Make Your Own Spy Bug (Arduino Voice Recorder)
32,185
148
26
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how I combined an Arduino Pro Mini with a couple of complementary components in order to create a voice recorder which could also be abused as a spy bug. It has a run time of around 9 hours, is small and super easy to use. The recording quality might not be the best, but it should be suitable for many purposes. Let's get started!
Step 1: Watch the Video!
The video gives you all the information you need to create your own Spy Bug. During the next steps though I will present you some additional information.
Step 2: Order Your Parts!
Here you can find a parts list with example sellers for all the components that you will need.
Amazon.com:
1x Arduino Pro Mini: http://amzn.to/2Eh0YnW
1x LiPo Battery: http://amzn.to/2E30BcU
1x TP4056 LiPo Charge/Protection Board: http://amzn.to/2s77dWo
1x Micro SD Card Adapter: http://amzn.to/2GMEY2G
1x Electret Mic + MAX9814 Amp: http://amzn.to/2GLB5uJ
1x Tactile Switch: http://amzn.to/2Eh15Qo
1x 5mm Red LED: http://amzn.to/2GNotDt
1x 2kΩ Resistor: http://amzn.to/2GNouY3
Ebay:
1x Arduino Pro Mini: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LiPo Battery: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x TP4056 LiPo Charge/Protection Board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Micro SD Card Adapter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Electret Mic + MAX9814 Amp: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Tactile Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 5mm Red LED: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 2kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Arduino Pro Mini: http://amzn.to/2FHf9PY
1x LiPo Battery: http://amzn.to/2DZnbY5
1x TP4056 LiPo Charge/Protection Board: http://amzn.to/2EE8pTT
1x Micro SD Card Adapter: http://amzn.to/2nHrsVd
1x Electret Mic + MAX9814 Amp: http://amzn.to/2FHzW60
1x Tactile Switch: http://amzn.to/2BTCxYg
1x 5mm Red LED: http://amzn.to/2BTCyLO
1x 2kΩ Resistor: http://amzn.to/2nKX5NN
Step 3: Build the Circuit!
Here you can find the schematic and pictures of my finished Spy Bug. Feel free to use them as a reference.
Step 4: Upload the Code!
Here you can download the Arduino code for the project. Use an FTDI breakout to upload it to the Arduino Pro Mini. And don't forget to download/include the TMRpcm library:
https://github.com/TMRh20/TMRpcm
Step 5: Success!
You did it! You just created your own Spy Bug!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
  • Weaving Challenge
    Weaving Challenge
  • Epilog X Contest
    Epilog X Contest
  • Trash to Treasure
    Trash to Treasure
26 Discussions
GiorgosK92
Question 6 days ago
Greetings,
What format was the sd card fat32 or fat?
thank you in advance
GiorgosK92
Question 19 days ago
Greetings,
What role is playing the while loop in first 4 lines in void loop?
Thanks
Amine19
Question 8 weeks ago
what parameters make the recording time encrease or decrease, plz , i need to record up to 12hours for my school project
sanjay sonkar
8 months ago on Step 4
exit status 1
'class TMRpcm' has no member named 'startRecording'
how to fix this error
pls help Great scott
LeonardoV46sanjay sonkar
Reply 2 months ago
In the Arduino IDE go to Sketch/Include Library/Add .ZIP Library, now that you have added the Library to the Arduino IDE go to \Documents\Arduino\libraries there you will find the TMRpcm library, modify the pcmConfig.h file, around line 75 is a #define ENABLE_RECORDING just uncomment that line and the one below that is #define BLOCK_COUNT 10000UL, save the .h file and compile again.
paclevkov
5 months ago
There is config file in the library. Scroll down and find Recorder option, uncomment it to set the library to Recorder mode. Then the code will compile successfully.
KunalB33paclevkov
Reply 2 months ago
Can you please explain this in detail.I'm not getting what you're saying. I'm stuck at this project
paclevkovKunalB33
Reply 2 months ago
Sure, after downloading the library, open the folder TMRpcm, in the main root, you can find pcmConfig.h file. Open it with text editor program. Scroll down to line 75(different lines can be found on different versions, mine is 75), you will see that, there is commented row: //#define ENABLE_RECORDING.
Uncomment it, delete the tho "//" symbols, it should look like this:
Save the file
as last step.
TristanS50
Question 3 months ago
When I record my WAV files come out with no data. I cannot play any of the files I get. What could be wrong?
AlperD8
Question 4 months ago
Can i use max 4468
JOSEPHW144NathanR124
Answer 7 months ago
you could always add that functionality yourself..
SonakulK
Question 9 months ago
i dont have microsdcard, it work?
arduinonewbie
Question 10 months ago on Introduction
Thanks for the great tutorial. Being a newbie in arduino, I followed the instructions precisely and I'm able to record voice. I use Arduino Uno and the SparkFun Electret Microphone Breakout. I haven't incorporated the batteries yet and the system is powered by my laptop through a usb cable. Unfortunately, there is a continuous popping sound in the recorded wav file. Any ideas why this happens?
tomik986TM
Can I ask anyone, when I am recorded a .waw file it has 5000kB or length of 9:21:26 and I don't know why. Thanks everyone who answered.
1 answer
zonkerharristomik986TM
Answer 10 months ago
Did you maybe "startrecording", but not use "stoprecording" until 9 hours later?
Bikramghuku05
Question 12 months ago
It is showing error that tmpcm does not have any members named startrecording and stoprecording
1 answer
onlun79Bikramghuku05
Answer 12 months ago
You need to edit the header file (pcmConfig.h) to enable the recording function.
dpcons
Question 1 year ago
Implemented system as described. Works well except audio playback is at a higher rate.
(i.e chipmunk voice). I'm using Windows media player. Do I need to modify something.
Thanks, nice project.
