Make a Wing Bolt From a Plastic Bottle
11,206
99
37
About: Innovative Projects, Diy's, Life Hacks
More than once I needed a wing bolt, but I did not have one.
In this Instructable, I show you a trick how you can make a wing bolt from a bolt and a plastic bottle.
Step 1:
I cut off the bottle neck
Step 2:
I put the bolt in the vice and heated up the bottleneck with a heat-gun.
If you don't have a heat-gun, you can use an oven or a candle.
Step 3:
I used my hands and pliers to shape the wings.
Step 4:
Then I cut off the excess plastic
Step 5:
That's it! Our wing bolt is ready.
You might assume that the plastic will break, but actually it's very strong.
I could no break it with my hands.
Apart from making the wing nut, you can use this method to undo nuts and bolts in emergency situations.
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    37 Discussions
    Microbe
    1 year ago
    Great idea. But I doubt that in an "emergency situation" I would have a heat gun or a rotary tool handy ;o)
    DakotaLallyMicrobe
    Reply 1 year ago
    A lighter should suffice and the rotary tool would only be needed for aesthetics, unless you are in a really tight situation, in which case this might not work anyways.
    Good points, but if in a true emergency, work with the tools you have available to get the job done.
    Lovetra
    Question 1 year ago on Step 5
    SHOULD or is there one or the other type of plastic bottle that is better plastic to use? I mean it seems to me that milk bottles are of a more pliable plastic but maybe not as long lasting, ie more susceptible to sunlight degeneration? Love the concept, needed a wing nut a couple of days ago and drove 3 miles to get one.
    ShakeTheFutureLovetra
    Answer 1 year ago
    I don't think milk bottle plastic will work very well as it's very soft.
    In this Instructable I used a bottle from a sparkling water..... it's just like a like a coca-cola bottle.
    It works very well because it's very hard.
    I tried to use a cap from a juice carton, but it was too soft.
    LovetraShakeTheFuture
    Reply 1 year ago
    I sort of thought as much, but sometimes my thinking is all wrong. I am finding half gallon milk bottles with the bottom part cut off at a slant great pet food scoops, easily replaced and I keep the caps on cause sometimes I can use also with cap removed as a funnel. Oh! made a wing nut out of a Pepsi bottle and I love it. Did it just so I would remember the exercise when I need it next time.
    DakotaLallyLovetra
    Reply 1 year ago
    "Did it just so I would remember the exercise when I need it next time."
    That is a great idea! I often read things like this but forget about it when the time comes, a practice run to cement it to memory would certainly help.
    DakotaLally
    1 year ago
    Excellent instructable. This will definitely come in handy as I always try to reuse before I recycle and plastic bottles are a prime candidate.
    alhaxxor
    1 year ago
    Excellent idea, this helped me in a pinch when I lost one for some prefab fruniture!
    Lovetraalhaxxor
    Reply 1 year ago
    My exact need about a week ago that presented a trip to the hardware store when that was not convenient for one item.
    Reply 1 year ago
    Thanks for leaving the comment.
    I do it all the time. Making journeys to the store and spending 1h of my time only to buy small item that I did not have in stock.
    That teaches me to stock up on things I might use, but you you never know what you'll need :)
    carl5blum
    1 year ago
    Hello:
    Nice idea!
    You could put a fender washer under the head and hold it there with a nut. Then when you formed the wings they wouldn't need to be trimmed below the bolt head.
    Thanks, Carl.
