Make a Bracelet From a Phone/Ipod Cord
7,824
188
11
The idea for this bracelet came from a phone charger that the dog chewed up.
Supplies:
- Phone charger cord / computer cord
- Small bracelet buckle or clasp
- Craft Glue
- Scissors
Step 1: Cord: Part 1
Cut the ends off of the cord. Remove the outside coating from the cord. If the plastic will not peel off, carefully cut sections of the plastic and slide it off the wires. Do not cut all the way through the cord.
Step 2: Cord: Part 2
The next layer is silver colored wire. Remove the wire. The four colored wires for the bracelet are inside the foil. Take off the foil and separate the wires.
Step 3: Buckle / Clasp
Put the ends of the wires through the buckle. Bend the wires down and wrap the ends. Put the other half of the buckle on the wires. The wires between the buckle halves are the length of the bracelet. Adjust it to the correct length and bend the wires down.
Step 4: Start the Bracelet
Split the four wires into groups of two. Put the first set of wires (green and white) under the four in the middle wires and over the second set (red and black) of two wires on the side. Put the second set of wires (red and black) over the four in the middle and through the loop of the first set (green and white). Tighten the knot and make sure the bracelet is still the correct length.
Step 5: Middle and End
The sets of wires change sides every knot. Repeat step 4 until it reaches the end. Go over the ends of the wrapped wires. Glue and trim the ends of the wires.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    11 Discussions
    chiczgirlzjohnstat000
    Reply 4 years ago on Introduction
    USB cords usually have the four wires. A micro/USB phone cord and an ipod cord both worked. I haven't broken any other types of cords yet.
    hailey784
    4 years ago
    I got down to the cords and had all the colors but the black cord from my iPhone charger? Three cords. I think I'll braid it. Good instructable though. Would've never thought of it.
    watchmeflyy
    Nice tutorial; it's a great way to reuse the cords' innards. :)
    Verticees
    It's too bad I threw away my broken cord. Nonetheless, awesome instructable!
