Sanding Pads With Velcro Backing Made Easy
57,843
239
24
About: I'm a 49 year old Systems Architect living in the Midwestern United States. After travelling the world for 20 years as a consulting architect I became disabled, as a result, I am now embracing a Slow life.
Why?
I love having a cordless oscillating multi-tool (mine happens to be a Dremel Multi-Max). What I don't love however, is when I have to do a lot of sanding and the sanding pads cost $15 per 18 pack. In this Instructable, I hope to show that with just a few items, including an old shirt, you can make loads of these pads for much less.
Items needed:
  • A old shirt that sticks to Velcro. $0
  • A can of spray adhesive [I used 3M Super 77 which I happened to have lying around and will last for 20 to 40 sheets of sandpaper] $16
  • A 9x11 inch sheet of sandpaper with desired grit [again, I had some 3M paper lying around] 4 sheets for $3
  • A pair of scissors
  • A marker or pen
Supplies:
Step 1: Prepare Old Shirt
Using the Velcro tool attachment, go through any old shirts or rags and see if any stick to the attachment. In my case I found an old 100% polyester shirt that I wouldn't mind sacrificing (there is something to be said for 100% cotton shirts). Once you have identified a shirt, cut out the sleeves, collar, etc... Discard the collar (remember to keep those buttons!) and cut along all the seams so that you end up with nice, flat, single layers of fabric.
Step 2: Prepare Sandpaper
In a well-ventilated area, on a durable surface, place your sandpaper grit side down. Spray generously with spray adhesive, being sure to keep the nozzle at least 6" away from the paper. After you are done spraying, remember to tilt the can upside down and spray a little to clean the nozzle. Set a timer for 9 minutes and get yourself a cup of tea or coffee. This wait time is to allow the adhesive to get tacky for the next step.
Step 3: Putting the Sandpaper Pad Together
Once the time is up, lay your fabric over the sheet of sandpaper and work out any wrinkles. You will notice the adhesive is sticky, but not too sticky to allow you to realign the fabric and pull out wrinkles as necessary. Once you have the fabric flat and wrinkle-free, lightly rub your hand over the surface to press the fabric into the adhesive. Set a timer for 15 minutes and get some more tea or coffee :)
Step 4: Cutting the Sandpaper Pad Apart
After the time is up, trim away any large pieces of fabric. Don't worry about the edges looking clean, they are going to get trimmed off anyway. Holding the tool or just the attachment over the grit side of the sandpaper, use a marker to trace the outline of the attachment onto the sandpaper. You should be able to get at least 9 pieces out of a 9x11 inch sheet. Once that is complete, simply cut out the shapes with your scissors and voila!
Step 5: Conclusion
Your pads should now be ready to use on your sanding tool. If my math checks out, you use about 1/20th to 1/40th of the can of adhesive, so $16 divided by 20 is $.80. 4 sheets of 9x11 inch sandpaper are $3. 4 sheets of sandpaper will yield 36 pads so that is $3.80 per 36 pads or 18 pads for $1.90. I like that a lot better than $15.
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    24 Discussions
    jayj
    7 days ago
    Thanks for posting this. Would this adhesive hold for wet/dry sandpaper? Using a cordless sander, of course.
    TheCoffeeDudejayj
    Reply 6 days ago
    I have used it for wet sanding successfully, however, I would add that I always use pads that were glued up several days prior.
    MeeC1
    4 months ago
    Thanks for the inspiration. I went even cheaper: I simply cut and glue sand paper on old sanding pads
    sipxstream
    1 year ago
    Sheets of felt fabric work well for this too!
    I laid down an A4 (I'm in the UK) sheet of aluminium oxide paper, glued the back of it and pasted it on top of a sheet of felt fabric. One it had dried, I cut out the triangle shapes of my palm sander and then used a drill press to drill out the holes. The fabric adheres to Velcro quite well when secured down properly, but the only problem is that it does sometimes leave fibres on the velcro backing when removed. Easily cleaned, and not a big deal, especially if it saves you money.
    garagedoorguy
    2 years ago
    Scotchbrite!!!
    I was running into the same problems you fellas were, so I grabbed everything I could think of, not even cotton T-shirts would do the trick. So I ws going through all my many years of collected things and found a new scotchbrite pad , Lowes or Home Depot, cant remember which, you can buy em in 10 packs at the time, and different grits as well.
    Stuck very nicely to the velcro, havent mounted it to and sandpaper yet, and due to the thickness it may either have to be split down the center or may need a stiff or semi stiff material 3m'ed to it. regardless of how you use it, I beleive those of you who dont have access to velcro tape, this may be the way to go, hope this helps anyone stuck, cheers
    PaulS312
    3 years ago
    Didn't work out to well for me. My shirt wouldn't grab as well flattened out but the 800 grit paper was so thin it just flexed and curled. I'm gonna try again with some cardstock to stiffen it up and find a better shirt.
    TheCoffeeDudePaulS312
    Reply 3 years ago
    Before I throw away a shirt with a tear or hole in it, I velcro test it on my multi-max. I've managed to compile a sizeable bag of compatible shirts.
    I haven't run into the thin sandpaper stock issue, so please let me know if the cardstock solution works.
    buck2217
    3 years ago on Introduction
    I do this as well for all my sanders, I just use sticky backed velcro (that I liberate from work) such a money saver 9Even if you have to buy everything!)
    Raigmoul
    4 years ago on Introduction
    Hi there,
    Nice idea, I love my multi-tool (I have a Bosch model), and if I'm doing lots of sanding, the paper is really expensive here in the UK. Also, I can't seem to find the finer grits (400 and above) which I need quite often.
    I've been using a different approach, self adhesive velcro - I've used sheets or tape, whichever's available - stick it to the back of sanding paper (after I've cut it) for instant results.
    1 tip: the velcro on the pad itself will sooner or later wear out, I use the other side of the velcro sheet / tape to replace it, saves a few £/$ and you don't have to wait for new pad!!
    Cheers,
    R
    TheCoffeeDudeRaigmoul
    Reply 4 years ago
    Thats a great idea if the tool side velcro wears out. I haven't seen that happen yet, but will definitely keep that in mind.
    I have had this happen to me and the cost to replace the sanding base was not much less than buying a new sander (Craftsman C3 Mouse sander). I never thought of replacing the male end of the Velcro on the sander. Thanks Raigmoul. And thanks again to you Scottbus.
    If your looking for 400+ grit, 600, 800, 1000, 1500, etc check your local auto body supply shops.... usually if they sell auto paint, bondo, then they'll have the finer sand grit also.. Cheers, E:L
    Hi EL,
    I can easily find the finer grits, it's the velcro backed ones that I have trouble getting. I found some on ebay, only problem is the paper was of low quality: it clogged up easily, and as many of you have found I'm sure, the heat causes the backing strip to come off... plus the cost :-)
    This is WAY cheaper than buying pre-velcroed (is that even a word??), and it means you can control the quality and grit :-)
    Cheers,
    R
    RyanMoore22
    Life saver. I'm so cheap that I would duct tape sand paper onto a sanding block before I would buy more Velcro pads for my oscillating sander. Is anyone with me on this?
    PetrichorXFi
    4 years ago
    Very Nice!
    How well does this stay attached? I have tried similar with a circular spinning pad, but with heat it would often come off...
    TheCoffeeDudePetrichorXFi
    Reply 4 years ago
    They adhere remarkably well due to the type of adhesive and the fact its allowed to tack first. An even stronger bond can be achieved by spraying the sandpaper and the fabric then waiting 9 minutes to put them together, but I found that this wasn't necessary and used up more adhesive and made adhering the fabric to the paper a bit of a pain.
    pantalone
    Many thanks for this. I actually avoid using my oscillating sander because the pads are so expensive. Now I can sand to my heart's content!
