes i have to do for made a esc for a brushed motor ?
    1 answer
    liu.sunnyAiltonO
    Answer 11 months ago
    this driver is only for brushless motor, brushed motor is a completely different structure and you cannot modify from this driver
    EdaÇ3
    Question 1 year ago on Step 5
    Hi,I want to try this project.But before the create it, I want to simulate in the program .Which simulation program you use ?Can you help me?
    diy_bloke
    1 year ago
    Followed this on youtube. Great work, learned a lot
    PierceB4
    1 year ago
    hi, i have a quick question about this design, if im using Sketch 4 can i remove everything between pins 14 and 17 on the motor controller and pin 3 on the Arduino, the reason i ask is that i am limited on size in my current project
    Thợ RènB
    1 year ago
    cám ơn bạn rất nhiều !
    indram11
    1 year ago
    Hello...i've been trying to make esc based on your project, i already downloaded your arduino's code but i couldn't create the sketch and since i'm still learning in arduino, so i want to ask you about your code in your video, does that video show the full code of the project?
    Sorry for my bad english.
    Ivan4567
    1 year ago
    Hello! Is it possible to implement a digital speed reference? Without using a potentiometer.
    AllexandruP
    1 year ago
    make a video ; comparators vs opamp
    ahmet_024102
    1 year ago
    can you add good schematic photo.
    can you share good ? because not sure names
    mikeanton
    1 year ago
    Great instructable, but I think there are a few errors in your schematic. The RC filters you have on the comparator inputs look to be drawn incorrectly. The capacitor should be located directly on the comparator pin, so that the capacitor forms a voltage divider along with the resistor, to form a lowpass filter. As drawn, the capacitor is right across a low impedance source, so it will have little to no effect.
    JaccoV
    1 year ago
    Awesome project! We made it exacatly like you.. The only problem is that the motor isn't spinning fast enough. Do you have any idea why this is happening? We using the software 4.ino
    kevinmaker2018
    1 year ago
    Very good project.I had bought some parts form Makerfabs. Hope every thing is OK. Could you please sharing the eagle files? Thanks!
    doctek
    1 year ago
    Very nice! How about a high res version of the schematic that I could actually read? That would be much appreciated.
    GreatScottLabdoctek
    Reply 1 year ago
    Left click on the image, left click again and select the resolution on the left side. You can even print it as a poster.
