Make a Rain Proof Portable Generator Housing
295,639
115
37
About: I am an electrical engineer by education and a software developer by profession. I am like building electro-mechanical models. I also like grilling and barbecuing with passion. To burn my beer cals, I swim...
I live in New Jersey and as I write this instructable on October 28, 2012, we are about to be pounded by hurricane Sandy, To keep my sump pumps going, I decided to buy a portable generator in case the power goes out. The only generator I could get my hands on is this behemoth 225 lbs Generac 5500 watts generator. Keep in mind that I cannot run this generator in a covered open area. First on all, other than my small covered porch I do not have any other covered open area, secondly with 100 miles an hour wind, there is no such thing as covered and open. I had to make a cover which will protect the generator from rain and I will need to provide ample opening for it to breathe and dump its exhaust.
You can use this link to select and size a generator for your needs.
Step 1: The Design
As I mentioned before, the generator needs to be protected from the rain.  It should be able to breathe.  The cover should be beefy enough to stay on the generator.  If I was a sheet metal guy like the Tuttles from The American Chopper, I would have done every thing in sheet metal with a cool paint job.  Unfortunately my skills are limited to some crude carpentry, so I decided to make a plywood housing with louvered vents for air circulation.  I did think of generator getting hot and found the hottest part to be the exhaust muffler.  I decide to put a aluminum sheet as a shield against the heat.
Step 2: Start With the Top
I used a 24" X 32" X 0.5" plywood as the top.  Rest of the structure of the housing would be attached to the top.  I still had some nice hardwood railing bars left from the deck I built.  I attached those bars to the plywood using 1" long deck screws.  In the picture below you see two sides already attached.
Step 3: Make the Side and Front Panels
I cut pieces of plywood as per the design.  I used three pre-fabricated louvered vents (sold in Lowes and Home Depot for $1.50 a piece.)  I cut the slots in the plywood equal to the open area of the vents.  To cut the slots, I marked the rectangular area to be cut first.  I made four holes using a dremel inside the boundary of each line of the rectangle.  I used the jig saw to cut straight on the pre-marked lines to get a decent rectangle.  I fastened the vent on to the plywood using 1/2" machine screws.
Step 4: Make the Rear Panel
The rear panel is smaller than rest of the panels because it used on the exhaust side and I wanted the exhaust fumes to go out with very little obstruction.  However, the rain was still a concern and as I mentioned before the exhaust muffler gets really hot, I needed to protect the plywood from burning from the heat.  I had some flashing sheet laying around.  I cut a piece of sheet slightly bigger than the rear panel and attached it from inside on to the plywood using 1/4" machine screws.  Note that flexible aluminum flashing can be bent as a canopy to stop the rain and let the exhaust out.
Step 5: Attach All the Panels to the Top Panel
In this step I attached all four panels to the top panel using 1" deck screws.  I ran out of plywood so you will see that I used a smaller piece of plywood to cover the entire area.  To secure the panels from moving I used some L brackets to fasten two panels together.  The part where one panel was made of two pieces of plywood, I fastened them together as well using a flat bracket. I used some outdoor sealant caulk in between the joints to keep the water out.  The reason why I did not use a carpenter's glue for the joints is because I do not know yet whether my contraption will work or not.  If it does not work because the generator is not getting enough air, I may need to remove a panel or two.  A carpenter's glue due to its bonding strength will make this task extremely tedious.  I filled all the cracks with caulk.  After the caulk dried I sealed the plywood with the deck sealer.
Step 6: Conclusion
I will secure the housing on the generator by wrapping it with a bungee chord to stop it from being blown away by strong winds.
What happens next, only time will tell.  My design seems to be sound. I will keep you posted.
Be Prepared Contest
First Prize in the
Be Prepared Contest
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    37 Discussions
    kabiratriumphman
    Reply 6 years ago on Introduction
    I could very well be! I like beer, I like whiskey, and I love (I mean love love) corned beef! I do attend St. Patrick's Day in New York off and on. I am sure there is more to being Irish, but I hope, what I mentioned above suffice. :)
    tbird481
    Why not just get a GenTent? www.gentent.com a lot of people used them during Sandy and reviews are very positive.
    Riddle1814tbird481
    Reply 7 months ago
    I have a Pramac model S7500...their GenTent would not work on this unit for a number of reasons..
    tbird481Riddle1814
    Reply 7 months ago
    Primarily one reason, the Pramac S7500 has an open top with nothing blocking the muffler heat from venting upward. I would expect this is by design. So GenTent disqualifies generators that vent upwards so no heat is retained/captured. BTW your picture shows a Generac GP5500, GP6500 or GP7500. Honestly i apologize for ever posting here in my overzealousness and pride in the product I designed. It was the wrong thing to do and I wish there were a way to delete my comment from 5 years ago. thanks, Mark
    JoeJ8tbird481
    Reply 1 year ago
    I would but with your money. I'd rather make something and be proud of my accomplishment.
    kpqowieuryttbird481
    Reply 1 year ago
    Not wanting to be mean but instructables is a web for tutorials on how to do stuff. Not how to buy stuff. That's why.
    Riddle1814
    Question 7 months ago on Introduction
    I wondered how well it worked and also...no sure of the exhaust side...how the sheet metal played into the rain concerns. Understand the heat issue.. Picture did not give me a view that I could see well. Sorry... Do you have a better view of that specific side??
    DICKklomp
    1 year ago
    Looks good, but a couple of questions on the generator:
    1. How many devices are you powering ? 2. Does the gas tank have a drain plug ?
    D
    kabiraDICKklomp
    Reply 1 year ago
    Thanks.
    1. The generator is only 5500 Watts, which is not a lot. I had it to power sump pumps, a fridge, and a few lights, give or take a few; all under 5500 Watts.
    2. The generator does not have a drain plug. There several ways to empty the tank. You can let the unit run until it runs out of gas. You can buy a cheap siphon pump, empty the gas, and then let the unit burn the remaining gas.
    IngenuityAtWork
    1 year ago
    Good solution to a very real problem!
    FYI, at many big box home improvement stores, you can now buy 1/4" thickness 4'x8' HDPE plastic sheets; would be more durable and in my locality it's $40-50/sheet. One could also utilize foil-faced fiberglass board insulation for sound-dampening properties on the interior, and compared to other sound-dampening options like foam board insulation, it should withstand heat better. Could also add the sort of vent that is often used on farm buildings, where the tube exits 90* from vertical and swivels away from the wind direction, to allow for good air intake without scooping in rain at the same time. Could do the same for exhaust.
    nell.patrick.9
    2 years ago
    wood is a bad choice if your trying for quiet it carries sound maybe if you nailed some insulation inside
    RaymondR6nell.patrick.9
    Reply 1 year ago
    Wood will only transmit strong engine noise if the material is in direct contact with the engine. Isolating the box from the frame with rubber will help.
    zoocop
    1 year ago
    What a great idea. I've been looking for a cover for my Yamaha 2600 generator for a while and had settled on using a ice fishing sled attached with bungee cord. I looked at dedicated covers from GenTent (http://www.gentent.com/) but the money they wanted was outrageous. There are a few minor tweaks that I'll do when making one of these. Primarily I want to be able to knock it down when not in use but otherwise I like this.
    Ganigirll
    2 years ago
    Thank you I was trying to figure out how to do this when we lose power for days even up to a week with snow, rain and wind. I had the idea but now I have instuctions so I hope to get this built soon. Much needed. Thanks for sharing
    My portable generator has always been stored in my garage where there is a designated storage area for it to be especially guarded from harsh weather conditions like rainstorms or winter. However, to be able to build this rain proof casing for the generator would be beneficial especially if we were to be caught in an unexpected shower while using it outdoors.
    Hello Christopher,
    Yes, that was the idea behind the whole project. The project was done four days before the hurricane Sandy, which did a major damage in New York and New Jersey. Luckily for me the the power was gone for only twelve hours. We had some lights in the house, thanks to the generator, running on my driveway with rain and 70-80 MPH wind.
    Generator was a sought out commodity at that time. If you are interested, here is the store of how I acquired it.
    http://thisisnotcnn.blogspot.com/2012/10/my-precious.html
    Cheers!
    Tom 7
    6 years ago on Step 6
    it would be better to cut a larger top that covers and over hangs the side walls. that would help the structure last longer in the rain.
    some padding inside to soften contact points with help sound vibration.
