Make a Mousepad
3,252
22
About: Hi. I'm Ellen, PhD student by day and sewer/crafter/maker by night. I believe anyone can be a maker, so I post videos on YouTube about what I make and how I make it to offer some help. I believe that if you...
While a mousepad isn't really necessary anymore, I get really annoyed by the sound of a mouse sliding over a desk. So I decided to make my own mousepad to get rid of that sound. It's a quick project that doesn't require a lot of materials and tools, and allows you to make a mousepad in any size, shape and colour you want.
What you'll need:
- non-slip mat
- thin craft foam
- smooth, non-stretch fabric
- all-purpose glue
- scissors
Supplies:
Step 1: Get Your Layers Ready
After some experimenting, I ended up with a three layer design. First a layer of non-slip material. Then a layer of thin craft foam. And finally a piece of smooth, non-stretch fabric with the colour or design you want. Cut them all to roughly the same size.
Step 2: Glue Test
Now the layers need to be glued together in a nice mousepad sandwich. It's a bit of a strange mix of materials, and I want it to still feel soft and smooth afterwards, so I wasn't sure what glue would work best.
I set up a little mousepad glue battle with some scraps and the glues I had on hand: all-purpose glue, craft glue and fabric glue.
The fabric glue seeped through the thin fabric and left a visible white residue. The craft glue looked good, but was quite hard to the touch. The all-purpose glue both looked good and had a nice feel to it, so that's what I continued with.
Step 3: Assemble the Layers
To make the mousepad, I spread a layer of glue on one side of the craft foam. I placed the fabric on top, smoothing out any wrinkles and bubbles. The glue sinks into the fabric, so I let this dry before moving on.
I then repeated the glue process on the other side of the craft foam, adding the non-slip mat.
Step 4: Cut to Size
After this all dried, I drew out the shape I wanted for the mousepad and cut it out.
Finally I gave the non-slip mat a bit of a trim, since it was peaking out the sides a bit. I also decided to make the edge black with a permanent marker.
That's all there's to it. It's quick and simple, and you can make mousepads in any shape, size and colour that you want. I'm very happy with mine and already know I'll get a lot of use out of it.
Stick It! Contest
Runner Up in the
Stick It! Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    3 Discussions
    JayneC23
    10 months ago
    Thanks for the Instructable, though it'd be helpful to include a bit more info about the kind of glue you'd used. In the vast world of adhesives there're many different types... and for the most part, all glues fall into one of several different categories/types of adhesives, depending on their formulation or the main ingredient(s) they're made of... as well as other key characteristics.
    And "All-Purpose" is a fairly vague, generic description... a denomination given to products by manufacturers mostly for marketing reasons. But it doesn't say much about the kind of glue/adhesive it is or what it's main make-up is. So one manufacturer/brand's "All-Purpose" glue product can be quite different in formulation, consistency, performance, etc. than what another manufacturer/brand might tout as their "All-Purpose" adhesive, even though both are made and marketed for general household use.
    Considering you'd included the sample tests you'd done with different glues to point out the varying differences of each after they'd dried and cured, and how the aesthetic or tactile qualities of the fabric can be affected as a result and would, therefore, also affect the end result of the finished project... and when pertaining to adhesives that might not be commonly recognized or readily available in other countries, or when labelled in a different language, it'd be especially helpful to include a little more info about the type of glue you'd used since it seemed to work out well for you (and because this is an Instructable, after all). :)
    It'd help so others wouldn't necessarily have to go through the same process of trial and error as you had... or so those who don't already have a variety of glues to try out would have a better idea of what to look for or buy (and hopefully not end up with a hard or wrinkly mouse pad, or whatever could be the case!)
    John Made it
    11 months ago on Step 4
    nice work. well thought out and explained :)
    jessyratfink
    11 months ago
    This is great! I've been meaning to buy a cheap one for ages, but I'll have to do this instead. :)
