Make a PVC Microphone Shockmount for $1.20
40,312
106
10
About: I'm a tinkering filmmaker who likes to build stuff for my films.
What is a shockmount?  If want to record dialogue for your movie, using a shotgun mic on the end of a boom pole is a good way to capture it.  The problem is that if your mic is connected directly to the pole, it will pick up noise from the operator's hands.  A shockmount suspends the mic up and away from this potential noise.
A few years ago, I published an Instructable for a rubber band mic shockmount that was became featured on the home page.  I received positive feedback, but after finally using it in the field, I didn't like it.  The rubber bands tended to move too much and the whole thing looked cheap.  I think I've come up with a better build that is tougher, easier to make, and less expensive.
Step 1: Parts List
1/2" PVC pipe scrap (2.5" long) - FREE (or just over a buck for a 10' length)
4 rubber bands - FREE (rubber bands are everywhere)
1  1/4" x 1/2" Tee fitting - $1.20 at Lowe's
Step 2: Tools
Pencil
Dremel
PVC ratcheting cutters
Step 3: Place Bands Around Large End of Tee Fitting
The idea here is to create a narrow hole for the microphone to rest in.
Step 4: Mark Where Bands Lie With Pencil
Leave a mark on both sides of each rubber band.  Pencil is better than ink as you can easily rub off leftover marks when done.
Step 5: Remove Bands, Dremel, Replace
Time to create the notches which will give the bands a firm grip on the tube.
Step 6: Insert PVC Pipe and You Are Done!
If you like this kind of thing, come check out The Frugal Filmmaker!
Step 7: Here's the Video Version...
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    10 Discussions
    svarnell1
    7 years ago on Introduction
    Just in case someone isn't paying close attention your 1 1/4" x 1/2" is missing a -. Should have read 1-1/4" x 1/2" Or even possibly 1¼" x ½" (ASCI codes alt 171 and 172 on num lock keys)
    I would have painted the whole thing too, because PVC has low UV resistance and it will discolor. Flat black would probably be the best.
    I like this design. It is great for those without a boom pole (yet). Would you mind posting an ible' about it, or discussing what you used/did? Thanks!
    The base at the very bottom came with the microphone and it is the type that just slides on and then screws tight on top of the camera. I took that with me to Home Depot and just made sure that the pvc pipe (white piece) I bought fit nice and snug. I had to look around the plumbing section for the black pvc piece, so you can use whatever works for you. After I made the slots for the rubber bands I drilled a couple of screws into the base and the pvc to make sure that the mic didn't slide to the right or to the left. This thing is pretty steady, I have actually run around with and it stayed on. The best part, and the main reason I built this thing, is that I no longer pick up the sound of my camera's hard drive (faint little ticks). It will probably take you a few hours to make, but if you are broke and have the time it definitely beats spending the $30-$40. Good luck.
    Thanks for the description! Would you happen to have the exact pipe measurements? Like 1/2" for the main pvc connecting to the mic holder, or the main shockmount piece size? Thanks again!
    CrLz
    9 years ago on Introduction
    Nice update!
    I'd suggest trying elastic hair bands (ponytail holders) for a nicer looking rubber band.  I've found the hair ties to last longer and the fabric covering looks good.
    photodude
    I think it's brilliant. I plan to build a couple for some studio mics I use to record music. Thank you.
