Make a Dust Mask Out of a Tee Shirt
11,073
81
11
About: I'm a remodeling contractor and longtime woodworker.
Do you hate every dust mask on the market? Me too. Most of them are more trouble than they're worth. The cheap throwaways never fit your face well enough, and if you just need one for a trip up to the attic or something it might not make sense to go buy an expensive respirator.
Unless you're really into steamed up glasses and breathing in the dust coming in around the damn thing anyway, try making one of your own. If it's going to be for a one time use, you can throw it away or recycle it when you're done. Or you can keep it, as it's also useful in some other ways. I use mine to wrap up my chisel when I carry it in my toolbag. It's handy for a rag, too.
You can just tie a bandanna around your face, but it only ties in one place and can slip off. Cutting a tee shirt in the way I'm going to show allows you to tie it in two places. It's very comfortable.
Watch on YouTube here
Supplies:
Step 1: Cut the Bottom
Lay the shirt out flat. Cut about a handspan's width out of the bottom. When you lay your hand down, you don't need to spread your fingers out - just place it there. Your handspan will cover your face holes. Put your hand up to your face right now and see! That's how wide the fabric should be.
After you cut off the bottom, make one cut to free the ends. Put the two ends together and fold the long piece in half to make the rest of the cuts.
Step 2: Cut Out the Ties
Measure out three handspans. The first represents the part that covers your face and the other two represent the length of the ties. If your piece is more than three handspans long, you can cut that last bit off or leave it for longer ties.
Cut out the center, leaving a big fat thumb's width on the upper and lower edges for the ties. I cut these two sections one handspan at a time because I use these scraps, as you'll see.
Step 3: Tie It On
Grab two of the ties, pull the mask across the bridge of your nose and tie them around the back of your neck. Grab the other two ties (pulling the lower part of the mask under your chin) and tie them up on top of your head.
Step 4: Bonus Protection!
Don't throw those scraps away - you can use them as extra layers to maximize filtration! Stuff them in the gaps beside your nose, or sew them in.
Step 5: Go Fearlessly Forward to Some Probably Horrible Task
Godspeed.
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    11 Discussions
    gracat72
    2 years ago
    Looks easy enough to make and hopefully stop my spectacles from steaming up.
    gracat
    Kinderhookgracat72
    Reply 2 years ago
    That's always my problem. Let me know if it works out for you!
    gracat72Kinderhook
    Reply 1 year ago
    Glasses did not steam up. dust free breathing
    Lil_Flowa
    2 years ago
    Seems perfect i'm trying this for sure i hate those one-use dust masks too!
    kmacdonell
    2 years ago
    this is both a clever design and an effective health technology all with a humble shirt and imagination. Thank you and well done!
    Yonatan24
    2 years ago
    Great idea! I will probably try this in the future - we have the same opinion about dust masks.
    Fav'd.
    JoSte0421
    2 years ago
    Brilliant idea. Will definitely be trying this.
