Make Your Own Oil Cloth | DIY Waterproof Outdoor Bunting
12,127
88
22
About: Multi-crafter, jewellery maker, card designer and frequent procrastinator.
I wanted to make some bunting that was suitable for keeping outside, and during my research I came across a way of making your own traditional oil cloth using boiled linseed oil.
The advantage of this over the modern plastic-based version of oil cloth is that it doesn't look and feel like plastic and keeps the flexibility of the fabric.
Usually oil cloth is used for waterproof bags, clothing, luggage, tents and so on.
Not many ingredients are required, and it's a very simple process, so I hope you'll give it a go!
Step 1: What You Will Need
The main ingredients for making oil cloth are boiled linseed oil and mineral spirits; the oil is what makes the fabric waterproof, and the mineral spirits are required to make the oil dry out (otherwise it would stay wet/sticky).
Boiled linseed oil is usually used as a finish for wood projects.
For the amount of bunting I made, I required no more than 50ml of each of these liquids. I also chose to use the odourless version of mineral spirits to make it more pleasant for me!
I also used the following items:
- Breathing mask, gloves, ventilation etc for safety when mixing the liquids.
- Fabric; You need to use a sturdy woven fabric (not stretchy) for this. I used a cotton canvas. (Close weave) linen is also an option.
- Oil paints; If you wish to paint a design on the fabric. You can also use oil dyes.
- Paintbrush
- If you wish to potato print a pattern, you will need a potato, a knife and a cutting mat.
- Some kind of inking/painting tray that's big enough for your fabric pieces to go in and has a lip around the outside. If the fabric you want to turn into oil cloth is too big or you don't have a tray (or suitable plastic packaging) you can just use a wide paint brush to paint on the oil mixture whilst the fabric is on a protective drop cloth or similar.
- Measuring cup; I used a disposable paint mixing cup.
- Sealable glass or metal container; I used a glass jar with a lid.
- Pegs & a washing line
- Pinking shears; To cut out the fabric pieces with, to help prevent fraying. You could instead choose to hem the bunting with a sewing machine if you wish, but that would be time consuming.
- String/twine; I used a jute twine. You could instead use fabric such as bias binding (which you could also waterproof if you wished).
- Super glue or a sewing machine & thread; You can use glue or a sewing machine to attach the bunting to the string. I used an all-purpose (UHU) adhesive.
- Ruler
- Fabric pen or sewing pins
- Scissors
- Pen/pencil
- Piece of paper
Step 2: Make the Template
For my bunting, I decided I wanted the triangles to be around 5" x 7" in size, but I needed an extra 1" of length to fold over the string at the top. So I measured out 5" x 8" on a sheet of paper and cut that rectangle out.
I then folded this rectangle vertically down the centre (so the fold was at the 2.5" halfway point).
I could then, whilst keeping the paper folded, cut a single line, corner to corner, to produce a symmetrical triangle.
Then finally, on the top 1" of the triangle, I cut off the corners. This is so that when this 1" of fabric is folded over later, it won't be seen from the front.
Step 3: Cutting Out the Fabric
The photos show 2 ways of doing this, depending on if you have a 'magic/disappearing' fabric pen or just sewing pins:
1) Just draw around the paper template using a ruler and fabric pen, then cut the shape out with pinking shears.
or
2)Pin the template to the fabric and cut around the shape with pinking shears.
Try and minimise the wastage of fabric when doing this by cutting the shapes out close together.
I cut out 7 triangle shapes in total.
Step 4: Printing & Painting
It's completely optional to paint the fabric, or indeed potato print it, particularly as potato printing is not an accurate means of painting (!). Using oil dyes are also an option as a means of decoration.
To make my printing pattern, I first cut a simple line shape in the potato, and put some white oil paint in the inking tray. I used a cheap paintbrush to apply the paint to the potato to print with it, and also to paint directly onto the fabric.
Remember to protect your work surface from the paint during this stage.
Oil paint takes a long while to dry (anywhere from 24 hours to weeks depending on the paint brand, the temperature, humidity etc). So just leave your fabric until the paint is touch dry before continuing to the next stage.
Step 5: Turning the Fabric Into Oil Cloth
I used a breathing mask and gloves during this step, and also did it outside for best ventilation.
I placed a fabric piece on my inking tray, and then measured out the liquids.
The key is to mix equal parts mineral spirits and boiled linseed oil. I used 100ml of each (using my disposable measuring cup to measure them out), but this turned out to be at least twice as much as I needed. So start with a smaller amount, because you can always mix more later.
I poured the 100ml of each into a glass jar and mixed thoroughly with a lollipop stick. The reason for putting it in a sealable glass or metal container is so that you can then keep and store any remainder inside this container. You shouldn't store it in a plastic container. Always read the instructions on the packaging for more info about safety.
Then pour some of the mix into the inking tray, onto the fabric piece. The fabric should soak the liquid up. I tilted the tray back and forth until all of the fabric was saturated, and then I hung the piece up on the washing line.
Do this for every piece.
If you don't have a lipped tray (or a big enough tray), you can instead spread the fabric out on a drop cloth and paint the liquid onto it with a wide, flat paintbrush.
Then just leave the fabric to dry thoroughly outside. This could take anywhere from a day or two, to a couple of weeks, depending on weather and fabric used.
Step 6: An Important Safety Note
Boiled linseed oil heats up as it dries, and particularly if it's on a piece of material that has been crumpled up/folded, or put in an enclosed space, the heating can be intense. This causes fires so please be very careful!
So the important things to do are:
- Let the fabric dry outside, and make sure the fabric is laid out (or hung) flat, not folded or crumpled up.
- Dry any other items that have had linseed oil on them outside too, before washing them or disposing of them. This includes paper towel, fabric rags, drop cloths etc.
- Store any remaining liquids in their original containers or in a metal (or glass) container.
- Always read the instructions on the packaging.
- Keep items with linseed oil on away from anything flammable until fully dry.
- If it starts raining so you can't store the fabric outside, lay the fabric out flat on a non-flammable surface in a cool room, with ventilation, until completely dry.
Step 7: Assembling the Bunting
From the first photo, you can see that water now doesn't get absorbed into the fabric. Success!
I then used super glue to fold over and secure the top section of each triangle of fabric, so that it covered the twine, but allowed the twine to still move through the fabric.
Leave to dry.
Step 8: Finished!
You can now display your bunting in pride of place in your garden!
I hope you enjoyed this Instructable, and thanks for reading :)
Oil Contest
First Prize in the
Oil Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    22 Discussions
    k24tea
    7 months ago
    Thank you for sharing this, and congrats for winning! I just love simple, practical "old-time" projects like this that make use of readily available materials & tools to make something fun and creative. When I was a child we did this on a plain piece of canvas (painter's drop cloth?) to make a picnic ground-cover. We used a big paint brush to saturate the canvas with the linseed oil. Your potato stamps came out better than mine! Later a friend made a yurt and waterproofed it with linseed oil.
    WmC2
    7 months ago
    A small amount of Japan drier will speed up the drying process.
    ata1anta
    8 months ago
    Thank you for this! I'm planning on treating a duster I made many years ago out of denim. I'd thought of using re-proofing cream, but this would probably be better.
    ddj0195
    8 months ago
    Love this DIY, thank you. Other than waterproofing, how does this affect the fabric? I expect the fabric will be stiffer than before, heavier. How does your bunting stand up to weathering by the sun? Does it by chance help resist the UV damage from being outdoors? The earliest signs of UV damage are color fading.
    FernMakesddj0195
    Reply 8 months ago
    I haven’t done thorough testing yet - the bunting has been in my garden only a few weeks - but I will update if I notice any fading etc.
    The main effect is that the colour of the fabric darkens, and perhaps it becomes slightly heavier and less soft/flexible. Only very minor differences though.
    Cat00x
    8 months ago
    Thank you for this instructable. I was thinking about an oil cloth tablecloth for camping but it would obviously be very large. Do you think you could fold the fabric so it fits in a smaller tray and soak it with the oil mixture that way? I loved your bunting idea.
    FernMakesCat00x
    Reply 8 months ago
    Thank you :) I think you could definitely do that but you’d have to make sure the tablecloth was completely spread out until dry - and isn’t kept folded up at all after the initial quick soak. I hope you have a go!
    Drboyd
    8 months ago on Step 6
    How long did you let the fabric soak? (FYI - you should have made this two lessons. Too much info on the bunting mixed in with the oil cloth. Don't care about the bunting. The oil cloth is the draw.)
    FernMakesDrboyd
    Reply 8 months ago
    I just let the oil soak through the fabric, which happened within a few seconds - no need to leave the fabric soaking for longer than that.
    fkunitzDrboyd
    Reply 8 months ago
    You don't really need to soak the cloth. Just get it covered in oil all over.
    Gadisha
    8 months ago
    Nice idea,why not use regular linseed oil?
    From what I've read (concerning woodworking) this should dry out as well,it will only take longer.
    FernMakesGadisha
    Reply 8 months ago
    Boiled linseed oil simply dries quicker, that's the only reason :)
    mark+autodeskFernMakes
    Reply 8 months ago
    "Boiled" linseed oil you buy from your local hardware store or home store probably has not been boiled. The reason it dries better than raw linseed oil is the addition of chemical drying agents. Usually a petrochemical substance.
    There is no problem with it for most people but neither is it completely harmless. Some people can have reactions to it. Rare, but it does happen.
    For the purpose you are using it for; it should be fine.
    For those people that do have a reaction; they should look for food grade linseed oil.
    krauseli
    Question 8 months ago
    Does this waterproofing method work as well with felt?
    1 answer
    fkunitzkrauseli
    Answer 8 months ago
    It should, but be even more careful about spontaneous combustion.
    jprussack
    8 months ago
    Love it! i looked this up years ago and never found a recipe. Thanks for sharing this great instructable!!
