Make a DOS Command
44,360
16
42
About: I live in Estes Park, Colorado. I like anything to do with science and I do a lot of sciency things.
Many people think that DOS is outdated, but I don't think so. You can do many things with DOS,and even Eric Wilhelm uses it! (See here) Some of the things you can do with DOS include giving yourself access to important files (good for hacking), deleting things, backing up things, showing all the files and folders in a folder, making simple but harmful viruses, and reformatting hard drives (!!). Unfortunately, when you want to run a program you made, you must type in the location if you want other information to be passed on to it. This instructable will teach you how to essentially make a command so you don't have to do this.
Supplies:
Step 1: Making the Program
Start by making a DOS executable. A DOS executable is a program that is run through CMD. These files can have six extensions: .exe, .com, .bat or .cmd .vbs or .vbe. Note that that you can use things passed into the program with %1, %2, %3 and so on.
When you have the program ready, rename it to the command you want, followed by its extension. Note that the command cannot contain spaces.
When ready, continue to step two.
Step 2: Transform It Into a Command
This is what turns it into a command. Copy the file into C:\WINDOWS\system32\. That is all you need to do. To test it, open cmd by typing "cmd" into start>Run and hitting enter. Test your command. Just type the name of the file, no extension. For example, if you want to go to instructables, just copy the attached file into C:\WINDOWS\system32, and then type "instructables" in cmd.
Note-The picture is making the icon for the program, which I did in .IcoFX
Step 3: How It Works
Press the windows button and pause/break on your keyboard. It will bring up a dialog called System Properties. Click the advanced tab. At the bottom, click environment variables. In the lower group box, scroll down to Path and PATHEXT. You will notice that the first thing in Path is C:\WINDOWS\system32. That is the directory that you put your command file in. Whenever you type in the command, it looks there for that file. In the PATHEXT variable, you will see the six main extensions you can use for your file, along with some others. If the file is in a directory that it is in the path variable, then you won't have to type a location. If its extension is in the PATHEXT variable, you won't have to type its extension. You will also notice that in C:\WINDOWS\system32, there are files like help.exe, xcopy.exe, and other DOS commands. They are being run the same way your command is run. You can prove this by opening CMD and typing your command. It will work. Then type "path ;" and hit enter. That will clear the path and make CMD look only in the current directory. Then, do CD and then another directory that is not C:\WINDOWS\system32. Now try your command again. It will not work. If you try a random DOS command, it might not work. For example, xcopy, help, attrib, cacls, chkdsk and taskkill will all not work anymore. That is because the path is cleared! This also means that if your program is in "C:\I am puffyfluff", then you could just add ;C:\I am puffyfluff to the end of the path variable, and you wouldn't have to copy it to C:\WINDOWS\system32.
Now you know how to make your own command!
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    42 Discussions
    microchip55
    9 years ago on Step 2
    you have to have admin permissions to though! is there a way without being a admin or making you on in cmd?
    puffyfluffmicrochip55
    Yes, that's true, you need admin powers to access system32.  Of course, you can always just change the admin password using DOS...but that's probably something you shouldn't do.
    chriskarrpuffyfluff
    Another method of accessing System32 is using Linux on an external drive and connecting it to the Windows box. You have full access to all of the system's files and the system administrator can do nothing about it! My friend, Tyler, does this and deletes system32 or renames it to profane names or things which are memes.
    chriskarrmicrochip55
    You would go about doing this by installing a linux partition on a USB hard disk, inserting the hard disk and, when the "select bootable hard disk' message appears, choose your removable disk. The computer will boot off of your disk and the entire hard disk of the system will be easily manipulated without restriction.
    Linux is an interesting OS. When you're using it on a harddrive also containing Windows, it says, "You know what? Go ahead and f*** this OS up; it's not me, so I don't care."
    When you try to access files in a Linux partition from a Windows partition or a different Linux partition, the one which you're trying to access says, "What do you think you're doing? These are mine, and I won't let you see them, a$$h***!"
    When you try to access the system files in a Linux OS which you own, it says, "Ummm...You need Root-Access to view these. Wait, what do you say? You have Root-Access? Well, I don't give a d***. If you want me dead, you'll have to do it my way."
    Doing anything to or from Windows OS', Windows says, "Can I help you with this? Perhaps I can bend over a little further."
    /me is visualizing the paperclip in Microsoft Office bending over past its elastic limit.
    gryffn
     i got to system 32 with run.exe
    puffyfluffraaams
    Reply 10 years ago on Step 1
    Was that meant to be funny? If it was, it's just because I have a very bad sense of humor.
    ranummpuffyfluff
    PowerShell is a new Command shell replacement for Windows. Object driven, and expandable using .NET Quite frankly it rocks. (let the windows bashing begin...)
    ranummpuffyfluff
    VB is ok, but if your serious about .NET, consider C#. Functionally, there is little that C# can do that VB cannot, but...C# is slightly more powerful, and much more consistent. Also, very much in demand right now...
    iRuleranumm
    i have the thing with vb, C,C++,dll, and all the others built into that program thing that makes it easier to write em.
