Make a Monopod From a Walking Pole, Using Sugru.
16,873
24
10
About: Find me on Reddit, Tumblr and Twitter as @KitemanX. Buy my projects at bit.ly/LWLaser
My boys have started getting into photography, but often have trouble keeping the camera still enough for really clear shots.
The obvious solution is to buy a mono-pod, but why buy when you can make, especially when you have Sugru?
Edit: this project got picked up by PetaPixel!
Supplies:
Step 1: Materials and Tools
Materials:
I used a cheap aluminium walking pole (which I already had), a quarter-inch diameter bolt, a few centimetres of 2mm paracord and a 5g "Smart Hack" sachet of black Sugru.
Tools:
Leatherman multitool, rotary tool and various small pointy things that came to hand.
________________________________________
On the subject of materials, allow me a small off-topic rant:
Always buy your hardware from a proper, local ironmongers (hardware store).  They know what they are doing, and they know their stock.
I bought the bolt for this Make from my local ironmonger.  It cost me 7 pence, and is exactly what I needed.
My father has no local ironmonger, just a branch of a large chain "DIY" store. When he needed a small hook a few days ago, he had to buy a bag of five, they cost £2.65, and the first two snapped when he tried to screw them into the wood.
Step 2: Excavation.
The walking pole had a small, unreliable compass built into the top.  I prised it out with my knife, ready to widened and deepen the hole to take the bolt.
This revealed a small cross-head screw, which I wasn't expecting.  I removed the screw, and the wrist strap fell out of the slot in the side of the handle.  Oops (more on this later).
I fitted my rotary tool with the bit that looks like a dentist's burr, set the tool to its lowest speed to avoid melting the plastic, and started digging.
I realised that the plastic of the handle was quite flexible, so I avoided making the hole any bigger, furtling around inside the hole instead, widening the hole beneath the surface to take the head of the bolt.
When it was deep enough, I forced the bolt-head sideways through the entrance to the hole, then it popped into place.
Step 3: Back to the "Oops"
Remember how the wrist strap fell out?
I couldn't put the screw back to hold it in, so I knotted a small loop of paracord through the strap, pushed it back into the slot from whence it fell, and then pulled the loop over the top of the bolt, using the pliers of my Leatherman.
I also threaded a second loop of paracord into the slot and over the bolt, but this time I left a long piece of the cord hanging out to fasten stuff to later.
Step 4: Sugru!
Time for the Sugru!
I'd never used this stuff before, but it just may turn into my favourite specialist material.
I used about half the blob (5g sachet of the black Sugru) to fill and pack around the bolt.  despite starting off quite clammy and sticky, it proved surprisingly easy to mould and shape.
A small jeweller's screwdriver proved very useful in scraping the un-cured Sugru from the exposed threads of the bolt, and as a tiny rolling pin to smooth off the worst of my thumb prints.
The other half of the Sugru became a safety cap - I embedded the nut in it, and then inserted the loose end of the paracord in it to prevent loss.  I knotted the end of the cord to make it less likely to pull out of the cured Sugru later.
The screwdriver again proved useful, pushing the Sugru back up the hole in the nut and out of the threads.
Step 5: Cured!
Sugru doesn't set instantly.  The packet says a 3mm thickness takes 24 hours to cure, and parts of this are easily twice that thick, so I left the mono-pod for two full days before attaching the camera properly.
The cured Sugru felt very like the original rubber of the handle, and is closer in colour than it looks in the photos.  The finished mono-pod is not as rigid as I hoped (which may be because I did not pack Sugru all the way down the hole), but it works, which is what I needed.
I've got to say, I'm impressed with my first experience of Sugru.  I wonder what I can do next?
First Prize in the
Sugru Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    10 Discussions
    rimar2000
    8 years ago on Introduction
    Good idea, Kiteman! One question: in the UK, is the walking stick used usually, or only handicapped people use it? (maybe I read too many novels of Sherlock Holmes)
    Kitemanrimar2000
    Around town, walking sticks are generally aids to walking (for the elderly or infirm). These, though, are walking poles, intended for hikers to take some of the strain off their joints and help balance on tricky terrain.
    santy22gmjhowe
    Pretty sure you can't take on more than a mole with an aluminum hiker pole.
    ewfw
    Oh my gosh, I did this a few years back before I knew about instructables. I used J-B weld and it has held for many excursions. With a little ingenuity you can prop it up and get yourself in the picture.
    Great instructable.
    ChrysN
    "why buy when you can make"
    Sounds like a great motto.
