Make Your Own FM Radio
132,796
756
82
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to transform a TEA5767 and an Arduino Pro Mini into a functional and decent looking FM Radio through the help of a couple complementary parts. Let's get started!
Step 1: Watch the Videos!
The two video parts should give you an overview of what is necessary to build the radio. In the following steps I will present you more detailed information.
Step 2: Order Your Parts!
Here you can find a parts list for the electronics with example sellers for your convenience.
Amazon.com:
1x Arduino Pro Mini: http://amzn.to/1pgkpSJ
(Optional) FTDI breakout: http://amzn.to/1pgkxS6
1x TEA5767: http://amzn.to/222XF6s
1x MCP4151: http://amzn.to/1pgkBRX
1x TDA1905: http://amzn.to/1SzD9YE
or (Optional) 1x PAM8403: http://amzn.to/1pgkPIH
1x HD44780 16x2 LCD: http://amzn.to/1SzDmLh
1x MT3608: http://amzn.to/222Y4G9
1x TP4056: http://amzn.to/1pgl1YB
1x Micro USB breakout: http://amzn.to/1pgldqR
1x 18650 Li-Ion battery: http://amzn.to/1pglkTi
1x Slide Switch: http://amzn.to/1pglJFj
1x Rotary Encoder: http://amzn.to/1pglLgm
1x Speaker: http://amzn.to/1pglYQv
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor: http://amzn.to/1pgm2Ql
1x 10kΩ Potentiometer: http://amzn.to/1pgmspN
1x 100nF, 1x 220nF Capacitor: http://amzn.to/1pgmRZq
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor: http://amzn.to/1pgmEFu
1x Retractable Antenna: http://amzn.to/1R70xqZ
2x 5mm RGB LED: http://amzn.to/1pgn7Yt
Perfboard with copper dots: http://amzn.to/1pgndz7
Ebay:
1x Arduino Pro Mini: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
(Optional) FTDI breakout: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TEA5767: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MCP4151: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TDA1905: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
or (Optional) 1x PAM8403: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x HD44780 16x2 LCD: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MT3608: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TP4056: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Micro USB breakout: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 18650 Li-Ion battery: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Slide Switch:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Rotary Encoder: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Speaker:http://rover.ebay.com/rover/1/711-53200-19255-0/1?..
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 100nF, 1x 220nF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Retractable Antenna: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 5mm RGB LED:http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Perfboard with copper dots: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress:
1x Arduino Pro Mini: http://s.click.aliexpress.com/e/iIyR3R3Fa
(Optional) FTDI breakout: http://s.click.aliexpress.com/e/RrR7qzrR7
1x TEA5767: http://s.click.aliexpress.com/e/auNnYjm2b
1x MCP4151: http://s.click.aliexpress.com/e/3rfqn2vfi
1x TDA1905:http://s.click.aliexpress.com/e/6uNzR3jii
or (Optional) 1x PAM8403: http://s.click.aliexpress.com/e/v7UfeEIEI
1x HD44780 16x2 LCD: http://s.click.aliexpress.com/e/m6UNFyBIe
1x MT3608: http://s.click.aliexpress.com/e/N7eemQNfA
1x TP4056: http://s.click.aliexpress.com/e/bYFYV7imu
1x Micro USB breakout: http://s.click.aliexpress.com/e/mAqjAqfQJ
1x 18650 Li-Ion battery: -
1x Slide Switch: http://s.click.aliexpress.com/e/bEMRz7Y7Q
1x Rotary Encoder: http://s.click.aliexpress.com/e/z33RvJEQB
1x Speaker: http://s.click.aliexpress.com/e/yfIEamQvn
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor: http://s.click.aliexpress.com/e/NrjaM7qfQ
1x 10kΩ Potentiometer: http://s.click.aliexpress.com/e/Rj2V7E6YZ
1x 100nF, 1x 220nF Capacitor: http://s.click.aliexpress.com/e/funiea6EU
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor: http://s.click.aliexpress.com/e/AEaMjEeQF
1x Retractable Antenna: http://s.click.aliexpress.com/e/MV3JqvFEQ
2x 5mm RGB LED: http://s.click.aliexpress.com/e/BmeYrBiYv
Perfboard with copper dots: http://s.click.aliexpress.com/e/7mi2rbe6A
Amazon.de
1x Arduino Pro Mini: http://amzn.to/1HwhJ8d
(Optional) FTDI breakout: http://amzn.to/1JbxEah
1x TEA5767: http://amzn.to/1U4FTOC
1x MCP4151: http://amzn.to/1TNHlp7
1x TDA1905: -
or (Optional) 1x PAM8403: http://amzn.to/1TNHzwq
1x HD44780 16x2 LCD: http://amzn.to/1TNHCbQ
1x MT3608: http://amzn.to/1U4G2l9
1x TP4056: http://amzn.to/1NnD3hB
1x Micro USB breakout: http://amzn.to/1PNqUYL
1x 18650 Li-Ion battery: http://amzn.to/1U4G3FW
1x Slide Switch: http://amzn.to/1U4G7p1
1x Rotary Encoder: http://amzn.to/1YAoEEp
1x Speaker: http://amzn.to/1U4G5h5
6x 10kΩ, 1x 3.3kΩ, 1x 100Ω, 1x 1Ω Resistor: http://amzn.to/1E9uEhN
1x 10kΩ Potentiometer: http://amzn.to/1YAqrJC
1x 100nF, 1x 220nF Capacitor: -
3x 1µF, 1x 2.2µF, 1x 10µF, 1x 220µF Capacitor: http://amzn.to/1YAqEfK
1x Retractable Antenna: http://amzn.to/1U4GEHF
2x 5mm RGB LED: http://amzn.to/1U4GEYf
Perfboard with copper dots: http://amzn.to/1YAqPI8
Step 3: Create the Circuit!
Use the given schematic to create the circuit. It is always a good idea to wire up the components on a breadboard before moving the circuit over to a perfboard.
Step 4: Upload the Code!
Here you can find the Arduino Code you need to upload before the radio can function properly.
Step 5: Build Your Case!
Here you can find the vector graphics I made for my own case. Feel free to use them to mill your own one or print them out and use them as a template. After your case is complete it is time to mount all your other external components and main perfboard inside it.
Step 6: Success!
You did it. You just built your own FM Radio!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
4 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
82 Discussions
Matthew37EDA
Question 8 days ago on Introduction
Would the circuit work on 5 volts and if so how much current would it draw?
edadams
2 years ago
Got it mostly working, but for some reason it is constantly switching between modes (freq and volume)... I've tried different Arduinos and various hardware debounce techniques. Any ideas?
edadamsedadams
Reply 2 years ago
Got it figured out... oddly enough it was the way I was powering my arduino. When powered via wall-wart or usb it caused a jumpy mode switch. Powered by battery or my bench supply it's smooth as glass.
Piluscaedadams
Reply 5 weeks ago
Put the rotary SW pin between 10k rezistor & 100nF and GND pin of rotary switch to GND and everything with works “like a charm” !
JohnS61edadams
Reply 1 year ago
I'm having the same issue. I did try and power it from the wall and also from a battery, but it still switches. Any advice? :(
lestat6666
5 weeks ago
Can you please share the Eagle-Schematic ?
sanwer solanki
2 years ago
we are making this fm radio project using arduino pro mini .we need the pcb layout of the circuit to complete our project .please provide us the pcb layout
PaundraT
1 year ago
Can you make a circuit WITHOUT the amplifier?
callumw18PaundraT
Reply 2 months ago
Without the amp it will work but noooo... Sound
Delta4Phoenix
Question 3 months ago on Step 3
Die Auflösung des Schaltplans ist zu niedrig. Kannst du den Schaltplan bitte in höherer Auflösung nochmal hochladen?
obulut2
Question 5 months ago
Schema isn't clear could you upload it again please?
obulut2
Question 5 months ago on Step 3
Merhaba, şema net değil.Yeniden yükler misiniz?
TaranA3
8 months ago
i would like to see a build video on building a radio using 1 pcs TDA1905 5W Audio Amplifier with Muting IC New DIP ST, • Digital Potentiometer - 10K, Audio Jack 3.5mm, ELEGOO 17 Values 1% Resistor Kit Assortment, 0 Ohm-1M Ohm (Pack of 525),Ceramic Capacitor Assortment Kit - Set of 600 Small Assorted Capacitors from 100 nF to 10 uF in a Box - Non-Polarized Disc Capacitor Component Set from Plusivo, Electrolytic Capacitor Assorted Assortment Box Kit,500PCS,Pair 62.5cm 4 Section Telescopic Stainless Steel AM FM Radio Antenna, microtivity IL612 5mm Diffused RGB Controllable LED, Common Anode (Pack of 12),MicroSD card module for Arduino and a Breadboard - Mini and the audio jack is used for when you want to listen to the radio via speaker
TaranA3
Question 9 months ago
and how do you hook up the
Digital Potentiometer? like what connect to what
1 answer
TaranA3
how meny volts does the radio need to operate?
TaranA3
could i use avbestlife dc dc voltage converter power supply module
12v to 3.3v/5v/12v step down converter module as a power supply?
팜기엔
Question 11 months ago on Step 3
what software do you use to creat schematic circuit
팜기엔
Question 1 year ago on Step 3
what is connect to d2 and d3 of the arduino
