Make Your Own Power Meter/Logger
80,158
490
47
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how I combined an Arduino, an INA219 power monitor IC, an OLED LCD and a Micro SD Card PCB in order to create a power meter/logger that has more functions than the popular USB Power Meter. Let's get started!
Step 1: Watch the Video!
The video gives you a good overview on how to create your own power meter. In the next steps though I will present you some additional information to make this project even simpler.
Step 2: Order Your Parts!
Here you can find a parts list with example seller for the portable version of this project.
Amazon.com:
1x LiPo Battery: http://amzn.to/2gz4yvd
1x TP4056 Board: http://amzn.to/2gzdIb4
1x Arduino Pro Mini: http://amzn.to/2gvfXuQ
1x INA219 Board: http://amzn.to/2gvflW7
1x OLED LCD: http://amzn.to/2fobopO
1x SD Card PCB: http://amzn.to/2fodhmu
1x Switch: http://amzn.to/2gz9ZtW
Ebay:
1x TP4056 Board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Arduino Pro Mini: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x INA219 Board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x OLED LCD: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x SD Card PCB: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x LiPo Battery: http://amzn.to/2gM2vXB
1x TP4056 Board: http://amzn.to/2eUvMNO
1x Arduino Pro Mini: http://amzn.to/2g6Ujjr
1x INA219 Board: http://amzn.to/2gM5M9v
1x OLED LCD: http://amzn.to/2g6Q3Rd
1x SD Card PCB: http://amzn.to/2gM9Zdf
Step 3: Create the Circuit!
Here you can find the schematic for the Arduino Nano version and the portable version of this project. You can also find those schematic on the EasyEDA website:
https://easyeda.com/GreatScott/PowerMeter-b6051723...
https://easyeda.com/GreatScott/PortablePowerMeter-...
You can also use the pictures of my finished board as a reference for your own.
Step 4: Upload the Code!
Now that your circuit is complete, it is time to upload the code. You can download it here. But don't forget to download and include the following libraries before uploading:
https://github.com/adafruit/Adafruit_INA219
https://github.com/adafruit/Adafruit_SSD1306
https://github.com/greiman/SdFat
Step 5: Success!
You did it! You just created your own Power Meter/Logger
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
5 People Made This Project!
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
47 Discussions
DerekA46
Question 7 months ago
So I know this have been here a while but I have a few questions,
1. How to do you modify the code so it only records an input measurement every 10min? [Figured this out... a few coding changes and it works like a champ. I had to seperate out the unsigned long interval for the reading measurements and unsigned long interval for the display readings.
for future reference if you want to change the time between reading measurements saved to the SD card the code should read like this:
updated code:
unsigned long previousMillis = 1799910; // this number is set to take a reading when program starts
unsigned long interval = 1800000; // interval time between data recording Set in milliseconds.
unsigned long previousMillisDisp = 0;
unsigned long intervalDisp = 100; // interval time between LCD refresh Set in milliseconds.
const int chipSelect = 10;
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
float energy = 0;
File TimeFile;
File VoltFile;
File CurFile;
void setup() {
SD.begin(chipSelect);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
ina219.begin();
void loop() {
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval)
previousMillis = currentMillis;
ina219values();
TimeFile = SD.open("TIME.txt", FILE_WRITE);
if (TimeFile) {
TimeFile.println(currentMillis);
TimeFile.close();
VoltFile = SD.open("VOLT.txt", FILE_WRITE);
if (VoltFile) {
VoltFile.println(loadvoltage);
VoltFile.close();
CurFile = SD.open("CUR.txt", FILE_WRITE);
if (CurFile) {
CurFile.println(current_mA);
CurFile.close();
displaydata();
if (currentMillis - previousMillisDisp >= intervalDisp)
previousMillisDisp = currentMillis;
ina219values();
displaydata();
***Everything else within the code should remain the same.***
2. I am trying to measure the voltage and current drop of a battery operated LED light string... I can get the correct current to be displayed but no matter what I do the circuit will only display 1V. What am I doing wrong?
Thanks again for your help and this is a great setup!
Chiranjiv_sc30DerekA46
Answer 27 days ago
Hey can I get a copy of the entire code?.I would like to compare it with mine for rectifications.??
DerekB103DerekA46
Answer 2 months ago
HI DerekA46,
Did you ever work out the 1V issue? I have just created the power meter in last day or two and have exactly the same issue. If I manage to work it out (with my limited coding and electronics ability) before I hear back from you, I'll post a reply here.
Else, if you already have the answer, I'd appreciate knowing!
Thanks.
DerekB103DerekB103
Reply 2 months ago
So, with a little bit of thought and watching the video again, I was able to work out the 1V issue ... and it really makes simple sense.
In the video, when he mentions when connecting the testing load and source, that you connect the positive lead of the source to the Vin+ of the INA219, you connect the Vin- to the positive terminal of the load, and then you connect the negative terminal of the load to the GND of the measuring device (the Arduino). Obviously, I had to connect something to the negative end of the source or the load wouldn't draw any current(there would be no complete circuit), so I thought that's what he meant ... connect the negative terminal of the load to the negative end of the source.
What he actually means is, connect the negative terminal of the load to the negative end of the source AND the GND of the measuring device. You have to connect it to BOTH. Without a connection to the GND of the Arduino as well as the negative of the source, you cannot measure a true Voltage drop and so, the display only ever shows 1V.
That fixed my 1V issue rioght away!
mlhanes
Question 4 weeks ago on Introduction
How can this project be adjusted to monitor higher wattage useage like with appliance? I would like to build this to monitor copier power useage and perhaps spikes.
mlhanes
Question 5 weeks ago on Introduction
Can this project be used to monitor a larger piece of equipment like for instance a copier?
DerekB103JabinS1
Answer 8 weeks ago
Yes, it can.
The "load" will be whatever you are connecting to your panels, whether a battery to store your energy or some device you are powering. The "source" will be your panels. All you need to do is, more or less, connect this device between your panel and your device/battery.
EthanB98
Question 2 months ago
How do i use this to measure 9V 3W solar panels?
1 answer
DerekB103EthanB98
Answer 8 weeks ago
sagiro
Hello,
I wanted to know if there is a way to turn it into a solar panel tester to know how much energy I can get from the cell in various places around my house and find the best place to position the panel.
Can this do what I'm asking?
1 answer
DerekB103sagiro
Answer 8 weeks ago
Yes, it can.
smooth_jamie
2 years ago
Hi there, nice project. I'm curious as to what the lowest measured current is possible on this project and what the accuracy is?
smooth_jamieGreatScottLab
Reply 2 years ago
Done what you've suggested, datasheet gives ADC resolution, and accuracy (fair enough), but doesn't really answer the first part of my question. I'd like to know with regards to the way this is setup, what is the lowest current you have managed to measure? A approximate idea would be very helpful.
pingouin_smooth_jamie
Reply 2 months ago
Hello,
Full scale shunt voltage is 40mV (for PGA /1). Depending on the Rshunt value you select, you might get quite low on measured current...
martinezJ2
2 months ago
is it normal that i have in voltage 32,72 Volts ??
BHRAMOSk
Question 3 months ago on Step 2
I am from india and the LiPo battery isnt ship to India. Is there any alternative and can i use 6V D.C. battery.
Lofty1960
1 year ago
Hi Great Scott and all,
WHen compiling code I get this error. I am using Pro Mini, Arduino IDE 1.6.13 and the librabies that are listed on this site.
Any help would be appreciated.
Sketch uses 22,302 bytes (72%) of program storage space. Maximum is 30,720 bytes.
Global variables use 2,216 bytes (108%) of dynamic memory, leaving -168 bytes for local variables. Maximum is 2,048 bytes.
processing.app.debug.RunnerException: Not enough memory; see http://www.arduino.cc/en/Guide/Troubleshooting#si... for tips on reducing your footprint.
NathanS213Lofty1960
Reply 8 months ago
A bit late, I know, but I was having the same issue and realised that the screen uses up a lot of memory. I'd previously updated Adafruit_SSD1306.h to select the 128x64 screen, but I notice Scott has the 128x32 screen configured - this uses half the memory and allowed the program to compile. With only 2K of SRAM to work with you have tp save space where you can I suppose.
