Make a Layout Square
1,767
35
About: I have been working with wood since I could stumble into the shop with my dad. About a year ago I moved into a house with no space for a full shop so I decided to take up all hand tool wood working. That sta...
The layout square is the predecessor tot he carpenter's square as we know it today and this simple design goes back pre-history. They are found in every culture and time. almost all built the same way just different decorations and sizes to match the culture and use. we decided to make this out of Maple and walnut as it is a bit cliche but still a strong contrast! this can be built in a long afternoon and if treated well can last the rest of your life. it is also a fantastic learning exercise as you get to play with two different joints and a few simple angles. Then you can do whatever you want to the finished look.
Tools Needed
#4 Hand plane setup for smoothing: http://amzn.to/2hc6LQZ
Squair: http://amzn.to/2ia9M3Z
Marking Gauge: http://amzn.to/2i0jvHx
Panel saw: http://amzn.to/2hjAura
Marking knife: http://amzn.to/2hPHf34
Brace: http://amzn.to/2hPEs9Y
Bit set: http://amzn.to/2hZVT5T
Chisel Set: http://amzn.to/2i26mzX
Flush Cut Saw: http://amzn.to/2jI0z05
File set: http://amzn.to/2l0czdB
V-Tool: http://amzn.to/2kf8OjO
Router Plane http://amzn.to/2nba2Qc
F-Clamps http://amzn.to/2nrdEzs
Supplies Needed
2 Maple beams 2 1/4" X 3/4" X 22"
1 Walnut Cross member 2 1/4" X 3/4" X 22"
3/16" oak dowel: http://amzn.to/2kEj1GV
wood glue: http://amzn.to/2kEeTHc
Boiled Linseed Oil: http://amzn.to/2hPEUVO
Past Wax: http://amzn.to/2inlN23
Supplies:
Step 1: Dimension Lumber
If you are working with rough sawn lumber you will want to dimension the lumber. this is done by flattening one side then squaring one edge to that side then bringing the other edge and face to the appropriate dimension. I have a full video on this step with a lot more detail, https://www.instructables.com/id/How-to-Dimension-Lumber-With-Hand-Tools/ but most people will skip this step as they either have pre-dimensioned the lumber or buy it that way.
Step 2: Cut Bridal Joint
The bridal joint is a simple joint. it is much like a mortice and tenon but it is only captured on 3 of the 4 sides of the tenon. This is the joint that holds the main corner of the square. There is far more here to go into than one step can handle so I have a full video on this joint. Bridal Joint Video with a simple hand saw and chisel these can be made quickly!
Step 3: Cut Half Lap Joint
The half lap joint is very similar to cutting a bridal joint but you are only cutting one-half of the tenon on either joint. with the beams in place and square set the cross member on top of the beams and trace it out with the making knife both where it intersects the beams and the cross member. then just like with the tenon cut down on the shoulder and the cheek. For the main beam, it is easier to cut the cheek with a chisel and router plane than with a saw. do not let the angle complicate this in your mind it is still cutting straight lines to depth just the wood is turned 45 degrees.
Step 4: Shape Beam
Here you can get creative. I wanted mine to look a little Celtic so I drew a circle on the end of each beam with a cup that was in the shop. some like to do ogies or other decorative designs here. This is where you can have fun as they really do not matter. I used a chisel to take it down close to the line but you could as easily use a coping saw or turning saw. After cutting it out, you can use a file to smooth out the shape. Last, use the first beam to transfer the design to the second beam.
Step 5: Glue Frame
For gluing the frame I use F-Clamps to hold the joints. Also, at thes point I want to make sure it is close to square so I use a square to check before clamping it tight. then let it set before going further.
Step 6: Pin Joints
I like to add pins to the joints more for look than function. I just drilled 2 3/16" holes per joint. Then, cut some oak dowel to fit the holes. With a little bit of glue, they will not come lose.
Step 7: Trim Off
Using a flush cut saw you can cut off the dowels and the ears from the cross member. Then I use a smoothing plane to smooth out all faces and edges.
Step 8: Square the Square
This is the critical point where we turn it into an actual square. If you have a square you trust, you can use that to make the adjustments, but if not you can use a board with a straight edge. By drawing a line with the square then flipping it over and drawing the same line at 90 degrees to the straight edge you can see where material needs to be removed. You can use a smoothing plane to bring it into square so that when you draw the two lines they line up perfectly with each other.
Step 9: Carving and Finish
For my hand tools, I like to add some carving. this is a lot easier than it looks and a lot of fun. with a V- tool it can be done quickly. Carving videos
For a finish, I use Boiled Linseed Oil and Paste wax. It is a simple finish and feels great in the hand. here is a full video on my finishing method. BLO and Pastewax Video
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    2 Discussions
    jmdushi
    2 years ago
    I love the detail in the carving, everything fits and connects, just perfect.
