Make a Tyrannosaurus Rex (using Plastic Trash)
3,411
26
23
About: I'm Mario Caicedo Langer, from Colombia, former Navy officer and BSc in Naval Sciences. Right now I'm Technical Director and Technology Lead Teacher at STEM - Engineering for Kids Azerbaijan. Also, I'm artis...
The world is aware of the enormous amount of plastic trash we are throwing to the environment. And now more than ever, is important to teach in the schools how to reduce, reuse and recycling. This educational project will show how to build a dinosaur using plastic trash available in home. And the best part? It will be a durable and funny toy!
LEARNING OBJECTIVE
By making an ecodesigned dinosaur, students will be able to recognize building materials in everyday trash, use those materials to create artifacts for school and for fun and apply concepts of reduce, reuse and recycling.
Step 1: Materials
You will need:
  • 1 case for orthodontic retainer (for the head. You can replace it with a computer mouse, but it will be more tricky to build the mouth)
  • Plastic caps and cases from shaving foam, liquid detergents, beverage and other plastic stuff (look at the picture)
  • Screws, nuts and rings
  • 2 plastic circles (for the eyes. I use two from alcoholometer mouthpieces)
  • Red rubber or EVA foam (for the tongue)
  • For the arms, I use pieces from a damaged Transformer (the legs of an Animated Bumblebee)
TOOLS
Dremel Rotary Tool
tweezers
screwdrivers
pliers
And don't forget:
1. If you don't have it, replace it!
2. Use protective equipment (dust mask and goggles)
3. Beware of drilled and soldered hot surfaces
4. Work in a good ventilated area.
5. Always have junk in stock
6. Enjoy!
Step 2: Drilling Joint Holes
Drill holes in the center of the shaving foam and deodorant caps, and in the bottom of the retainer case (for the spinal column)
Drill holes in the upper part of the toothbrush cases (for the legs articulation)
Step 3: Head, Neck and Body
Insert a long screw from the bottom of the retainer case, and thread the caps from foot deodorant and shaving foam.
In the end, screw a ring and a nut.
Step 4: Legs
Drill holes on each side of the body.
Using screws and bolts, attach each leg to each side.
Step 5: Tail
Insert the plastic wheel in the body, and fix it with screws.
Put the beverage cap and fix it with screws. Now, you have the tail.
Step 6: Arms
I make the arms using the hips and legs from a Transformers Animated's Bumblebee action figure (damaged) and a piece from a Genius PC joystick.
Cut the joystick piece in half, making two talons, and attach them in each arm.
Attach one arm in each side of the dinosaurs neck.
Step 7: Face
Use the mouthpieces discs, screws and rings for making the eyes.
Glue the red rubber piece (or red EVA foam) to the mouth, for making the tongue.
And now, YOU HAVE YOUR ECODESIGNED DINOSAUR TOY!
    • Weaving Challenge
      Weaving Challenge
    • Tape Contest
      Tape Contest
    • Paper Contest
      Paper Contest
    23 Discussions
    JoLoveN
    4 years ago
    I wish the teachers would be taught how to be more creative & to RRR instead of just throwing everything away.
    lord_kianM.C. Langer
    Reply 6 years ago on Introduction
    Esas son las cosas de la vida que arrancan una sonrisa.
    That are the things in life that make a smile
