Make a Night Time Orthodontic Retainer
324,252
30
85
I lost my retainer about 6 months ago. It was a clear invisalign retainer, and I really didn't want to pay 200 dollars to get a new one. So I made my own, and they work great.
The pictures show the finished product.
Notice that they are white, so they are only really good for night time, unless you want to look like a dork. Usually after 6 months you can only wear them at night anyways.
Step 1: Materials/ Tools Needed
A glass cup
Water
Around 5 grams of Shapelock plastic, aka friendly plastic, per retainer
Microwave
The best place to get the plastic is by getting a 35 gram sample for 5 dollars here
http://shapelock.com/page3.html
Step 2: Melting and Forming
If this is your second retainer you are making, make sure you have the previous one in your mouth. This way they will fit together when you bite down.
Fill up the glass cup with water and put it in the microwave until it bubbles (around 2 min). Pour the shapelock plastic into the water and let it sit until it is all clear. Use a fork or something else to press the plastic together into a ball. Once it is totally clear, take it out with a fork and pull a chunk off of it, around 5 g. Then shape it into a half ring in the shape of your teeth. Make sure it is wide so you can fold it over the teeth. (See pic)
Do not try to press it onto your teeth yet. Once it is in a basic half ring shape, put it back into the water to let it soften again, then take it out and fold the edges in. (See pic)
Step 3: Fitting
Once that is done, soften it again by putting it in the water, then immediately take it out and place it in your mouth, over your teeth (top or bottom). Try to create suction with your mouth to get the retainer to fit snugly over your teeth. Use your fingers to press the plastic around your teeth also. If this is your second retainer you are making, bite down so that the other retainer makes an impression in the current one. This will ensure that they fit together.
Leave the retainer in your mouth for a few minutes while it hardens, then take it out.
If any part sticks out and is uncomfortable, it can be cut off with scissors or tin snips.
If it still is not the way you want it, resoften it in the water again and reform.
This plastic can be melted as many times as needed.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Organization Contest
    85 Discussions
    galaxyman7Bethany_southern
    Answer 2 months ago
    I think the generic name for it is moldable plastic or morph plastic. The actual name of the plastic is PCL. It should melt in boiling water, and be food safe.
    Bethany_southerngalaxyman7
    Reply 2 months ago
    Where would i be able to get some of this plastic, I live in England and am unsure where I can get it from
    Reply 2 months ago
    I'm not sure where you could get it in England. You would have to look that up.
    galaxyman7CourtneyC74
    Answer 1 year ago
    They can crack if you make them too thin in areas, but if you make sure they are thick enough, they last forever
    magushnik01
    2 years ago
    Thats pretty cool. You can get professionally made retainers tho for much less than what you pay at the dentist. I'd go to www.royaldentaldirect.com
    kyler405galaxyman7
    Reply 2 years ago
    I have my mold from my orthodontist. Could i make my retainer from that? Its been wayyy to long to make it from my teeth ha.
    Kxl1e
    2 years ago
    I lost my retainer two days ago, I was looking everywhere for something I can use and I saw this, I am going to try to make it but I have a question. What do I do after its done in the microwave? Please answer right away and thank you..
    camillekn
    2 years ago
    can you get this plastic in any stores?
    DaniaA6
    2 years ago
    I wasn't able to get shapelock, is Instamorph okay?
    Chantelletj
    3 years ago
    Hello, i know this was posted some time ago but heres hoping youll reply. I broke my retainer after only having it for 2 months, whoops. Im in no position to pay the fees for a replacement and i have an obsession about my teeth. I think your idea if brilliant but im in the UK, so do you have any alternative tips please? Many thanks :)
    galaxyman7Chantelletj
    Reply 3 years ago
    The plastic is called "PCL". From wikipedia:
    "PCL also has many applications in the hobbyist market (sold under various tradenames, such as "InstaMorph", "Friendly Plastic", "ShapeLock", "PolyMorph", "Plastimake", "Protoplast", "Plaast" etc.)."
    So any of those will work, as long as they are food safe
    sissykeira
    3 years ago
    how do i make a clear retainer
    KashmereG1
    3 years ago
    Hey..i just ordered some of the plastic. Just wanted to know if you know how cavity fillings hold up when fitting the plastic around your teeth? Not recent fillings btw but old fillings.
    Thanks in advance man
    galaxyman7KashmereG1
    Reply 3 years ago
    It shouldn't affect them. The plastic isn't very sticky so it won't grab the fillings or anything.
    Xcom79
    3 years ago
    First off thank you for pointing a lot of us in the right direction but I do have some questions that your experience would be able to answer.
    I am ordering some of this stuff from amazon today. Any tips on your technique to go from glass to mouth without burning yourself? I will be using boiling water instead of microwave have you tried it and know of any problems I might have to be concerned about? Also how long do I have to keep it in my mouth before its hard enough to remove and still fit? Anything else you might not consider important because you have done this a few times before that I might need to know when I get start doing it myself?
    Again thank you very much for this information your going to save a lot of us a good amount of cash and having to deal with stress about our teeth moving!
    galaxyman7Xcom79
    Reply 3 years ago
    Your not going to have a problem with it being too hot. Just let it cool in the air and test it with yiur fingers before putting it in your mouth. Also, the plastic cools very quickly when it is in your mouth, so it is going to take a few times to get it to the right shape. Once you feel it become rigid, you can take it out. It should be pretty obvious.
