Make a Tiling Image in Photoshop
113,396
11
9
Learn how to make an image that can repeat in all directions in Photoshop 7.0 or later. Tiling images are great for desktops.
Supplies:
Step 1: Get a Good Picture
The picture you use should make sense when tiled (for example, tiles). A good example of a bad tiling image is one of a street sign, since you only need one. I used a nice picture of Bacon. You can find a good picture on Google, or you can just use my bacon.
Step 2: Open the Picture
Open the picture in Photoshop, or GIMP. I will be using Photoshop 7.0. If using the bacon picture, for inspiration, go make bacon. After making the bacon, stare at it for a while, and eat it before it gets cold.
Step 3: Offsetting the Image
Since the offset filter doesn't have a "half-image offset" button, we have to find out what half of the pixels of the image are. There are two ways.
1. Go to the "Image" drop-down, and click "Canvas Size". From there, make both of the drop-downs show "percent", and then change the percent to 50. Then, change the drop-downs back to "pixels" and remember the numbers.
2. Go to the "Image" drop-down, and click "Canvas Size". Calculate half of the canvas sizes, and remember the numbers.
Our bacon image is to be offset 190 x 127 pixels.
To offset, go to "Filter", "Other", "Offset..."
Make sure you select "Wrap Around"
P.S. Sometimes, if you have been working on the picture beforehand, make sure to crop the image, and select to delete the cropped out part. This gets rid of any unwanted offsetting.
Step 4: Fix Borders
Now that the picture is offset, when I say "borders", I mean the middle of the picture, where it doesn't look right.
There are many ways to fix the borders, but using all of the techniques will have the desired effect.
-Use the Clone Stamp Tool (S)
The Clone Stamp Tool will be used to copy the parts of the picture that are totally different. In the bacon picture, I used it to make the skinny white part be connected through the border.
-Use the Healing Brush Tool (J)
The Healing Brush Tool will help to fix all of the slight discolorations between the "borders" of the picture. In the bacon picture, I used it to make the colors of the red parts be flawless looking.
Step 5: Afterwards
I then rotated it by 90 degrees, so it would look nicer on my monitor.
Save Your File
Right-click your desktop, select "Properties", go to display, and then "Browse". Select the file, and then select "Tile". Of course, then "Apply"
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    9 Discussions
    cubby40
    9 years ago on Step 5
    Thank you, this is very helpful, you can use this for more than your desktop, you may use it on a website as well.
    Dipankar
    10 years ago on Introduction
    You can do anything with a photograph in Photoshop. The other name for Photoshop is Photo Manipulation.
    karen608
    11 years ago on Introduction
    wo! you really do 'bring home the bacon' huh? why do i now want to go to the kitchen and fry some bacon? :D thanks, really informative for us beginners.
    jak06
    or u could use paint and flip the image. then put then all together
    I luv prosciutto! Just not on my desktop. Oh, and thanks for offering to let us use your bacon.....in the end it looks kinda like a partial American flag made of meat...
    a_d777
    12 years ago on Introduction
    wuff !!! u use norton antivirus!!! pretty good idea ...
    quicumque
    Wow. That's a pretty sick (as in gross) background. Good idea though.
    darth2oewilhelm
    Reply 12 years ago on Introduction
    there, but the "print scrn" I took isn't really of high caliber (quality)
