Make a Cheap Spot Welder
9,029
97
7
How to diy a cheap spot welder
Supplies:
Step 1: We Will Remove Secondary Coils With a Hacksaw
Part list:
01. 12V Relay Module External Trigger Delay Switch Time Adjustable
https://www.banggood.com/External-Trigger-Delay-Sw...
02. Button Switch
https://www.banggood.com/3A-250V-Off-on-Non-lockin...
03. 0.15x8mm Nickel Plated Steel Sheet Strap Tape Strip For Battery Spot Welding
https://www.banggood.com/0_15X8X200mm-Nickel-Plate...
Step 2: We Will Add a Second Coil
I use the 70mm cable from old generator you can use other types welding cable. I recommend using a 35mm or more cable
Step 3: Box
I use old ATX psu for the box
Step 4: Timer - Switch - Welding Needle
01. Timer
You try to use other types but there is a note that you should select the timer can set the value is 0.1s. Because if your transformer is of great value long time can burn nickel.
02. Switch
I use a foot pedal from old motor bike. You can use a button as step 1.
03. Welding Needle
I use a needle of electrical soldering iron gun. There are many options for you
Step 5: Modular Design
I designed the module to avoid the wires.
Thanks for watching my friends. See you on next project
You can support me by watching the clip on Youtube.
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    7 Discussions
    ManoelG3
    Question 8 months ago
    You said "70mm cable from old generator".
    70 mm is a width just a little less than 3 inches.
    Isn't it 0.7 mm?
    VietnamReviewsBobtoomey
    Answer 10 months ago
    This timer use 12v DC and transformer use 220v AC my friend
    DanC317
    Tip 10 months ago
    Instead of using another connector for 12V, you could add a power supply inside and connect it to mains.
    VietnamReviewsDanC317
    Reply 10 months ago
    Thanks my friend because i can use a 12v adapter for more project
    VietnamReviews
    10 months ago
    Yes my friend. You can see on clip 4:55 my finger touch the cos
